--- ray/src/common/objutil.c 2020/04/02 20:44:15 2.2 +++ ray/src/common/objutil.c 2021/04/07 16:40:28 2.16 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: objutil.c,v 2.2 2020/04/02 20:44:15 greg Exp $"; +static const char RCSid[] = "$Id: objutil.c,v 2.16 2021/04/07 16:40:28 greg Exp $"; #endif /* * Basic .OBJ scene handling routines. @@ -19,7 +19,7 @@ static const char RCSid[] = "$Id: objutil.c,v 2.2 2020 int findName(const char *nm, const char **nmlist, int n) { - register int i; + int i; for (i = n; i-- > 0; ) if (!strcmp(nmlist[i], nm)) @@ -31,7 +31,7 @@ findName(const char *nm, const char **nmlist, int n) void clearSelection(Scene *sc, int set) { - Face *f; + Face *f; for (f = sc->flist; f != NULL; f = f->next) if (set) @@ -44,8 +44,8 @@ clearSelection(Scene *sc, int set) void selectGroup(Scene *sc, const char *gname, int invert) { - int gid = findName(gname, (const char **)sc->grpname, sc->ngrps); - Face *f; + int gid = getGroupID(sc, gname); + Face *f; if (gid < 0) return; @@ -62,8 +62,8 @@ selectGroup(Scene *sc, const char *gname, int invert) void selectMaterial(Scene *sc, const char *mname, int invert) { - int mid = findName(mname, (const char **)sc->matname, sc->nmats); - Face *f; + int mid = getMaterialID(sc, mname); + Face *f; if (mid < 0) return; @@ -80,7 +80,7 @@ selectMaterial(Scene *sc, const char *mname, int inver void invertSelection(Scene *sc) { - Face *f; + Face *f; for (f = sc->flist; f != NULL; f = f->next) f->flags ^= FACE_SELECTED; @@ -90,8 +90,8 @@ invertSelection(Scene *sc) int numberSelected(Scene *sc) { - int nsel = 0; - Face *f; + int nsel = 0; + Face *f; for (f = sc->flist; f != NULL; f = f->next) nsel += ((f->flags & FACE_SELECTED) != 0); @@ -103,9 +103,9 @@ int foreachFace(Scene *sc, int (*cb)(Scene *, Face *, void *), int flreq, int flexc, void *c_data) { - int fltest = flreq | flexc; - int sum = 0; - Face *f; + const int fltest = flreq | flexc; + int sum = 0; + Face *f; if ((sc == NULL) | (cb == NULL)) return(0); @@ -123,8 +123,8 @@ foreachFace(Scene *sc, int (*cb)(Scene *, Face *, void static int remFaceTexture(Scene *sc, Face *f, void *dummy) { - int hadTexture = 0; - int i; + int hadTexture = 0; + int i; for (i = f->nv; i-- > 0; ) { if (f->v[i].tid < 0) @@ -146,8 +146,8 @@ removeTexture(Scene *sc, int flreq, int flexc) static int remFaceNormal(Scene *sc, Face *f, void *dummy) { - int hadNormal = 0; - int i; + int hadNormal = 0; + int i; for (i = f->nv; i-- > 0; ) { if (f->v[i].nid < 0) @@ -169,7 +169,8 @@ removeNormals(Scene *sc, int flreq, int flexc) static int chngFaceGroup(Scene *sc, Face *f, void *ptr) { - int grp = *(int *)ptr; + int grp = *(int *)ptr; + if (f->grp == grp) return(0); f->grp = grp; @@ -180,7 +181,8 @@ chngFaceGroup(Scene *sc, Face *f, void *ptr) int changeGroup(Scene *sc, const char *gname, int flreq, int flexc) { - int grp = findName(gname, (const char **)sc->grpname, sc->ngrps); + int