root/radiance/ray/src/common/objutil.c
Revision: 2.14
Committed: Wed Apr 7 03:02:00 2021 UTC (4 years, 3 months ago) by greg
Changes since 2.13: +126 -46 lines
feat: created addScene() function to add one scene to another
2 static const char RCSid[] = "$Id: objutil.c,v 2.13 2021/03/03 18:53:08 greg Exp $";
5 * Basic .OBJ scene handling routines.
6 *
7 * Created by Greg Ward on Wed Feb 11 2004.
8 */
9
10 #include <stdlib.h>
11 #include <ctype.h>
12 #include "rtio.h"
13 #include "rtmath.h"
14 #include "rterror.h"
15 #include "lookup.h"
16 #include "objutil.h"
17
18 /* Find an existing name in a list of names */
19 int
20 findName(const char *nm, const char **nmlist, int n)
21 {
22 int i;
23
24 for (i = n; i-- > 0; )
25 if (!strcmp(nmlist[i], nm))
26 break;
27 return(i);
28 }
29
30 /* Clear face selection */
31 void
32 clearSelection(Scene *sc, int set)
33 {
34 Face *f;
35
36 for (f = sc->flist; f != NULL; f = f->next)
37 if (set)
38 f->flags |= FACE_SELECTED;
39 else
40 f->flags &= ~FACE_SELECTED;
41 }
42
43 /* Select faces by object name (modifies current) */
44 void
45 selectGroup(Scene *sc, const char *gname, int invert)
46 {
47 int gid = getGroupID(sc, gname);
48 Face *f;
49
50 if (gid < 0)
51 return;
52 for (f = sc->flist; f != NULL; f = f->next)
53 if (f->grp == gid) {
54 if (invert)
55 f->flags &= ~FACE_SELECTED;
56 else
57 f->flags |= FACE_SELECTED;
58 }
59 }
60
61 /* Select faces by material name (modifies current) */
62 void
63 selectMaterial(Scene *sc, const char *mname, int invert)
64 {
65 int mid = getMaterialID(sc, mname);
66 Face *f;
67
68 if (mid < 0)
69 return;
70 for (f = sc->flist; f != NULL; f = f->next)
71 if (f->mat == mid) {
72 if (invert)
73 f->flags &= ~FACE_SELECTED;
74 else
75 f->flags |= FACE_SELECTED;
76 }
77 }
78
79 /* Invert face selection */
80 void
81 invertSelection(Scene *sc)
82 {
83 Face *f;
84
85 for (f = sc->flist; f != NULL; f = f->next)
86 f->flags ^= FACE_SELECTED;
87 }
88
89 /* Count selected faces */
90 int
91 numberSelected(Scene *sc)
92 {
93 int nsel = 0;
94 Face *f;
95
96 for (f = sc->flist; f != NULL; f = f->next)
97 nsel += ((f->flags & FACE_SELECTED) != 0);
98 return(nsel);
99 }
100
101 /* Execute callback on indicated faces */
102 int
103 foreachFace(Scene *sc, int (*cb)(Scene *, Face *, void *),
104 int flreq, int flexc, void *c_data)
105 {
106 const int fltest = flreq | flexc;
107 int sum = 0;
108 Face *f;
109
110 if ((sc == NULL) | (cb == NULL))
111 return(0);
112 for (f = sc->flist; f != NULL; f = f->next)
113 if ((f->flags & fltest) == flreq) {
114 int res = (*cb)(sc, f, c_data);
115 if (res < 0)
116 return(res);
117 sum += res;
118 }
119 return(sum);
120 }
121
122 /* Callback for removeTexture() */
123 static int
124 remFaceTexture(Scene *sc, Face *f, void *dummy)
125 {
126 int hadTexture = 0;
127 int i;
128
129 for (i = f->nv; i-- > 0; ) {
130 if (f->v[i].tid < 0)
131 continue;
132 f->v[i].tid = -1;
133 hadTexture = 1;
134 }
135 return(hadTexture);
136 }
137
138 /* Remove texture coordinates from the indicated faces */
139 int
140 removeTexture(Scene *sc, int flreq, int flexc)
141 {
142 return(foreachFace(sc, remFaceTexture, flreq, flexc, NULL));
143 }
144
145 /* Callback for removeNormals() */
