| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: objutil.c,v 2.10 2020/12/18 00:15:47 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Basic .OBJ scene handling routines.
| 6 |
| 7 |
* Created by Greg Ward on Wed Feb 11 2004.
| 8 |
| 9 |
| 10 |
#include <stdlib.h>
| 11 |
#include <ctype.h>
| 12 |
#include "rtio.h"
| 13 |
#include "rtmath.h"
| 14 |
#include "rterror.h"
| 15 |
#include "lookup.h"
| 16 |
#include "objutil.h"
| 17 |
| 18 |
/* Find an existing name in a list of names */
| 19 |
int
| 20 |
findName(const char *nm, const char **nmlist, int n)
| 21 |
| 22 |
int i;
| 23 |
| 24 |
for (i = n; i-- > 0; )
| 25 |
if (!strcmp(nmlist[i], nm))
| 26 |
break;
| 27 |
return(i);
| 28 |
| 29 |
| 30 |
/* Clear face selection */
| 31 |
void
| 32 |
clearSelection(Scene *sc, int set)
| 33 |
| 34 |
Face *f;
| 35 |
| 36 |
for (f = sc->flist; f != NULL; f = f->next)
| 37 |
if (set)
| 38 |
f->flags |= FACE_SELECTED;
| 39 |
else
| 40 |
f->flags &= ~FACE_SELECTED;
| 41 |
| 42 |
| 43 |
/* Select faces by object name (modifies current) */
| 44 |
void
| 45 |
selectGroup(Scene *sc, const char *gname, int invert)
| 46 |
| 47 |
int gid = findName(gname, (const char **)sc->grpname, sc->ngrps);
| 48 |
Face *f;
| 49 |
| 50 |
if (gid < 0)
| 51 |
return;
| 52 |
| 53 |
if (f->grp == gid) {
| 54 |
if (invert)
| 55 |
| 56 |
else
| 57 |
| 58 |
| 59 |
| 60 |
| 61 |
/* Select faces by material name (modifies current) */
| 62 |
void
| 63 |
selectMaterial(Scene *sc, const char *mname, int invert)
| 64 |
| 65 |
int mid = findName(mname, (const char **)sc->matname, sc->nmats);
| 66 |
Face *f;
| 67 |
| 68 |
if (mid < 0)
| 69 |
return;
| 70 |
| 71 |
if (f->mat == mid) {
| 72 |
if (invert)
| 73 |
| 74 |
else
| 75 |
| 76 |
| 77 |
| 78 |
| 79 |
/* Invert face selection */
| 80 |
void
| 81 |
invertSelection(Scene *sc)
| 82 |
| 83 |
Face *f;
| 84 |
| 85 |
| 86 |
f->flags ^= FACE_SELECTED;
| 87 |
| 88 |
| 89 |
/* Count selected faces */
| 90 |
int
| 91 |
numberSelected(Scene *sc)
| 92 |
| 93 |
int nsel = 0;
| 94 |
Face *f;
| 95 |
| 96 |
| 97 |
nsel += ((f->flags & FACE_SELECTED) != 0);
| 98 |
return(nsel);
| 99 |
| 100 |
| 101 |
/* Execute callback on indicated faces */
| 102 |
int
| 103 |
foreachFace(Scene *sc, int (*cb)(Scene *, Face *, void *),
| 104 |
int flreq, int flexc, void *c_data)
| 105 |
| 106 |
int fltest = flreq | flexc;
| 107 |
int sum = 0;
| 108 |
Face *f;
| 109 |
| 110 |
if ((sc == NULL) | (cb == NULL))
| 111 |
return(0);
| 112 |
| 113 |
if ((f->flags & fltest) == flreq) {
| 114 |
int res = (*cb)(sc, f, c_data);
| 115 |
if (res < 0)
| 116 |
return(res);
| 117 |
sum += res;
| 118 |
| 119 |
return(sum);
| 120 |
| 121 |
| 122 |
/* Callback for removeTexture() */
| 123 |
static int
| 124 |
remFaceTexture(Scene *sc, Face *f, void *dummy)
| 125 |
| 126 |
int hadTexture = 0;
| 127 |
int i;
| 128 |
| 129 |
for (i = f->nv; i-- > 0; ) {
| 130 |
if (f->v[i].tid < 0)
| 131 |
continue;
| 132 |
f->v[i].tid = -1;
| 133 |
hadTexture = 1;
| 134 |
| 135 |
return(hadTexture);
| 136 |
| 137 |
| 138 |
/* Remove texture coordinates from the indicated faces */
| 139 |
int
| 140 |
removeTexture(Scene *sc, int flreq, int flexc)
| 141 |
| 142 |
return(foreachFace(sc, remFaceTexture, flreq, flexc, NULL));
| 143 |
| 144 |
| 145 |
/* Callback for removeNormals() */
| 146 |
static int
| 147 |