grp = getGroupID(sc, gname); + if (grp < 0) { sc->grpname = chunk_alloc(char *, sc->grpname, sc->ngrps); sc->grpname[grp=sc->ngrps++] = savqstr((char *)gname); @@ -192,7 +194,8 @@ changeGroup(Scene *sc, const char *gname, int flreq, i static int chngFaceMaterial(Scene *sc, Face *f, void *ptr) { - int mat = *(int *)ptr; + int mat = *(int *)ptr; + if (f->mat == mat) return(0); f->mat = mat; @@ -203,7 +206,8 @@ chngFaceMaterial(Scene *sc, Face *f, void *ptr) int changeMaterial(Scene *sc, const char *mname, int flreq, int flexc) { - int mat = findName(mname, (const char **)sc->matname, sc->nmats); + int mat = getMaterialID(sc, mname); + if (mat < 0) { sc->matname = chunk_alloc(char *, sc->matname, sc->nmats); sc->matname[mat=sc->nmats++] = savqstr((char *)mname); @@ -248,10 +252,10 @@ norm_diff(const Normal n1, const Normal n2, double eps static int replace_vertex(Scene *sc, int prev, int repl, double eps) { - int repl_tex[10]; - int repl_norm[10]; - Face *f, *flast=NULL; - int i, j=0; + int repl_tex[10]; + int repl_norm[10]; + Face *f, *flast=NULL; + int i, j=0; /* check to see if it's even used */ if (sc->vert[prev].vflist == NULL) return(0); @@ -259,13 +263,13 @@ replace_vertex(Scene *sc, int prev, int repl, double e repl_tex[0] = -1; for (f = sc->vert[repl].vflist; f != NULL; f = f->v[j].fnext) { /* make sure prev isn't in there */ - for (j = 0; j < f->nv; j++) + for (j = f->nv; j-- > 0; ) if (f->v[j].vid == prev) return(0); - for (j = 0; j < f->nv; j++) + for (j = f->nv; j-- > 0; ) if (f->v[j].vid == repl) break; - if (j >= f->nv) + if (j < 0) goto linkerr; if (f->v[j].tid < 0) continue; @@ -290,7 +294,7 @@ replace_vertex(Scene *sc, int prev, int repl, double e /* get replacement normals */ repl_norm[0] = -1; for (f = sc->vert[repl].vflist; f != NULL; f = f->v[j].fnext) { - for (j = 0; j < f->nv; j++) + for (j = f->nv; j-- > 0; ) if (f->v[j].vid == repl) break; if (f->v[j].nid < 0) @@ -315,14 +319,14 @@ replace_vertex(Scene *sc, int prev, int repl, double e } /* replace occurrences of vertex */ for (f = sc->vert[prev].vflist; f != NULL; f = f->v[j].fnext) { - for (j = 0; j < f->nv; j++) + for (j = f->nv; j-- > 0; ) if (f->v[j].vid == prev) break; - if (j >= f->nv) + if (j < 0) goto linkerr; /* XXX doesn't allow for multiple references to prev in face */ f->v[j].vid = repl; /* replace vertex itself */ - if (faceArea(sc, f, NULL) <= FTINY) + if (faceArea(sc, f, NULL) <= FTINY*FTINY) f->flags |= FACE_DEGENERATE; if (f->v[j].tid >= 0) /* replace texture if appropriate */ for (i = 0; repl_tex[i] >= 0; i++) { @@ -360,12 +364,12 @@ linkerr: int coalesceVertices(Scene *sc, double eps) { - int nelim = 0; - LUTAB myLookup; - LUENT *le; - char vertfmt[32], vertbuf[64]; - double d; - int i; + int nelim = 0; + LUTAB myLookup; + LUENT *le; + char vertfmt[32], vertbuf[64]; + double d; + int i; if (eps >= 1.) return(0); @@ -412,11 +416,11 @@ coalesceVertices(Scene *sc, double eps) int findDuplicateFaces(Scene *sc) { - int nchecked = 0; - int nfound = 0; - Face *f, *f1; - int vid; - int i, j; + int nchecked = 0; + int nfound = 0; + Face *f, *f1; + int vid; + int i, j; /* start fresh */ for (f = sc->flist; f != NULL; f = f->next) f->flags &= ~FACE_DUPLICATE; @@ -432,10 +436,10 @@ findDuplicateFaces(Scene *sc) /* look for duplicates */ for (f1 = sc->vert[vid].vflist; f1 != NULL; f1 = f1->v[j].fnext) { - for (j = 0; j < f1->nv; j++) + for (j = f1->nv; j-- > 0; ) if (f1->v[j].vid == vid) break; - if (j >= f1->nv) + if (j < 0) break; /* missing link! */ if (f1 == f) continue; /* shouldn't happen */ @@ -460,6 +464,8 @@ findDuplicateFaces(Scene *sc) ++nfound; } } + if (verbose) + fprintf(stderr, "Found %d duplicate faces\n", nfound); return(nfound); } @@ -467,10 +473,10 @@ findDuplicateFaces(Scene *sc) int deleteFaces(Scene *sc, int flreq, int flexc) { - int fltest = flreq | flexc; - int orig_nfaces = sc->nfaces; - Face fhead; - Face *f, *ftst; + const int fltest = flreq | flexc; + int orig_nfaces = sc->nfaces; + Face fhead; + Face *f, *ftst; fhead.next = sc->flist; f = &fhead; @@ -486,10 +492,10 @@ deleteFaces(Scene *sc, int flreq, int flexc) continue; } while (vf != NULL) { - for (j = 0; j < vf->nv; j++) + for (j = vf->nv; j-- > 0; ) if (vf->v[j].vid == vid) break; - if (j >= vf->nv) + if (j < 0) break; /* error */ if (vf->v[j].fnext == ftst) { vf->v[j].fnext = @@ -547,6 +553,19 @@ addComment(Scene *sc, const char *comment) sc->descr[sc->ndescr++] = savqstr((char *)comment); } +/* Find index for comment containing the given string (starting from n) */ +int +findComment(Scene *sc, const char *match, int n) +{ + if (n >= sc->ndescr) + return(-1); + n *= (n > 0); + while (n < sc->ndescr) + if (strstr(sc->descr[n], match) != NULL) + return(n); + return(-1); +} + /* Clear comments */ void clearComments(Scene *sc) @@ -573,10 +592,10 @@ add2facelist(Scene *sc, Face *f, int i) for ( ; ; ) { /* else find position */ if (fp == f) return; /* already in list */ - for (j = 0; j < fp->nv; j++) + for (j = fp->nv; j-- > 0; ) if (fp->v[j].vid == vid) break; - if (j >= fp->nv) + if (j < 0) error(CONSISTENCY, "Link error in add2facelist()"); if (fp->v[j].fnext == NULL) break; /* reached the end */ @@ -585,11 +604,107 @@ add2facelist(Scene *sc, Face *f, int i) fp->v[j].fnext = f; /* append new face */ } +/* Add a vertex to a scene */ +int +addVertex(Scene *sc, double x, double y, double z) +{ + sc->vert = chunk_alloc(Vertex, sc->vert, sc->nverts); + sc->vert[sc->nverts].p[0] = x; + sc->vert[sc->nverts].p[1] = y; + sc->vert[sc->nverts].p[2] = z; + sc->vert[sc->nverts].vflist = NULL; + return(sc->nverts++); +} + +/* Add a texture coordinate to a scene */ +int +addTexture(Scene *sc, double u, double v) +{ + sc->tex = chunk_alloc(TexCoord, sc->tex, sc->ntex); + sc->tex[sc->ntex].u = u; + sc->tex[sc->ntex].v = v; + return(sc->ntex++); +} + +/* Add a surface normal to a scene */ +int +addNormal(Scene *sc, double xn, double yn, double zn) +{ + FVECT nrm; + + nrm[0] = xn; nrm[1] = yn; nrm[2] = zn; + if (normalize(nrm) == .0) + return(-1); + sc->norm = chunk_alloc(Normal, sc->norm, sc->nnorms); + VCOPY(sc->norm[sc->nnorms], nrm); + return(sc->nnorms++); +} + +/* Set current (last) group */ +void +setGroup(Scene *sc, const char *nm) +{ + sc->lastgrp = getGroupID(sc, nm); + if (sc->lastgrp >= 0) + return; + sc->grpname = chunk_alloc(char *, sc->grpname, sc->ngrps); + sc->grpname[sc->lastgrp=sc->ngrps++] = savqstr((char *)nm); +} + +/* Set current (last) material */ +void +setMaterial(Scene *sc, const char *nm) +{ + sc->lastmat = getMaterialID(sc, nm); + if (sc->lastmat >= 0) + return; + sc->matname = chunk_alloc(char *, sc->matname, sc->nmats); + sc->matname[sc->lastmat=sc->nmats++] = savqstr((char *)nm); +} + +/* Add new face to a scene */ +Face * +addFace(Scene *sc, VNDX vid[], int nv) +{ + Face *f; + int i; + + if (nv < 3) + return(NULL); + f = (Face *)emalloc(sizeof(Face)+sizeof(VertEnt)*(nv-3)); + f->flags = 0; + f->nv = nv; + f->grp = sc->lastgrp; + f->mat = sc->lastmat; + for (i = 0; i < nv; i++) { /* add each vertex */ + int j; + f->v[i].vid = vid[i][0]; + f->v[i].tid = vid[i][1]; + f->v[i].nid = vid[i][2]; + f->v[i].fnext = NULL; + for (j = i; j-- > 0; ) + if (f->v[j].vid == vid[i][0]) + break; + if (j < 0) { /* first occurrence? */ + f->v[i].fnext = sc->vert[vid[i][0]].vflist; + sc->vert[vid[i][0]].vflist = f; + } else if (nv == 3) /* degenerate triangle? */ + f->flags |= FACE_DEGENERATE; + } + f->next = sc->flist; /* push onto face list */ + sc->flist = f; + sc->nfaces++; + /* check face area */ + if (!(f->flags & FACE_DEGENERATE) && faceArea(sc, f, NULL) <= FTINY*FTINY) + f->flags |= FACE_DEGENERATE; + return(f); +} + /* Allocate an empty scene */ Scene * newScene(void) { - Scene *sc = (Scene *)ecalloc(1, sizeof(Scene)); + Scene *sc = (Scene *)ecalloc(1, sizeof(Scene)); /* default group & material */ sc->grpname = chunk_alloc(char *, sc->grpname, sc->ngrps); sc->grpname[sc->ngrps++] = savqstr("DEFAULT_GROUP"); @@ -599,10 +714,11 @@ newScene(void) return(sc); } -/* Duplicate a scene */ +/* Duplicate a scene, optionally selecting faces */ Scene * -dupScene(const Scene *osc) +dupScene(const Scene *osc, int flreq, int flexc) { + int fltest = flreq | flexc; Scene *sc; const Face *fo; Face *f; @@ -613,25 +729,24 @@ dupScene(const Scene *osc) sc = newScene(); for (i = 0; i < osc->ndescr; i++) addComment(sc, osc->descr[i]); - if (osc->ngrps) { - sc->grpname = (char **)emalloc(sizeof(char *) * - (osc->ngrps+(CHUNKSIZ-1))); - for (i = 0; i < osc->ngrps; i++) + if (osc->ngrps > 1) { + sc->grpname = (char **)erealloc((char *)sc->grpname, + sizeof(char *) * (osc->ngrps+(CHUNKSIZ-1))); + for (i = 1; i < osc->ngrps; i++) sc->grpname[i] = savqstr(osc->grpname[i]); sc->ngrps = osc->ngrps; } - if (osc->nmats) { - sc->matname = (char **)emalloc(sizeof(char *) * - (osc->nmats+(CHUNKSIZ-1))); - for (i = 0; i < osc->nmats; i++) + if (osc->nmats > 1) { + sc->matname = (char **)erealloc((char *)sc->matname, + sizeof(char *) * (osc->nmats+(CHUNKSIZ-1))); + for (i = 1; i < osc->nmats; i++) sc->matname[i] = savqstr(osc->matname[i]); sc->nmats = osc->nmats; } if (osc->nverts) { sc->vert = (Vertex *)emalloc(sizeof(Vertex) * (osc->nverts+(CHUNKSIZ-1))); - memcpy((void *)sc->vert, (const void *)osc->vert, - sizeof(Vertex)*osc->nverts); + memcpy(sc->vert, osc->vert, sizeof(Vertex)*osc->nverts); sc->nverts = osc->nverts; for (i = 0; i < sc->nverts; i++) sc->vert[i].vflist = NULL; @@ -639,49 +754,163 @@ dupScene(const Scene *osc) if (osc->ntex) { sc->tex = (TexCoord *)emalloc(sizeof(TexCoord) * (osc->ntex+(CHUNKSIZ-1))); - memcpy((void *)sc->tex, (const void *)osc->tex, - sizeof(TexCoord)*osc->ntex); + memcpy(sc->tex, osc->tex, sizeof(TexCoord)*osc->ntex); sc->ntex = osc->ntex; } if (osc->nnorms) { sc->norm = (Normal *)emalloc(sizeof(Normal) * (osc->nnorms+CHUNKSIZ)); - memcpy((void *)sc->norm, (const void *)osc->norm, - sizeof(Normal)*osc->nnorms); + memcpy(sc->norm, osc->norm, sizeof(Normal)*osc->nnorms); sc->nnorms = osc->nnorms; } for (fo = osc->flist; fo != NULL; fo = fo->next) { - f = (Face *)emalloc(sizeof(Face) + - sizeof(VertEnt)*(fo->nv-3)); - memcpy((void *)f, (const void *)fo, sizeof(Face) + - sizeof(VertEnt)*(fo->nv-3)); + if ((fo->flags & fltest) != flreq) + continue; + f = (Face *)emalloc(sizeof(Face) + sizeof(VertEnt)*(fo->nv-3)); + memcpy(f, fo, sizeof(Face) + sizeof(VertEnt)*(fo->nv-3)); for (i = 0; i < f->nv; i++) add2facelist(sc, f, i); f->next = sc->flist; sc->flist = f; sc->nfaces++; } + deleteUnreferenced(sc); /* jetsam */ return(sc); } -/* Transform entire scene */ +/* Add one scene to another, not checking for redundancies */ +int +addScene(Scene *scdst, const Scene *scsrc) +{ + VNDX my_vlist[4]; + int *vert_map = NULL; + int tex_off = 0; + int norm_off = 0; + VNDX *vlist = my_vlist; + int vllen = sizeof(my_vlist)/sizeof(VNDX); + int cur_mat = 0; + int cur_grp = 0; + int fcnt = 0; + const Face *f; + int i; + + if ((scdst == NULL) | (scsrc == NULL)) + return(-1); + if (scsrc->nfaces <= 0) + return(0); + /* map vertices */ + vert_map = (int *)emalloc(sizeof(int *)*scsrc->nverts); + for (i = 0; i < scsrc->nverts; i++) { + const Vertex *v = scsrc->vert + i; + if (v->vflist == NULL) { + vert_map[i] = -1; + continue; + } + vert_map[i] = addVertex(scdst, v->p[0], v->p[1], v->p[2]); + } + tex_off = scdst->ntex; /* append texture coords */ + if (scsrc->ntex > 0) { + scdst->tex = (TexCoord *)erealloc((char *)scdst->tex, + sizeof(TexCoord)*(tex_off+scsrc->ntex+(CHUNKSIZ-1))); + memcpy(scdst->tex+tex_off, scsrc->tex, + sizeof(TexCoord)*scsrc->ntex); + } + norm_off = scdst->nnorms; /* append normals */ + if (scsrc->nnorms > 0) { + scdst->norm = (Normal *)erealloc((char *)scdst->norm, + sizeof(Normal)*(norm_off+scsrc->nnorms+(CHUNKSIZ-1))); + memcpy(scdst->norm+norm_off, scsrc->norm, + sizeof(Normal)*scsrc->nnorms); + } + /* add faces */ + scdst->lastgrp = scdst->lastmat = 0; + for (f = scsrc->flist; f != NULL; f = f->next) { + if (f->grp != cur_grp) + setGroup(scdst, scsrc->grpname[cur_grp = f->grp]); + if (f->mat != cur_mat) + setMaterial(scdst, scsrc->matname[cur_mat = f->mat]); + if (f->nv > vllen) { + if (vlist == my_vlist) + vlist = (VNDX *)emalloc( + sizeof(VNDX)*(vllen = f->nv)); + else + vlist = (VNDX *)erealloc((char *)vlist, + sizeof(VNDX)*(vllen = f->nv)); + } + memset(vlist, 0xff, sizeof(VNDX)*f->nv); + for (i = f->nv; i-- > 0; ) { + if (f->v[i].vid >= 0) + vlist[i][0] = vert_map[f->v[i].vid]; + if (f->v[i].tid >= 0) + vlist[i][1] = f->v[i].tid + tex_off; + if (f->v[i].nid >= 0) + vlist[i][2] = f->v[i].nid + norm_off; + } + fcnt += (addFace(scdst, vlist, f->nv) != NULL); + } + /* clean up */ + if (vlist != my_vlist) efree((char *)vlist); + efree((char *)vert_map); + return(fcnt); +} + #define MAXAC 100 + +/* Transform entire scene */ int +xfScene(Scene *sc, int xac, char *xav[]) +{ + char comm[24+MAXAC*8]; + char *cp; + XF myxf; + FVECT vec; + int i; + + if ((sc == NULL) | (xac <= 0) | (xav == NULL)) + return(0); + /* compute matrix */ + if (xf(&myxf, xac, xav) < xac) + return(0); + /* transform vertices */ + for (i = 0; i < sc->nverts; i++) { + VCOPY(vec, sc->vert[i].p); + multp3(vec, vec, myxf.xfm); + VCOPY(sc->vert[i].p, vec); + } + /* transform normals */ + for (i = 0; i < sc->nnorms; i++) { + VCOPY(vec, sc->norm[i]); + multv3(vec, vec, myxf.xfm); + vec[0] /= myxf.sca; vec[1] /= myxf.sca; vec[2] /= myxf.sca; + VCOPY(sc->norm[i], vec); + } + /* add comment */ + cp = strcpy(comm, "Transformed by:"); + for (i = 0; i < xac; i++) { + while (*cp) cp++; + *cp++ = ' '; + strcpy(cp, xav[i]); + } + addComment(sc, comm); + return(xac); /* all done */ +} + +/* Ditto, using transform string rather than pre-parsed words */ +int xfmScene(Scene *sc, const char *xfm) { char *xav[MAXAC+1]; int xac, i; - XF myxf; - FVECT vec; if ((sc == NULL) | (xfm == NULL)) return(0); - while (isspace(*xfm)) /* find first word */ + /* skip spaces at beginning */ + while (isspace(*xfm)) xfm++; if (!*xfm) return(0); - /* break into words for xf() */ - xav[0] = strcpy((char *)malloc(strlen(xfm)+1), xfm); + /* parse string into words */ + xav[0] = strcpy((char *)emalloc(strlen(xfm)+1), xfm); xac = 1; i = 0; for ( ; ; ) { while (!isspace(xfm[++i])) @@ -691,33 +920,109 @@ xfmScene(Scene *sc, const char *xfm) xav[0][i++] = '\0'; if (!xfm[i]) break; - if (xac >= MAXAC-1) - goto bad_xform; + if (xac >= MAXAC-1) { + free(xav[0]); + return(0); + } xav[xac++] = xav[0] + i; } xav[xac] = NULL; - if (xf(&myxf, xac, xav) < xac) - goto