root/radiance/ray/src/common/objutil.h
Revision: 2.12
Committed: Wed Mar 3 18:53:08 2021 UTC (4 years, 4 months ago) by greg
Changes since 2.11: +5 -2 lines
refactor: added handy macros for getting group and material IDs
1 /* RCSid $Id: objutil.h,v 2.11 2021/02/15 18:45:11 greg Exp $ */
2 /*
3 * Declarations for .OBJ file utility
4 *
5 * Include after <stdio.h>
6 *
7 * Created by Greg Ward on Wed Feb 11 2004.
8 */
9
10 #ifndef _OBJUTIL_H_
11 #define _OBJUTIL_H_
12
13 #ifndef DUP_CHECK_REVERSE
14 #define DUP_CHECK_REVERSE 1 /* eliminate flipped duplicates */
15 #endif
16 #ifndef POPEN_SUPPORT
17 #define POPEN_SUPPORT 1 /* support "!command" i/o */
18 #endif
19 /* face flags */
20 #define FACE_DEGENERATE 01
21 #define FACE_DUPLICATE 02
22 #define FACE_SELECTED 04
23 #define FACE_CUSTOM(n) (FACE_SELECTED<<(n))
24
25 struct Face; /* forward declaration */
26
27 typedef int VNDX[3]; /* vertex indices (point,map,normal) */
28
29 /* Structure to hold vertex indices and link back to face list */
30 typedef struct {
31 int vid; /* vertex id */
32 int tid; /* texture id */
33 int nid; /* normal id */
34 struct Face *fnext; /* next in vertex face list */
35 } VertEnt;
36
37 /* Structure to hold face and its vertex references */
38 typedef struct Face {
39 struct Face *next; /* next face in main list */
40 short flags; /* face selected, etc */
41 short nv; /* number of vertices */
42 short grp; /* group/object index */
43 short mat; /* material index */
44 /* in cases where the same vertex appears twice, first has link */
45 VertEnt v[3]; /* vertex list (extends struct) */
46 } Face;
47
48 /* Structure to hold vertex */
49 typedef struct {
50 double p[3]; /* 3-D position */
51 Face *vflist; /* linked face list (no repeats) */
52 } Vertex;
53
54 /* Structure to hold texture coordinate */
55 typedef struct {
56 float u, v; /* 2-D local texture coordinate */
57 } TexCoord;
58
59 /* Array to hold surface normal */
60 typedef float Normal[3];
61
62 /* Structure to hold a loaded .OBJ file */
63 typedef struct {
64 char **descr; /* descriptive comments */
65 int ndescr; /* number of comments */
66 char **grpname; /* object/group name list */
67 int ngrps; /* number of group names */
68 int lastgrp; /* last group seen */
69 char **matname; /* material name list */
70 int nmats; /* number of materials */
71 int lastmat; /* last material seen */
72 Vertex *vert; /* vertex array */
73 int nverts; /* number of vertices */
74 TexCoord *tex; /* texture coordinate array */
75 int ntex; /* number of texture coord's */
76 Normal *norm; /* surface normal array */
77 int nnorms; /* number of surface normals */
78 Face *flist; /* linked face list */
79 int nfaces; /* count of faces */
80 } Scene;
81
82 #ifdef __cplusplus
83 extern "C" {
84 #endif
85
86 /* Allocate a new scene holder */
87 Scene * newScene(void);
88
89 /* Add a .OBJ file to a scene */
90 Scene * loadOBJ(Scene *sc, const char *fspec);
91
92 /* Duplicate a scene, optionally selecting faces */
93 Scene * dupScene(const Scene *sc, int flreq, int flexc);
94
95 /* Transform entire scene */
96 int xfScene(Scene *sc, int xac, char *xav[]);
97 int xfmScene(Scene *sc, const char *xfm);
98
99 /* Add a descriptive comment */
100 void addComment(Scene *sc, const char *comment);
101
102 /* Find index for comment containing the given string (starting from n) */
103 int findComment(Scene *sc, const char *match, int n);
104
105 /* Clear comments */
106 void clearComments(Scene *sc);
107
108 /* Write a .OBJ file, return # faces written or -1 on error */