remFaceNormal(Scene *sc, Face *f, void *dummy)
| 148 |
| 149 |
int hadNormal = 0;
| 150 |
int i;
| 151 |
| 152 |
| 153 |
if (f->v[i].nid < 0)
| 154 |
continue;
| 155 |
f->v[i].nid = -1;
| 156 |
hadNormal = 1;
| 157 |
| 158 |
return(hadNormal);
| 159 |
| 160 |
| 161 |
/* Remove surface normals from the indicated faces */
| 162 |
int
| 163 |
removeNormals(Scene *sc, int flreq, int flexc)
| 164 |
| 165 |
return(foreachFace(sc, remFaceNormal, flreq, flexc, NULL));
| 166 |
| 167 |
| 168 |
/* Callback for changeGroup() */
| 169 |
static int
| 170 |
chngFaceGroup(Scene *sc, Face *f, void *ptr)
| 171 |
| 172 |
int grp = *(int *)ptr;
| 173 |
if (f->grp == grp)
| 174 |
return(0);
| 175 |
f->grp = grp;
| 176 |
return(1);
| 177 |
| 178 |
| 179 |
/* Change group for the indicated faces */
| 180 |
int
| 181 |
changeGroup(Scene *sc, const char *gname, int flreq, int flexc)
| 182 |
| 183 |
int grp = findName(gname, (const char **)sc->grpname, sc->ngrps);
| 184 |
if (grp < 0) {
| 185 |
sc->grpname = chunk_alloc(char *, sc->grpname, sc->ngrps);
| 186 |
sc->grpname[grp=sc->ngrps++] = savqstr((char *)gname);
| 187 |
| 188 |
return(foreachFace(sc, chngFaceGroup, flreq, flexc, (void *)&grp));
| 189 |
| 190 |
| 191 |
/* Callback for changeMaterial() */
| 192 |
static int
| 193 |
chngFaceMaterial(Scene *sc, Face *f, void *ptr)
| 194 |
| 195 |
int mat = *(int *)ptr;
| 196 |
if (f->mat == mat)
| 197 |
return(0);
| 198 |
f->mat = mat;
| 199 |
return(1);
| 200 |
| 201 |
| 202 |
/* Change material for the indicated faces */
| 203 |
int
| 204 |
changeMaterial(Scene *sc, const char *mname, int flreq, int flexc)
| 205 |
| 206 |
int mat = findName(mname, (const char **)sc->matname, sc->nmats);
| 207 |
if (mat < 0) {
| 208 |
sc->matname = chunk_alloc(char *, sc->matname, sc->nmats);
| 209 |
sc->matname[mat=sc->nmats++] = savqstr((char *)mname);
| 210 |
| 211 |
return(foreachFace(sc, chngFaceMaterial, flreq, flexc, (void *)&mat));
| 212 |
| 213 |
| 214 |
/* Compare floating point values for (near) equality */
| 215 |
static int
| 216 |
fdiffer(double f1, double f2, double eps)
| 217 |
| 218 |
if (f2 != .0)
| 219 |
f1 = f1/f2 - 1.;
| 220 |
return((f1 > eps) | (f1 < -eps));
| 221 |
| 222 |
| 223 |
/* Compare two texture coordinates for (near) equality */
| 224 |
static int
| 225 |
tex_diff(const TexCoord *t1, const TexCoord *t2, double eps)
| 226 |
| 227 |
if (fdiffer(t1->u, t2->u, eps))
| 228 |
return(1);
| 229 |
if (fdiffer(t1->v, t2->v, eps))
| 230 |
return(1);
| 231 |
return(0);
| 232 |
| 233 |
| 234 |
/* Compare two surface normals for (near) equality */
| 235 |
static int
| 236 |
norm_diff(const Normal n1, const Normal n2, double eps)
| 237 |
| 238 |
if (fabs(n1[0]-n2[0]) > eps)
| 239 |
return(1);
| 240 |
if (fabs(n1[1]-n2[1]) > eps)
| 241 |
return(1);
| 242 |
if (fabs(n1[2]-n2[2]) > eps)
| 243 |
return(1);
| 244 |
return(0);
| 245 |
| 246 |
| 247 |
/* Replace the given vertex with an equivalent one */
| 248 |
static int
| 249 |
replace_vertex(Scene *sc, int prev, int repl, double eps)
| 250 |
| 251 |
int repl_tex[10];
| 252 |
int repl_norm[10];
| 253 |
Face *f, *flast=NULL;
| 254 |
int i, j=0;
| 255 |
/* check to see if it's even used */
| 256 |
if (sc->vert[prev].vflist == NULL)
| 257 |
return(0);
| 258 |
/* get replacement textures */
| 259 |
repl_tex[0] = -1;
| 260 |