bad_xform; - free(xav[0]); - /* transform vertices */ - for (i = 0; i < sc->nverts; i++) { - VCOPY(vec, sc->vert[i].p); - multp3(vec, vec, myxf.xfm); - VCOPY(sc->vert[i].p, vec); + i = xfScene(sc, xac, xav); + efree((char *)xav[0]); + return(i); +} +#undef MAXAC + +/* Delete unreferenced vertices, normals, texture coords */ +void +deleteUnreferenced(Scene *sc) +{ + int *vmap; + Face *f; + int nused, i; + /* allocate index map */ + if (!sc->nverts) + return; + i = sc->nverts; + if (sc->ntex > i) + i = sc->ntex; + if (sc->nnorms > i) + i = sc->nnorms; + vmap = (int *)emalloc(sizeof(int)*i); + /* remap positions */ + for (i = nused = 0; i < sc->nverts; i++) { + if (sc->vert[i].vflist == NULL) { + vmap[i] = -1; + continue; + } + if (nused != i) + sc->vert[nused] = sc->vert[i]; + vmap[i] = nused++; } - /* transform normals */ - for (i = 0; i < sc->nnorms; i++) { - VCOPY(vec, sc->norm[i]); - multv3(vec, vec, myxf.xfm); - vec[0] /= myxf.sca; vec[1] /= myxf.sca; vec[2] /= myxf.sca; - VCOPY(sc->norm[i], vec); + if (nused == sc->nverts) + goto skip_pos; + sc->vert = (Vertex *)erealloc((char *)sc->vert, + sizeof(Vertex)*(nused+(CHUNKSIZ-1))); + sc->nverts = nused; + for (f = sc->flist; f != NULL; f = f->next) + for (i = f->nv; i--; ) + if ((f->v[i].vid = vmap[f->v[i].vid]) < 0) + error(CONSISTENCY, + "Link error in del_unref_verts()"); +skip_pos: + /* remap texture coord's */ + if (!sc->ntex) + goto skip_tex; + memset((void *)vmap, 0, sizeof(int)*sc->ntex); + for (f = sc->flist; f != NULL; f = f->next) + for (i = f->nv; i--; ) + if (f->v[i].tid >= 0) + vmap[f->v[i].tid] = 1; + for (i = nused = 0; i < sc->ntex; i++) { + if (!vmap[i]) + continue; + if (nused != i) + sc->tex[nused] = sc->tex[i]; + vmap[i] = nused++; } - return xac; /* finito */ -bad_xform: - free(xav[0]); - return(0); + if (nused == sc->ntex) + goto skip_tex; + sc->tex = (TexCoord *)erealloc((char *)sc->tex, + sizeof(TexCoord)*(nused+(CHUNKSIZ-1))); + sc->ntex = nused; + for (f = sc->flist; f != NULL; f = f->next) + for (i = f->nv; i--; ) + if (f->v[i].tid >= 0) + f->v[i].tid = vmap[f->v[i].tid]; +skip_tex: + /* remap normals */ + if (!sc->nnorms) + goto skip_norms; + memset((void *)vmap, 0, sizeof(int)*sc->nnorms); + for (f = sc->flist; f != NULL; f = f->next) + for (i = f->nv; i--; ) + if (f->v[i].nid >= 0) + vmap[f->v[i].nid] = 1; + for (i = nused = 0; i < sc->nnorms; i++) { + if (!vmap[i]) + continue; + if (nused != i) + memcpy(sc->norm[nused], sc->norm[i], sizeof(Normal)); + vmap[i] = nused++; + } + if (nused == sc->nnorms) + goto skip_norms; + sc->norm = (Normal *)erealloc((char *)sc->norm, + sizeof(Normal)*(nused+(CHUNKSIZ-1))); + sc->nnorms = nused; + for (f = sc->flist; f != NULL; f = f->next) + for (i = f->nv; i--; ) + if (f->v[i].nid >= 0) + f->v[i].nid = vmap[f->v[i].nid]; +skip_norms: + /* clean up */ + efree((char *)vmap); } -#undef MAXAC /* Free a scene */ void
