root/radiance/ray/src/common/objutil.h
Mon Mar 14 19:51:19 2022 UTC (2 years, 7 months ago) by greg
CVS Tags: HEAD, rad5R4
Changes since 2.17: +5 -5 lines
Diff to previous 2.17
fix: corrected declarations for emalloc routines
Sat Jan 15 16:57:46 2022 UTC (2 years, 9 months ago) by greg
Diff to previous 2.16
refactor: eliminated use of MEM_PTR and (char *) for untyped memory
Fri Apr 23 18:31:45 2021 UTC (3 years, 6 months ago) by greg
Changes since 2.15: +7 -3 lines
Diff to previous 2.15
feat: Added getVertexNeighbors() call to find neighboring edges/vertices
Fri Apr 9 15:26:41 2021 UTC (3 years, 6 months ago) by greg
Changes since 2.14: +42 -38 lines
Diff to previous 2.14
feat: added growBoundingBox() to compute scene boundaries
Wed Apr 7 03:02:00 2021 UTC (3 years, 6 months ago) by greg
Diff to previous 2.13
feat: created addScene() function to add one scene to another
Fri Mar 12 03:59:25 2021 UTC (3 years, 7 months ago) by greg
Changes since 2.12: +9 -5 lines
Diff to previous 2.12
feat: added routine to triangulate .OBJ scene in memory
Wed Mar 3 18:53:08 2021 UTC (3 years, 7 months ago) by greg
Changes since 2.11: +5 -2 lines
refactor: added handy macros for getting group and material IDs
Mon Feb 15 18:45:11 2021 UTC (3 years, 8 months ago) by greg
refactor: aesthetic change to flag
Fri Feb 12 15:35:07 2021 UTC (3 years, 8 months ago) by greg
Changes since 2.9: +5 -4 lines
feat: Added custom face flag(s)
Fri Feb 12 01:57:49 2021 UTC (3 years, 8 months ago) by greg
Changes since 2.8: +6 -3 lines
feat: added ability to choose faces when duplicating scene
Tue Jun 23 19:29:40 2020 UTC (4 years, 4 months ago) by greg
Changes since 2.7: +4 -1 lines
feat(libwfobj.a): added findComment() call
Sat May 2 00:21:13 2020 UTC (4 years, 6 months ago) by greg
Changes since 2.6: +7 -7 lines
Comment changes
Sat May 2 00:12:45 2020 UTC (4 years, 6 months ago) by greg
Changes since 2.5: +7 -1 lines
Made addFace() into a public routine as well, so tools can add geometry
Fri May 1 18:55:34 2020 UTC (4 years, 6 months ago) by greg
Changes since 2.4: +16 -1 lines
Made some useful routines public from readwfobj.c
Sat Apr 18 17:10:33 2020 UTC (4 years, 6 months ago) by greg
Changes since 2.3: +1 -7 lines
Eliminated unimplemented declaration
Thu Apr 2 22:14:01 2020 UTC (4 years, 7 months ago) by greg
Added interface for transform from pre-parsed words
Thu Apr 2 20:44:15 2020 UTC (4 years, 7 months ago) by greg
Added -x option to robjutil to transform .OBJ files
Mon Mar 30 18:28:35 2020 UTC (4 years, 7 months ago) by greg