for (f = sc->vert[repl].vflist; f != NULL; f = f->v[j].fnext) {
| 261 |
/* make sure prev isn't in there */
| 262 |
for (j = 0; j < f->nv; j++)
| 263 |
if (f->v[j].vid == prev)
| 264 |
return(0);
| 265 |
| 266 |
if (f->v[j].vid == repl)
| 267 |
break;
| 268 |
if (j >= f->nv)
| 269 |
goto linkerr;
| 270 |
if (f->v[j].tid < 0)
| 271 |
continue;
| 272 |
/* see if it's new */
| 273 |
for (i = 0; repl_tex[i] >= 0; i++) {
| 274 |
if (repl_tex[i] == f->v[j].tid)
| 275 |
break;
| 276 |
if (!tex_diff(&sc->tex[repl_tex[i]],
| 277 |
&sc->tex[f->v[j].tid], eps)) {
| 278 |
f->v[j].tid = repl_tex[i];
| 279 |
break; /* consolidate */
| 280 |
| 281 |
| 282 |
if (repl_tex[i] >= 0)
| 283 |
continue; /* have this one already */
| 284 |
/* else add it */
| 285 |
repl_tex[i++] = f->v[j].tid;
| 286 |
repl_tex[i] = -1;
| 287 |
if (i >= 9)
| 288 |
break; /* that's all we have room for */
| 289 |
| 290 |
/* get replacement normals */
| 291 |
repl_norm[0] = -1;
| 292 |
| 293 |
| 294 |
| 295 |
break;
| 296 |
if (f->v[j].nid < 0)
| 297 |
continue;
| 298 |
| 299 |
for (i = 0; repl_norm[i] >= 0; i++) {
| 300 |
if (repl_norm[i] == f->v[j].nid)
| 301 |
break;
| 302 |
if (!norm_diff(sc->norm[repl_norm[i]],
| 303 |
sc->norm[f->v[j].nid], eps)) {
| 304 |
f->v[j].nid = repl_norm[i];
| 305 |
| 306 |
| 307 |
| 308 |
if (repl_norm[i] >= 0)
| 309 |
| 310 |
/* else add it */
| 311 |
repl_norm[i++] = f->v[j].nid;
| 312 |
repl_norm[i] = -1;
| 313 |
if (i >= 9)
| 314 |
| 315 |
| 316 |
/* replace occurrences of vertex */
| 317 |
for (f = sc->vert[prev].vflist; f != NULL; f = f->v[j].fnext) {
| 318 |
| 319 |
| 320 |
break;
| 321 |
if (j >= f->nv)
| 322 |
goto linkerr;
| 323 |
/* XXX doesn't allow for multiple references to prev in face */
| 324 |
f->v[j].vid = repl; /* replace vertex itself */
| 325 |
if (faceArea(sc, f, NULL) <= FTINY*FTINY)
| 326 |
f->flags |= FACE_DEGENERATE;
| 327 |
if (f->v[j].tid >= 0) /* replace texture if appropriate */
| 328 |
| 329 |
| 330 |
break;
| 331 |
| 332 |
| 333 |
| 334 |
break;
| 335 |
| 336 |
| 337 |
if (f->v[j].nid >= 0) /* replace normal if appropriate */
| 338 |
| 339 |
| 340 |
break;
| 341 |
| 342 |
| 343 |
| 344 |
break;
| 345 |
| 346 |
| 347 |
flast = f;
| 348 |
| 349 |
/* transfer face list */
| 350 |
flast->v[j].fnext = sc->vert[repl].vflist;
| 351 |
sc->vert[repl].vflist = sc->vert[prev].vflist;
| 352 |
sc->vert[prev].vflist = NULL;
| 353 |
return(1);
| 354 |
linkerr:
| 355 |
error(CONSISTENCY, "Link error in replace_vertex()");
| 356 |
return(0); /* shouldn't return */
| 357 |
| 358 |
| 359 |
/* Eliminate duplicate vertices, return # joined */
| 360 |
int
| 361 |
coalesceVertices(Scene *sc, double eps)
| 362 |
| 363 |
int nelim = 0;
| 364 |
LUTAB myLookup;
| 365 |
LUENT *le;
| 366 |
char vertfmt[32], vertbuf[64];
| 367 |
double d;
| 368 |
int i;
| 369 |
| 370 |
if (eps >= 1.)
| 371 |
return(0);
| 372 |
if (sc->nverts <= 3)
| 373 |
return(0);
| 374 |
/* create hash table */
| 375 |
myLookup.hashf = lu_shash;
| 376 |
myLookup.keycmp = (lut_keycmpf_t *)strcmp;
| 377 |
myLookup.freek = (lut_free_t *)freeqstr;
| 378 |
myLookup.freed = NULL;
| 379 |
if (!lu_init(&myLookup, sc->nverts))
| 380 |
return(0);
| 381 |
if (eps <= 5e-15)
| 382 |
strcpy(vertfmt, "%.15e %.15e %.15e");
| 383 |
else {
| 384 |
int nsigdig = 0;
| 385 |
for (d = eps; d < 0.5; d *= 10.)