146 static int
147 remFaceNormal(Scene *sc, Face *f, void *dummy)
148 {
149 int hadNormal = 0;
150 int i;
151
152 for (i = f->nv; i-- > 0; ) {
153 if (f->v[i].nid < 0)
154 continue;
155 f->v[i].nid = -1;
156 hadNormal = 1;
157 }
158 return(hadNormal);
159 }
160
161 /* Remove surface normals from the indicated faces */
162 int
163 removeNormals(Scene *sc, int flreq, int flexc)
164 {
165 return(foreachFace(sc, remFaceNormal, flreq, flexc, NULL));
166 }
167
168 /* Callback for changeGroup() */
169 static int
170 chngFaceGroup(Scene *sc, Face *f, void *ptr)
171 {
172 int grp = *(int *)ptr;
173
174 if (f->grp == grp)
175 return(0);
176 f->grp = grp;
177 return(1);
178 }
179
180 /* Change group for the indicated faces */
181 int
182 changeGroup(Scene *sc, const char *gname, int flreq, int flexc)
183 {
184 int grp = getGroupID(sc, gname);
185
186 if (grp < 0) {
187 sc->grpname = chunk_alloc(char *, sc->grpname, sc->ngrps);
188 sc->grpname[grp=sc->ngrps++] = savqstr((char *)gname);
189 }
190 return(foreachFace(sc, chngFaceGroup, flreq, flexc, (void *)&grp));
191 }
192
193 /* Callback for changeMaterial() */
194 static int
195 chngFaceMaterial(Scene *sc, Face *f, void *ptr)
196 {
197 int mat = *(int *)ptr;
198
199 if (f->mat == mat)
200 return(0);
201 f->mat = mat;
202 return(1);
203 }
204
205 /* Change material for the indicated faces */
206 int
207 changeMaterial(Scene *sc, const char *mname, int flreq, int flexc)
208 {
209 int mat = getMaterialID(sc, mname);
210
211 if (mat < 0) {
212 sc->matname = chunk_alloc(char *, sc->matname, sc->nmats);
213 sc->matname[mat=sc->nmats++] = savqstr((char *)mname);
214 }
215 return(foreachFace(sc, chngFaceMaterial, flreq, flexc, (void *)&mat));
216 }
217
218 /* Compare floating point values for (near) equality */
219 static int
220 fdiffer(double f1, double f2, double eps)
221 {
222 if (f2 != .0)
223 f1 = f1/f2 - 1.;
224 return((f1 > eps) | (f1 < -eps));
225 }
226
227 /* Compare two texture coordinates for (near) equality */
228 static int
229 tex_diff(const TexCoord *t1, const TexCoord *t2, double eps)
230 {
231 if (fdiffer(t1->u, t2->u, eps))
232 return(1);
233 if (fdiffer(t1->v, t2->v, eps))
234 return(1);
235 return(0);
236 }
237
238 /* Compare two surface normals for (near) equality */
239 static int
240 norm_diff(const Normal n1, const Normal n2, double eps)
241 {
242 if (fabs(n1[0]-n2[0]) > eps)
243 return(1);
244 if (fabs(n1[1]-n2[1]) > eps)
245 return(1);
246 if (fabs(n1[2]-n2[2]) > eps)
247 return(1);
248 return(0);
249 }
250
251 /* Replace the given vertex with an equivalent one */
252 static int
253 replace_vertex(Scene *sc, int prev, int repl, double eps)
254 {
255 int repl_tex[10];
256 int repl_norm[10];
257 Face *f, *flast=NULL;
258 int i, j=0;
259 /* check to see if it's even used */
260 if (sc->vert[prev].vflist == NULL)
261 return(0);
262 /* get replacement textures */
263 repl_tex[0] = -1;
264 for (f = sc->vert[repl].vflist; f != NULL; f = f->v[j].fnext) {
265 /* make sure prev isn't in there */
266 for (j = f->nv; j-- > 0; )
267 if (f->v[j].vid == prev)
268 return(0);
269 for (j = f->nv; j-- > 0; )
270 if (f->v[j].vid == repl)
271 break;
272 if (j < 0)
273 goto linkerr;