109 int toOBJ(Scene *sc, FILE *fp);
110 int writeOBJ(Scene *sc, const char *fspec);
111
112 /* Convert indicated faces to Radiance, return # written or -1 on error */
113 int toRadiance(Scene *sc, FILE *fp, int flreq, int flexc);
114 int writeRadiance(Scene *sc, const char *fspec,
115 int flreq, int flexc);
116
117 /* Compute face area (and normal) */
118 double faceArea(const Scene *sc, const Face *f, Normal nrm);
119
120 /* Eliminate duplicate vertices, return # joined */
121 int coalesceVertices(Scene *sc, double eps);
122
123 /* Identify duplicate faces */
124 int findDuplicateFaces(Scene *sc);
125
126 /* Delete indicated faces, return # deleted */
127 int deleteFaces(Scene *sc, int flreq, int flexc);
128
129 /* Clear face selection */
130 void clearSelection(Scene *sc, int set);
131
132 /* Invert face selection */
133 void invertSelection(Scene *sc);
134
135 /* Count number of faces selected */
136 int numberSelected(Scene *sc);
137
138 /* Select faces by object name (modifies current) */
139 void selectGroup(Scene *sc, const char *gname, int invert);
140
141 /* Select faces by material name (modifies current) */
142 void selectMaterial(Scene *sc, const char *mname, int invert);
143
144 /* Execute callback on indicated faces */
145 int foreachFace(Scene *sc, int (*cb)(Scene *, Face *, void *),
146 int flreq, int flexc, void *c_data);
147
148 /* Remove texture coordinates from the indicated faces */
149 int removeTexture(Scene *sc, int flreq, int flexc);
150
151 /* Remove surface normals from the indicated faces */
152 int removeNormals(Scene *sc, int flreq, int flexc);
153
154 /* Change group for the indicated faces */
155 int changeGroup(Scene *sc, const char *gname,
156 int flreq, int flexc);
157
158 /* Change material for the indicated faces */
159 int changeMaterial(Scene *sc, const char *mname,
160 int flreq, int flexc);
161
162 /* Add a vertex to our scene, returning index */
163 int addVertex(Scene *sc, double x, double y, double z);
164
165 /* Add a texture coordinate to our scene, returning index */
166 int addTexture(Scene *sc, double u, double v);
167
168 /* Add a surface normal to our scene, returning index */
169 int addNormal(Scene *sc, double xn, double yn, double zn);
170
171 /* Set current group (sc->lastgrp) to given ID */
172 void setGroup(Scene *sc, const char *nm);
173
174 /* Set current material (sc->lastmat) to given ID */
175 void setMaterial(Scene *sc, const char *nm);
176
177 /* Add a new face to our scene, using current group and material */
178 Face * addFace(Scene *sc, VNDX vid[], int nv);
179
180 /* Delete unreferenced vertices, normals, texture coords */
181 void deleteUnreferenced(Scene *sc);
182
183 /* Free a scene */
184 void freeScene(Scene *sc);
185
186 /* Find an existing name in a list of names */
187 int findName(const char *nm, const char **nmlist, int n);
188
189 /* Verbose mode global */
190 extern int verbose;
191
192 extern char *emalloc(unsigned int n);
193 extern char *ecalloc(unsigned int ne, unsigned int n);
194 extern char *erealloc(char *cp, unsigned int n);
195 extern void efree(char *cp);
196
197 #define getGroupID(sc,nm) findName(nm, (const char **)(sc)->grpname, (sc)->ngrps)
198 #define getMaterialID(sc,nm) findName(nm, (const char **)(sc)->matname, (sc)->nmats)
199
200 #define CHUNKSIZ 128 /* object allocation chunk size */
201
202 #define chunk_alloc(typ, arr, nold) \
203 ((nold)%CHUNKSIZ ? (arr) : \
204 (typ *)erealloc((char *)(arr), sizeof(typ)*((nold)+CHUNKSIZ)))
205
206 #ifdef __cplusplus
207 }
208 #endif
209
210 #endif /* ! _OBJUTIL_H_ */