| 386 |
++nsigdig;
| 387 |
sprintf(vertfmt, "%%.%de %%.%de %%.%de",
| 388 |
nsigdig, nsigdig, nsigdig);
| 389 |
| 390 |
/* find coicident vertices */
| 391 |
for (i = 0; i < sc->nverts; i++) {
| 392 |
if (verbose && !((i+1) & 0x3fff))
| 393 |
fprintf(stderr, "%3d%% complete\r", 100*i/sc->nverts);
| 394 |
/* check for match */
| 395 |
sprintf(vertbuf, vertfmt, sc->vert[i].p[0],
| 396 |
sc->vert[i].p[1], sc->vert[i].p[2]);
| 397 |
le = lu_find(&myLookup, vertbuf);
| 398 |
if (le->data != NULL) { /* coincident vertex */
| 399 |
nelim += replace_vertex(sc, i,
| 400 |
(Vertex *)le->data - sc->vert, eps);
| 401 |
continue;
| 402 |
| 403 |
if (le->key == NULL) /* else create new entry */
| 404 |
le->key = savqstr(vertbuf);
| 405 |
le->data = (char *)&sc->vert[i];
| 406 |
| 407 |
lu_done(&myLookup); /* clean up */
| 408 |
return(nelim);
| 409 |
| 410 |
| 411 |
/* Identify duplicate faces */
| 412 |
int
| 413 |
findDuplicateFaces(Scene *sc)
| 414 |
| 415 |
int nchecked = 0;
| 416 |
int nfound = 0;
| 417 |
Face *f, *f1;
| 418 |
int vid;
| 419 |
int i, j;
| 420 |
/* start fresh */
| 421 |
| 422 |
f->flags &= ~FACE_DUPLICATE;
| 423 |
/* check each face */
| 424 |
for (f = sc->flist; f != NULL; f = f->next) {
| 425 |
nchecked++;
| 426 |
if (verbose && !(nchecked & 0x3fff))
| 427 |
| 428 |
100*nchecked/sc->nfaces);
| 429 |
if (f->flags & FACE_DUPLICATE)
| 430 |
continue; /* already identified */
| 431 |
vid = f->v[0].vid;
| 432 |
/* look for duplicates */
| 433 |
for (f1 = sc->vert[vid].vflist; f1 != NULL;
| 434 |
f1 = f1->v[j].fnext) {
| 435 |
for (j = 0; j < f1->nv; j++)
| 436 |
if (f1->v[j].vid == vid)
| 437 |
break;
| 438 |
if (j >= f1->nv)
| 439 |
break; /* missing link! */
| 440 |
if (f1 == f)
| 441 |
continue; /* shouldn't happen */
| 442 |
if (f1->flags & FACE_DUPLICATE)
| 443 |
continue; /* already marked */
| 444 |
if (f1->nv != f->nv)
| 445 |
continue; /* couldn't be dup. */
| 446 |
for (i = f->nv; --i > 0; )
| 447 |
if (f->v[i].vid != f1->v[(j+i)%f1->nv].vid)
| 448 |
break; /* vertex mismatch */
| 449 |
if (i) {
| 450 |
#if DUP_CHECK_REVERSE /* check reverse direction */
| 451 |
| 452 |
if (f1->v[(j+f1->nv-i)%f1->nv].vid
| 453 |
!= f->v[i].vid)
| 454 |
break;
| 455 |
if (i) /* no match */
| 456 |
#endif
| 457 |
continue;
| 458 |
| 459 |
f1->flags |= FACE_DUPLICATE;
| 460 |
++nfound;
| 461 |
| 462 |
| 463 |
if (verbose)
| 464 |
fprintf(stderr, "Found %d duplicate faces\n", nfound);
| 465 |
return(nfound);
| 466 |
| 467 |
| 468 |
/* Delete indicated faces */
| 469 |
int
| 470 |
deleteFaces(Scene *sc, int flreq, int flexc)
| 471 |
| 472 |
| 473 |
int orig_nfaces = sc->nfaces;
| 474 |
Face fhead;
| 475 |
Face *f, *ftst;
| 476 |
| 477 |
fhead.next = sc->flist;
| 478 |
f = &fhead;
| 479 |
while ((ftst = f->next) != NULL)
| 480 |
if ((ftst->flags & fltest) == flreq) {
| 481 |
Face *vf; /* remove from vertex lists */
| 482 |
int vid, i, j;
| 483 |
for (i = 0; i < ftst->nv; i++) {
| 484 |
vid = ftst->v[i].vid;
| 485 |
vf = sc->vert[vid].vflist;
| 486 |
if (vf == ftst) {
| 487 |
sc->vert[vid].vflist = ftst->v[i].fnext;
| 488 |
continue;
| 489 |
| 490 |
while (vf != NULL) {
| 491 |
for (j = 0; j < vf->nv; j++)
| 492 |
if (vf->v[j].vid == vid)
| 493 |
break;
| 494 |
if (j >= vf->nv)
| 495 |
break; /* error */
| 496 |
if (vf->v[j].fnext == ftst) {
| 497 |
vf->v[j].fnext =
| 498 |
ftst->v[i].fnext;
| 499 |
break;
| 500 |
| 501 |
vf = vf->v[j].fnext;
| 502 |
| 503 |
| 504 |
f->next = ftst->next; /* remove from scene list */
| 505 |
efree((char *)ftst);
| 506 |
sc->nfaces--;
| 507 |
} else
| 508 |
f = f->next;
| 509 |
sc->flist = fhead.next;
| 510 |
return(orig_nfaces - sc->nfaces);
| 511 |
| 512 |
| 513 |
/* Compute face area (and normal) */
| 514 |
double
| 515 |
faceArea(const Scene *sc, const Face *f, Normal nrm)
| 516 |
| 517 |
FVECT fnrm;
| 518 |
double area;
| 519 |
FVECT v1, v2, v3;
| 520 |
double *p0;
| 521 |
int i;
| 522 |
| 523 |
if (f->flags & FACE_DEGENERATE)
| 524 |
return(.0); /* should we check this? */
| 525 |
fnrm[0] = fnrm[1] = fnrm[2] = .0;
| 526 |
p0 = sc->vert[f->v[0].vid].p;
| 527 |
VSUB(v1, sc->vert[f->v[1].vid].p, p0);
| 528 |
for (i = 2; i < f->nv; i++) {
| 529 |
VSUB(v2, sc->vert[f->v[i].vid].p, p0);
| 530 |
fcross(v3, v1, v2);
| 531 |
VADD(fnrm, fnrm, v3);
| 532 |
VCOPY(v1, v2);
| 533 |
| 534 |
area = 0.5*normalize(fnrm);
| 535 |
if (nrm != NULL) {
| 536 |
if (area != 0.)