274 if (f->v[j].tid < 0)
275 continue;
276 /* see if it's new */
277 for (i = 0; repl_tex[i] >= 0; i++) {
278 if (repl_tex[i] == f->v[j].tid)
279 break;
280 if (!tex_diff(&sc->tex[repl_tex[i]],
281 &sc->tex[f->v[j].tid], eps)) {
282 f->v[j].tid = repl_tex[i];
283 break; /* consolidate */
284 }
285 }
286 if (repl_tex[i] >= 0)
287 continue; /* have this one already */
288 /* else add it */
289 repl_tex[i++] = f->v[j].tid;
290 repl_tex[i] = -1;
291 if (i >= 9)
292 break; /* that's all we have room for */
293 }
294 /* get replacement normals */
295 repl_norm[0] = -1;
296 for (f = sc->vert[repl].vflist; f != NULL; f = f->v[j].fnext) {
297 for (j = f->nv; j-- > 0; )
298 if (f->v[j].vid == repl)
299 break;
300 if (f->v[j].nid < 0)
301 continue;
302 /* see if it's new */
303 for (i = 0; repl_norm[i] >= 0; i++) {
304 if (repl_norm[i] == f->v[j].nid)
305 break;
306 if (!norm_diff(sc->norm[repl_norm[i]],
307 sc->norm[f->v[j].nid], eps)) {
308 f->v[j].nid = repl_norm[i];
309 break; /* consolidate */
310 }
311 }
312 if (repl_norm[i] >= 0)
313 continue; /* have this one already */
314 /* else add it */
315 repl_norm[i++] = f->v[j].nid;
316 repl_norm[i] = -1;
317 if (i >= 9)
318 break; /* that's all we have room for */
319 }
320 /* replace occurrences of vertex */
321 for (f = sc->vert[prev].vflist; f != NULL; f = f->v[j].fnext) {
322 for (j = f->nv; j-- > 0; )
323 if (f->v[j].vid == prev)
324 break;
325 if (j < 0)
326 goto linkerr;
327 /* XXX doesn't allow for multiple references to prev in face */
328 f->v[j].vid = repl; /* replace vertex itself */
329 if (faceArea(sc, f, NULL) <= FTINY*FTINY)
330 f->flags |= FACE_DEGENERATE;
331 if (f->v[j].tid >= 0) /* replace texture if appropriate */
332 for (i = 0; repl_tex[i] >= 0; i++) {
333 if (repl_tex[i] == f->v[j].tid)
334 break;
335 if (!tex_diff(&sc->tex[repl_tex[i]],
336 &sc->tex[f->v[j].tid], eps)) {
337 f->v[j].tid = repl_tex[i];
338 break;
339 }
340 }
341 if (f->v[j].nid >= 0) /* replace normal if appropriate */
342 for (i = 0; repl_norm[i] >= 0; i++) {
343 if (repl_norm[i] == f->v[j].nid)
344 break;
345 if (!norm_diff(sc->norm[repl_norm[i]],
346 sc->norm[f->v[j].nid], eps)) {
347 f->v[j].nid = repl_norm[i];
348 break;
349 }
350 }
351 flast = f;
352 }
353 /* transfer face list */
354 flast->v[j].fnext = sc->vert[repl].vflist;
355 sc->vert[repl].vflist = sc->vert[prev].vflist;
356 sc->vert[prev].vflist = NULL;
357 return(1);
358 linkerr:
359 error(CONSISTENCY, "Link error in replace_vertex()");
360 return(0); /* shouldn't return */
361 }
362
363 /* Eliminate duplicate vertices, return # joined */
364 int
365 coalesceVertices(Scene *sc, double eps)
366 {
367 int nelim = 0;
368 LUTAB myLookup;
369 LUENT *le;
370 char vertfmt[32], vertbuf[64];
371 double d;
372 int i;
373
374 if (eps >= 1.)
375 return(0);
376 if (sc->nverts <= 3)
377 return(0);
378 /* create hash table */
379 myLookup.hashf = lu_shash;
380 myLookup.keycmp = (lut_keycmpf_t *)strcmp;
381 myLookup.freek = (lut_free_t *)freeqstr;
382 myLookup.freed = NULL;
383 if (!lu_init(&myLookup, sc->nverts))
384 return(0);
385 if (eps <= 5e-15)
386 strcpy(vertfmt, "%.15e %.15e %.15e");
387 else {
388 int nsigdig = 0;
389 for (d = eps; d < 0.5; d *= 10.)
