root/radiance/ray/src/common/objutil.c
Tue Sep 26 00:14:02 2023 UTC (19 months, 3 weeks ago) by greg
CVS Tags: HEAD, rad5R4
Diff to previous 2.21 , to selected 2.10
style: corrected efree() typing and channel free loop
Sat Jan 15 02:00:21 2022 UTC (3 years, 4 months ago) by greg
Changes since 2.20: +21 -20 lines
Diff to previous 2.20 , to selected 2.10
refactor: eliminated stray uses of (char *) to point to memory
Sat May 1 00:58:18 2021 UTC (4 years ago) by greg
Changes since 2.19: +4 -4 lines
Diff to previous 2.19 , to selected 2.10
refactor: changed from calling emalloc() to savqstr()
Fri Apr 23 18:31:45 2021 UTC (4 years ago) by greg
Changes since 2.18: +51 -1 lines
Diff to previous 2.18 , to selected 2.10
feat: Added getVertexNeighbors() call to find neighboring edges/vertices
Fri Apr 9 15:26:41 2021 UTC (4 years, 1 month ago) by greg
Changes since 2.17: +34 -1 lines
Diff to previous 2.17 , to selected 2.10
feat: added growBoundingBox() to compute scene boundaries
Wed Apr 7 16:46:58 2021 UTC (4 years, 1 month ago) by greg
Changes since 2.16: +6 -8 lines
Diff to previous 2.16 , to selected 2.10
fix: bad emalloc() sizeof(type)
Wed Apr 7 16:40:28 2021 UTC (4 years, 1 month ago) by greg
Changes since 2.15: +18 -18 lines
Diff to previous 2.15 , to selected 2.10
perf: appending texture coordinates and normals more efficient in addScene()
Wed Apr 7 14:37:57 2021 UTC (4 years, 1 month ago) by greg
Changes since 2.14: +29 -36 lines
fix: very minor memory leak (2 strings) in dupScene()
Wed Apr 7 03:02:00 2021 UTC (4 years, 1 month ago) by greg
Changes since 2.13: +126 -46 lines
feat: created addScene() function to add one scene to another
Wed Mar 3 18:53:08 2021 UTC (4 years, 2 months ago) by greg
Changes since 2.12: +7 -7 lines
refactor: added handy macros for getting group and material IDs
Fri Feb 12 20:44:04 2021 UTC (4 years, 3 months ago) by greg
Changes since 2.11: +13 -13 lines
perf: slight improvement to vertex face traversal
Fri Feb 12 01:57:49 2021 UTC (4 years, 3 months ago) by greg
Changes since 2.10: +100 -3 lines
feat: added ability to choose faces when duplicating scene
Fri Dec 18 00:15:47 2020 UTC (4 years, 5 months ago) by greg
Changes since 2.9: +3 -1 lines
feat(robjutil): improved verbose reporting
Wed Jun 24 01:16:09 2020 UTC (4 years, 10 months ago) by greg
fix(libwfobj.a): strcasestr() not supported under (lame) Windows
Tue Jun 23 19:29:40 2020 UTC (4 years, 10 months ago) by greg
Changes since 2.7: +14 -1 lines
feat(libwfobj.a): added findComment() call
Sun Jun 14 17:44:27 2020 UTC (4 years, 11 months ago) by greg
Changes since 2.6: +13 -2 lines
Added transform comments
Sun Jun 14 03:04:25 2020 UTC (4 years, 11 months ago) by greg
Reduced minimum area for legal polygon
Sat May 2 00:12:45 2020 UTC (5 years ago) by greg
Changes since 2.4: +42 -4 lines
Made addFace() into a public routine as well, so tools can add geometry
Fri May 1 18:55:34 2020 UTC (5 years ago) by greg
Changes since 2.3: +59 -1 lines
Made some useful routines public from readwfobj.c
Thu Apr 2 22:14:01 2020 UTC (5 years, 1 month ago) by greg
Changes since 2.2: +39 -26 lines
Added interface for transform from pre-parsed words
Thu Apr 2 20:44:15 2020 UTC (5 years, 1 month ago) by greg
Changes since 2.1: +57 -1 lines
Added -x option to robjutil to transform .OBJ files
Mon Mar 30 18:28:35 2020 UTC (5 years, 1 month ago) by greg
Diff to selected 2.10