| 537 |
VCOPY(nrm, fnrm);
| 538 |
else
| 539 |
nrm[0] = nrm[1] = nrm[2] = 0.;
| 540 |
| 541 |
return(area);
| 542 |
| 543 |
| 544 |
/* Add a descriptive comment */
| 545 |
void
| 546 |
addComment(Scene *sc, const char *comment)
| 547 |
| 548 |
sc->descr = chunk_alloc(char *, sc->descr, sc->ndescr);
| 549 |
sc->descr[sc->ndescr++] = savqstr((char *)comment);
| 550 |
| 551 |
| 552 |
/* Find index for comment containing the given string (starting from n) */
| 553 |
int
| 554 |
findComment(Scene *sc, const char *match, int n)
| 555 |
| 556 |
if (n >= sc->ndescr)
| 557 |
return(-1);
| 558 |
n *= (n > 0);
| 559 |
while (n < sc->ndescr)
| 560 |
if (strstr(sc->descr[n], match) != NULL)
| 561 |
return(n);
| 562 |
return(-1);
| 563 |
| 564 |
| 565 |
/* Clear comments */
| 566 |
void
| 567 |
clearComments(Scene *sc)
| 568 |
| 569 |
while (sc->ndescr > 0)
| 570 |
freeqstr(sc->descr[--sc->ndescr]);
| 571 |
efree((char *)sc->descr);
| 572 |
sc->ndescr = 0;
| 573 |
| 574 |
| 575 |
/* Add a face to a vertex face list */
| 576 |
static void
| 577 |
add2facelist(Scene *sc, Face *f, int i)
| 578 |
| 579 |
int vid = f->v[i].vid;
| 580 |
Face *fp = sc->vert[vid].vflist;
| 581 |
int j;
| 582 |
| 583 |
f->v[i].fnext = NULL; /* will put at end */
| 584 |
if (fp == NULL) { /* new list */
| 585 |
sc->vert[vid].vflist = f;
| 586 |
return;
| 587 |
| 588 |
for ( ; ; ) { /* else find position */
| 589 |
if (fp == f)
| 590 |
return; /* already in list */
| 591 |
for (j = 0; j < fp->nv; j++)
| 592 |
if (fp->v[j].vid == vid)
| 593 |
break;
| 594 |
if (j >= fp->nv)
| 595 |
error(CONSISTENCY, "Link error in add2facelist()");
| 596 |
if (fp->v[j].fnext == NULL)
| 597 |
break; /* reached the end */
| 598 |
fp = fp->v[j].fnext;
| 599 |
| 600 |
fp->v[j].fnext = f; /* append new face */
| 601 |
| 602 |
| 603 |
/* Allocate an empty scene */
| 604 |
Scene *
| 605 |
newScene(void)
| 606 |
| 607 |
Scene *sc = (Scene *)ecalloc(1, sizeof(Scene));
| 608 |
/* default group & material */
| 609 |
| 610 |
sc->grpname[sc->ngrps++] = savqstr("DEFAULT_GROUP");
| 611 |
| 612 |
sc->matname[sc->nmats++] = savqstr("DEFAULT_MATERIAL");
| 613 |
| 614 |
return(sc);
| 615 |
| 616 |
| 617 |
/* Add a vertex to a scene */
| 618 |
int
| 619 |
addVertex(Scene *sc, double x, double y, double z)
| 620 |
| 621 |
sc->vert = chunk_alloc(Vertex, sc->vert, sc->nverts);
| 622 |
sc->vert[sc->nverts].p[0] = x;
| 623 |
sc->vert[sc->nverts].p[1] = y;
| 624 |
sc->vert[sc->nverts].p[2] = z;
| 625 |
sc->vert[sc->nverts].vflist = NULL;
| 626 |
return(sc->nverts++);
| 627 |
| 628 |
| 629 |
/* Add a texture coordinate to a scene */
| 630 |
int
| 631 |
addTexture(Scene *sc, double u, double v)
| 632 |
| 633 |
sc->tex = chunk_alloc(TexCoord, sc->tex, sc->ntex);
| 634 |
sc->tex[sc->ntex].u = u;
| 635 |
sc->tex[sc->ntex].v = v;
| 636 |
return(sc->ntex++);
| 637 |
| 638 |
| 639 |
/* Add a surface normal to a scene */
| 640 |
int
| 641 |
addNormal(Scene *sc, double xn, double yn, double zn)
| 642 |
| 643 |
FVECT nrm;
| 644 |
| 645 |
nrm[0] = xn; nrm[1] = yn; nrm[2] = zn;
| 646 |
if (normalize(nrm) == .0)
| 647 |