390 ++nsigdig;
391 sprintf(vertfmt, "%%.%de %%.%de %%.%de",
392 nsigdig, nsigdig, nsigdig);
393 }
394 /* find coicident vertices */
395 for (i = 0; i < sc->nverts; i++) {
396 if (verbose && !((i+1) & 0x3fff))
397 fprintf(stderr, "%3d%% complete\r", 100*i/sc->nverts);
398 /* check for match */
399 sprintf(vertbuf, vertfmt, sc->vert[i].p[0],
400 sc->vert[i].p[1], sc->vert[i].p[2]);
401 le = lu_find(&myLookup, vertbuf);
402 if (le->data != NULL) { /* coincident vertex */
403 nelim += replace_vertex(sc, i,
404 (Vertex *)le->data - sc->vert, eps);
405 continue;
406 }
407 if (le->key == NULL) /* else create new entry */
408 le->key = savqstr(vertbuf);
409 le->data = (char *)&sc->vert[i];
410 }
411 lu_done(&myLookup); /* clean up */
412 return(nelim);
413 }
414
415 /* Identify duplicate faces */
416 int
417 findDuplicateFaces(Scene *sc)
418 {
419 int nchecked = 0;
420 int nfound = 0;
421 Face *f, *f1;
422 int vid;
423 int i, j;
424 /* start fresh */
425 for (f = sc->flist; f != NULL; f = f->next)
426 f->flags &= ~FACE_DUPLICATE;
427 /* check each face */
428 for (f = sc->flist; f != NULL; f = f->next) {
429 nchecked++;
430 if (verbose && !(nchecked & 0x3fff))
431 fprintf(stderr, "%3d%% complete\r",
432 100*nchecked/sc->nfaces);
433 if (f->flags & FACE_DUPLICATE)
434 continue; /* already identified */
435 vid = f->v[0].vid;
436 /* look for duplicates */
437 for (f1 = sc->vert[vid].vflist; f1 != NULL;
438 f1 = f1->v[j].fnext) {
439 for (j = f1->nv; j-- > 0; )
440 if (f1->v[j].vid == vid)
441 break;
442 if (j < 0)
443 break; /* missing link! */
444 if (f1 == f)
445 continue; /* shouldn't happen */
446 if (f1->flags & FACE_DUPLICATE)
447 continue; /* already marked */
448 if (f1->nv != f->nv)
449 continue; /* couldn't be dup. */
450 for (i = f->nv; --i > 0; )
451 if (f->v[i].vid != f1->v[(j+i)%f1->nv].vid)
452 break; /* vertex mismatch */
453 if (i) {
454 #if DUP_CHECK_REVERSE /* check reverse direction */
455 for (i = f->nv; --i > 0; )
456 if (f1->v[(j+f1->nv-i)%f1->nv].vid
457 != f->v[i].vid)
458 break;
459 if (i) /* no match */
460 #endif
461 continue;
462 }
463 f1->flags |= FACE_DUPLICATE;
464 ++nfound;
465 }
466 }
467 if (verbose)
468 fprintf(stderr, "Found %d duplicate faces\n", nfound);
469 return(nfound);
470 }
471
472 /* Delete indicated faces */
473 int
474 deleteFaces(Scene *sc, int flreq, int flexc)
475 {
476 const int fltest = flreq | flexc;
477 int orig_nfaces = sc->nfaces;
478 Face fhead;
479 Face *f, *ftst;
480
481 fhead.next = sc->flist;
482 f = &fhead;
483 while ((ftst = f->next) != NULL)
484 if ((ftst->flags & fltest) == flreq) {
485 Face *vf; /* remove from vertex lists */
486 int vid, i, j;
487 for (i = 0; i < ftst->nv; i++) {
488 vid = ftst->v[i].vid;
489 vf = sc->vert[vid].vflist;
490 if (vf == ftst) {
491 sc->vert[vid].vflist = ftst->v[i].fnext;
492 continue;
493 }
494 while (vf != NULL) {
495 for (j = vf->nv; j-- > 0; )
496 if (vf->v[j].vid == vid)
497 break;
498 if (j < 0)
499 break; /* error */
500 if (vf->v[j].fnext == ftst) {
501 vf->v[j].fnext =
502 ftst->v[i].fnext;
503 break;
504 }
505 vf = vf->v[j].fnext;
506 }
507 }
508 f->next = ftst->next; /* remove from scene list */
509 efree((char *)ftst);
510 sc->nfaces--;
511 } else
512 f = f->next;
513 sc->flist = fhead.next;
514 return(orig_nfaces - sc->nfaces);
515 }
516
517 /* Compute face area (and normal) */
518 double
519 faceArea(const Scene *sc, const Face *f, Normal nrm)
520 {
521 FVECT fnrm;
522 double area;
523 FVECT v1, v2, v3;
524 double *p0;
525 int i;
526
527 if (f->flags & FACE_DEGENERATE)
528 return(.0); /* should we check this? */
529 fnrm[0] = fnrm[1] = fnrm[2] = .0;
530 p0 = sc->vert[f->v[0].vid].p;
531 VSUB(v1, sc->vert[f->v[1].vid].p, p0);
532 for (i = 2; i < f->nv; i++) {
533 VSUB(v2, sc->vert[f->v[i].vid].p, p0);
534 fcross(v3, v1, v2);
535 VADD(fnrm, fnrm, v3);
536 VCOPY(v1, v2);
537 }
538 area = 0.5*normalize(fnrm);
539 if (nrm != NULL) {
540 if (area != 0.)