return(-1);
| 648 |
sc->norm = chunk_alloc(Normal, sc->norm, sc->nnorms);
| 649 |
VCOPY(sc->norm[sc->nnorms], nrm);
| 650 |
return(sc->nnorms++);
| 651 |
| 652 |
| 653 |
/* Set current (last) group */
| 654 |
void
| 655 |
setGroup(Scene *sc, const char *nm)
| 656 |
| 657 |
sc->lastgrp = findName(nm, (const char **)sc->grpname, sc->ngrps);
| 658 |
if (sc->lastgrp >= 0)
| 659 |
return;
| 660 |
| 661 |
sc->grpname[sc->lastgrp=sc->ngrps++] = savqstr((char *)nm);
| 662 |
| 663 |
| 664 |
/* Set current (last) material */
| 665 |
void
| 666 |
setMaterial(Scene *sc, const char *nm)
| 667 |
| 668 |
sc->lastmat = findName(nm, (const char **)sc->matname, sc->nmats);
| 669 |
if (sc->lastmat >= 0)
| 670 |
return;
| 671 |
| 672 |
sc->matname[sc->lastmat=sc->nmats++] = savqstr((char *)nm);
| 673 |
| 674 |
| 675 |
/* Add new face to a scene */
| 676 |
Face *
| 677 |
addFace(Scene *sc, VNDX vid[], int nv)
| 678 |
| 679 |
Face *f;
| 680 |
int i;
| 681 |
| 682 |
if (nv < 3)
| 683 |
return(NULL);
| 684 |
f = (Face *)emalloc(sizeof(Face)+sizeof(VertEnt)*(nv-3));
| 685 |
f->flags = 0;
| 686 |
f->nv = nv;
| 687 |
f->grp = sc->lastgrp;
| 688 |
f->mat = sc->lastmat;
| 689 |
for (i = 0; i < nv; i++) { /* add each vertex */
| 690 |
int j;
| 691 |
f->v[i].vid = vid[i][0];
| 692 |
f->v[i].tid = vid[i][1];
| 693 |
f->v[i].nid = vid[i][2];
| 694 |
| 695 |
for (j = i; j-- > 0; )
| 696 |
if (f->v[j].vid == vid[i][0])
| 697 |
break;
| 698 |
if (j < 0) { /* first occurrence? */
| 699 |
f->v[i].fnext = sc->vert[vid[i][0]].vflist;
| 700 |
sc->vert[vid[i][0]].vflist = f;
| 701 |
} else if (nv == 3) /* degenerate triangle? */
| 702 |
| 703 |
| 704 |
f->next = sc->flist; /* push onto face list */
| 705 |
sc->flist = f;
| 706 |
sc->nfaces++;
| 707 |
/* check face area */
| 708 |
if (!(f->flags & FACE_DEGENERATE) && faceArea(sc, f, NULL) <= FTINY*FTINY)
| 709 |
| 710 |
return(f);
| 711 |
| 712 |
| 713 |
/* Duplicate a scene, optionally selecting faces */
| 714 |
Scene *
| 715 |
dupScene(const Scene *osc, int flreq, int flexc)
| 716 |
| 717 |
| 718 |
Scene *sc;
| 719 |
const Face *fo;
| 720 |
Face *f;
| 721 |
int i;
| 722 |
| 723 |
if (osc == NULL)
| 724 |
return(NULL);
| 725 |
sc = newScene();
| 726 |
for (i = 0; i < osc->ndescr; i++)
| 727 |
addComment(sc, osc->descr[i]);
| 728 |
if (osc->ngrps) {
| 729 |
sc->grpname = (char **)emalloc(sizeof(char *) *
| 730 |
(osc->ngrps+(CHUNKSIZ-1)));
| 731 |
for (i = 0; i < osc->ngrps; i++)
| 732 |
sc->grpname[i] = savqstr(osc->grpname[i]);
| 733 |
sc->ngrps = osc->ngrps;
| 734 |
| 735 |
if (osc->nmats) {
| 736 |
sc->matname = (char **)emalloc(sizeof(char *) *
| 737 |
(osc->nmats+(CHUNKSIZ-1)));
| 738 |
for (i = 0; i < osc->nmats; i++)
| 739 |
sc->matname[i] = savqstr(osc->matname[i]);
| 740 |
sc->nmats = osc->nmats;
| 741 |
| 742 |
if (osc->nverts) {
| 743 |
sc->vert = (Vertex *)emalloc(sizeof(Vertex) *
| 744 |
(osc->nverts+(CHUNKSIZ-1)));
| 745 |
memcpy((void *)sc->vert, (const void *)osc->vert,
| 746 |
sizeof(Vertex)*osc->nverts);
| 747 |
sc->nverts = osc->nverts;
| 748 |
| 749 |
sc->vert[i].vflist = NULL;
| 750 |
| 751 |
if (osc->ntex) {
| 752 |
sc->tex = (TexCoord *)emalloc(sizeof(TexCoord) *
| 753 |
(osc->ntex+(CHUNKSIZ-1)));
| 754 |
memcpy((void *)sc->tex, (const void *)osc->tex,
| 755 |
sizeof(TexCoord)*osc->ntex);
| 756 |
sc->ntex = osc->ntex;
| 757 |
| 758 |
if (osc->nnorms) {
| 759 |
sc->norm = (Normal *)emalloc(sizeof(Normal) *
| 760 |
(osc->nnorms+CHUNKSIZ));
| 761 |
memcpy((void *)sc->norm, (const void *)osc->norm,
| 762 |
sizeof(Normal)*osc->nnorms);
| 763 |
sc->nnorms = osc->nnorms;
| 764 |
| 765 |
for (fo = osc->flist; fo != NULL; fo = fo->next) {
| 766 |
if ((fo->flags & fltest) != flreq)
| 767 |
continue;
| 768 |
f = (Face *)emalloc(sizeof(Face) +
| 769 |
sizeof(VertEnt)*(fo->nv-3));
| 770 |
memcpy((void *)f, (const void *)fo, sizeof(Face) +
| 771 |
| 772 |
for (i = 0; i < f->nv; i++)
| 773 |
add2facelist(sc, f, i);
| 774 |
| 775 |
sc->flist = f;
| 776 |
sc->nfaces++;
| 777 |
| 778 |
deleteUnreferenced(sc); /* jetsam */
| 779 |
return(sc);
| 780 |
| 781 |
| 782 |
#define MAXAC 100
| 783 |
| 784 |
/* Transform entire scene */
| 785 |
int
| 786 |
xfScene(Scene *sc, int xac, char *xav[])
| 787 |
| 788 |
char comm[24+MAXAC*8];
| 789 |
char *cp;
| 790 |
XF myxf;
| 791 |
FVECT vec;
| 792 |
int i;
| 793 |
| 794 |
if ((sc == NULL) | (xac <= 0) | (xav == NULL))
| 795 |
return(0);
| 796 |
/* compute matrix */
| 797 |
if (xf(&myxf, xac, xav) < xac)
| 798 |
return(0);
| 799 |
/* transform vertices */
| 800 |
| 801 |
VCOPY(vec, sc->vert[i].p);
| 802 |
multp3(vec, vec, myxf.xfm);
| 803 |
VCOPY(sc->vert[i].p, vec);
| 804 |
| 805 |
/* transform normals */
| 806 |
for (i = 0; i < sc->nnorms; i++) {
| 807 |
VCOPY(vec, sc->norm[i]);
| 808 |
multv3(vec, vec, myxf.xfm);
| 809 |
vec[0] /= myxf.sca; vec[1] /= myxf.sca; vec[2] /= myxf.sca;
| 810 |
VCOPY(sc->norm[i], vec);
| 811 |
| 812 |
/* add comment */
| 813 |
cp = strcpy(comm, "Transformed by:");
| 814 |
for (i = 0; i < xac; i++) {
| 815 |
while (*cp) cp++;
| 816 |
*cp++ = ' ';
| 817 |
strcpy(cp, xav[i]);
| 818 |
| 819 |
addComment(sc, comm);
| 820 |
return(xac); /* all done */
| 821 |
| 822 |
| 823 |
/* Ditto, using transform string rather than pre-parsed words */
| 824 |
int
| 825 |
xfmScene(Scene *sc, const char *xfm)
| 826 |
| 827 |
char *xav[MAXAC+1];
| 828 |
int xac, i;
| 829 |
| 830 |
if ((sc == NULL) | (xfm == NULL))
| 831 |
return(0);
| 832 |
/* skip spaces at beginning */
| 833 |
while (isspace(*xfm))
| 834 |
xfm++;
| 835 |
if (!*xfm)
| 836 |
return(0);
| 837 |
/* parse string into words */
| 838 |
xav[0] = strcpy((char *)malloc(strlen(xfm)+1), xfm);
| 839 |
xac = 1; i = 0;
| 840 |
for ( ; ; ) {
| 841 |
while (!isspace(xfm[++i]))
| 842 |
if (!xfm[i])
| 843 |
break;
| 844 |
while (isspace(xfm[i]))
| 845 |
xav[0][i++] = '\0';
| 846 |
if (!xfm[i])
| 847 |
break;
| 848 |
if (xac >= MAXAC-1) {
| 849 |
free(xav[0]);
| 850 |
return(0);
| 851 |
| 852 |
xav[xac++] = xav[0] + i;
| 853 |
| 854 |
xav[xac] = NULL;
| 855 |
i = xfScene(sc, xac, xav);
| 856 |
free(xav[0]);
| 857 |
return(i);
| 858 |
| 859 |
#undef MAXAC
| 860 |
| 861 |
/* Delete unreferenced vertices, normals, texture coords */
| 862 |
void