541 VCOPY(nrm, fnrm);
542 else
543 nrm[0] = nrm[1] = nrm[2] = 0.;
544 }
545 return(area);
546 }
547
548 /* Add a descriptive comment */
549 void
550 addComment(Scene *sc, const char *comment)
551 {
552 sc->descr = chunk_alloc(char *, sc->descr, sc->ndescr);
553 sc->descr[sc->ndescr++] = savqstr((char *)comment);
554 }
555
556 /* Find index for comment containing the given string (starting from n) */
557 int
558 findComment(Scene *sc, const char *match, int n)
559 {
560 if (n >= sc->ndescr)
561 return(-1);
562 n *= (n > 0);
563 while (n < sc->ndescr)
564 if (strstr(sc->descr[n], match) != NULL)
565 return(n);
566 return(-1);
567 }
568
569 /* Clear comments */
570 void
571 clearComments(Scene *sc)
572 {
573 while (sc->ndescr > 0)
574 freeqstr(sc->descr[--sc->ndescr]);
575 efree((char *)sc->descr);
576 sc->ndescr = 0;
577 }
578
579 /* Add a face to a vertex face list */
580 static void
581 add2facelist(Scene *sc, Face *f, int i)
582 {
583 int vid = f->v[i].vid;
584 Face *fp = sc->vert[vid].vflist;
585 int j;
586
587 f->v[i].fnext = NULL; /* will put at end */
588 if (fp == NULL) { /* new list */
589 sc->vert[vid].vflist = f;
590 return;
591 }
592 for ( ; ; ) { /* else find position */
593 if (fp == f)
594 return; /* already in list */
595 for (j = fp->nv; j-- > 0; )
596 if (fp->v[j].vid == vid)
597 break;
598 if (j < 0)
599 error(CONSISTENCY, "Link error in add2facelist()");
600 if (fp->v[j].fnext == NULL)
601 break; /* reached the end */
602 fp = fp->v[j].fnext;
603 }
604 fp->v[j].fnext = f; /* append new face */
605 }
606
607 /* Allocate an empty scene */
608 Scene *
609 newScene(void)
610 {
611 Scene *sc = (Scene *)ecalloc(1, sizeof(Scene));
612 /* default group & material */
613 sc->grpname = chunk_alloc(char *, sc->grpname, sc->ngrps);
614 sc->grpname[sc->ngrps++] = savqstr("DEFAULT_GROUP");
615 sc->matname = chunk_alloc(char *, sc->matname, sc->nmats);
616 sc->matname[sc->nmats++] = savqstr("DEFAULT_MATERIAL");
617
618 return(sc);
619 }
620
621 /* Add a vertex to a scene */
622 int
623 addVertex(Scene *sc, double x, double y, double z)
624 {
625 sc->vert = chunk_alloc(Vertex, sc->vert, sc->nverts);
626 sc->vert[sc->nverts].p[0] = x;
627 sc->vert[sc->nverts].p[1] = y;
628 sc->vert[sc->nverts].p[2] = z;
629 sc->vert[sc->nverts].vflist = NULL;
630 return(sc->nverts++);
631 }
632
633 /* Add a texture coordinate to a scene */
634 int
635 addTexture(Scene *sc, double u, double v)
636 {
637 sc->tex = chunk_alloc(TexCoord, sc->tex, sc->ntex);
638 sc->tex[sc->ntex].u = u;
639 sc->tex[sc->ntex].v = v;
640 return(sc->ntex++);
641 }
642
643 /* Add a surface normal to a scene */
644 int
645 addNormal(Scene *sc, double xn, double yn, double zn)
646 {
647 FVECT nrm;
648