| 863 |
deleteUnreferenced(Scene *sc)
| 864 |
| 865 |
int *vmap;
| 866 |
Face *f;
| 867 |
int nused, i;
| 868 |
/* allocate index map */
| 869 |
if (!sc->nverts)
| 870 |
return;
| 871 |
i = sc->nverts;
| 872 |
if (sc->ntex > i)
| 873 |
i = sc->ntex;
| 874 |
if (sc->nnorms > i)
| 875 |
i = sc->nnorms;
| 876 |
vmap = (int *)emalloc(sizeof(int)*i);
| 877 |
/* remap positions */
| 878 |
for (i = nused = 0; i < sc->nverts; i++) {
| 879 |
if (sc->vert[i].vflist == NULL) {
| 880 |
vmap[i] = -1;
| 881 |
continue;
| 882 |
| 883 |
if (nused != i)
| 884 |
sc->vert[nused] = sc->vert[i];
| 885 |
vmap[i] = nused++;
| 886 |
| 887 |
if (nused == sc->nverts)
| 888 |
goto skip_pos;
| 889 |
sc->vert = (Vertex *)erealloc((char *)sc->vert,
| 890 |
sizeof(Vertex)*(nused+(CHUNKSIZ-1)));
| 891 |
sc->nverts = nused;
| 892 |
| 893 |
for (i = f->nv; i--; )
| 894 |
if ((f->v[i].vid = vmap[f->v[i].vid]) < 0)
| 895 |
error(CONSISTENCY,
| 896 |
"Link error in del_unref_verts()");
| 897 |
skip_pos:
| 898 |
/* remap texture coord's */
| 899 |
if (!sc->ntex)
| 900 |
goto skip_tex;
| 901 |
memset((void *)vmap, 0, sizeof(int)*sc->ntex);
| 902 |
| 903 |
| 904 |
if (f->v[i].tid >= 0)
| 905 |
vmap[f->v[i].tid] = 1;
| 906 |
for (i = nused = 0; i < sc->ntex; i++) {
| 907 |
if (!vmap[i])
| 908 |
continue;
| 909 |
if (nused != i)
| 910 |
sc->tex[nused] = sc->tex[i];
| 911 |
vmap[i] = nused++;
| 912 |
| 913 |
if (nused == sc->ntex)
| 914 |
goto skip_tex;
| 915 |
sc->tex = (TexCoord *)erealloc((char *)sc->tex,
| 916 |
sizeof(TexCoord)*(nused+(CHUNKSIZ-1)));
| 917 |
sc->ntex = nused;
| 918 |
| 919 |
| 920 |
| 921 |
f->v[i].tid = vmap[f->v[i].tid];
| 922 |
skip_tex:
| 923 |
/* remap normals */
| 924 |
if (!sc->nnorms)
| 925 |
goto skip_norms;
| 926 |
memset((void *)vmap, 0, sizeof(int)*sc->nnorms);
| 927 |
| 928 |
| 929 |
if (f->v[i].nid >= 0)
| 930 |
vmap[f->v[i].nid] = 1;
| 931 |
for (i = nused = 0; i < sc->nnorms; i++) {
| 932 |
if (!vmap[i])
| 933 |
continue;
| 934 |
if (nused != i)
| 935 |
memcpy((void *)sc->norm[nused],
| 936 |
(void *)sc->norm[i],
| 937 |
sizeof(Normal));
| 938 |
vmap[i] = nused++;
| 939 |
| 940 |
if (nused == sc->nnorms)
| 941 |
goto skip_norms;
| 942 |
sc->norm = (Normal *)erealloc((char *)sc->norm,
| 943 |
sizeof(Normal)*(nused+(CHUNKSIZ-1)));
| 944 |
sc->nnorms = nused;
| 945 |
| 946 |
| 947 |
| 948 |
f->v[i].nid = vmap[f->v[i].nid];
| 949 |
skip_norms:
| 950 |
/* clean up */
| 951 |
efree((char *)vmap);
| 952 |
| 953 |
| 954 |
/* Free a scene */
| 955 |
void
| 956 |
freeScene(Scene *sc)
| 957 |
| 958 |
int i;
| 959 |
Face *f;
| 960 |
| 961 |
if (sc == NULL)
| 962 |
return;
| 963 |
clearComments(sc);
| 964 |
for (i = sc->ngrps; i-- > 0; )
| 965 |
freeqstr(sc->grpname[i]);
| 966 |
efree((char *)sc->grpname);
| 967 |
for (i = sc->nmats; i-- > 0; )
| 968 |
freeqstr(sc->matname[i]);
| 969 |
efree((char *)sc->matname);
| 970 |
efree((char *)sc->vert);
| 971 |
efree((char *)sc->tex);
| 972 |
efree((char *)sc->norm);
| 973 |
while ((f = sc->flist) != NULL) {
| 974 |
sc->flist = f->next;
| 975 |
efree((char *)f);
| 976 |
| 977 |
efree((char *)sc);
| 978 |