649 nrm[0] = xn; nrm[1] = yn; nrm[2] = zn;
650 if (normalize(nrm) == .0)
651 return(-1);
652 sc->norm = chunk_alloc(Normal, sc->norm, sc->nnorms);
653 VCOPY(sc->norm[sc->nnorms], nrm);
654 return(sc->nnorms++);
655 }
656
657 /* Set current (last) group */
658 void
659 setGroup(Scene *sc, const char *nm)
660 {
661 sc->lastgrp = getGroupID(sc, nm);
662 if (sc->lastgrp >= 0)
663 return;
664 sc->grpname = chunk_alloc(char *, sc->grpname, sc->ngrps);
665 sc->grpname[sc->lastgrp=sc->ngrps++] = savqstr((char *)nm);
666 }
667
668 /* Set current (last) material */
669 void
670 setMaterial(Scene *sc, const char *nm)
671 {
672 sc->lastmat = getMaterialID(sc, nm);
673 if (sc->lastmat >= 0)
674 return;
675 sc->matname = chunk_alloc(char *, sc->matname, sc->nmats);
676 sc->matname[sc->lastmat=sc->nmats++] = savqstr((char *)nm);
677 }
678
679 /* Add new face to a scene */
680 Face *
681 addFace(Scene *sc, VNDX vid[], int nv)
682 {
683 Face *f;
684 int i;
685
686 if (nv < 3)
687 return(NULL);
688 f = (Face *)emalloc(sizeof(Face)+sizeof(VertEnt)*(nv-3));
689 f->flags = 0;
690 f->nv = nv;
691 f->grp = sc->lastgrp;
692 f->mat = sc->lastmat;
693 for (i = 0; i < nv; i++) { /* add each vertex */
694 int j;
695 f->v[i].vid = vid[i][0];
696 f->v[i].tid = vid[i][1];
697 f->v[i].nid = vid[i][2];
698 f->v[i].fnext = NULL;
699 for (j = i; j-- > 0; )
700 if (f->v[j].vid == vid[i][0])
701 break;
702 if (j < 0) { /* first occurrence? */
703 f->v[i].fnext = sc->vert[vid[i][0]].vflist;
704 sc->vert[vid[i][0]].vflist = f;
705 } else if (nv == 3) /* degenerate triangle? */
706 f->flags |= FACE_DEGENERATE;
707 }
708 f->next = sc->flist; /* push onto face list */
709 sc->flist = f;
710 sc->nfaces++;
711 /* check face area */
712 if (!(f->flags & FACE_DEGENERATE) && faceArea(sc, f, NULL) <= FTINY*FTINY)
713 f->flags |= FACE_DEGENERATE;
714 return(f);
715 }
716
717 /* Duplicate a scene, optionally selecting faces */
718 Scene *
719 dupScene(const Scene *osc, int flreq, int flexc)
720 {
721 int fltest = flreq | flexc;
722 Scene *sc;
723 const Face *fo;
724 Face *f;
725 int i;
726
727 if (osc == NULL)
728 return(NULL);
729 sc = newScene();
730 for (i = 0; i < osc->ndescr; i++)
731 addComment(sc, osc->descr[i]);
732 if (osc->ngrps) {
733 sc->grpname = (char **)emalloc(sizeof(char *) *
734 (osc->ngrps+(CHUNKSIZ-1)));
735 for (i = 0; i < osc->ngrps; i++)
736 sc->grpname[i] = savqstr(osc->grpname[i]);
737 sc->ngrps = osc->ngrps;
738 }
739 if (osc->nmats) {
740 sc->matname = (char **)emalloc(sizeof(char *) *
741 (osc->nmats+(CHUNKSIZ-1)));
742 for (i = 0; i < osc->nmats; i++)
743 sc->matname[i] = savqstr(osc->matname[i]);
744 sc->nmats = osc->nmats;
745 }
746 if (osc->nverts) {
747 sc->vert = (Vertex *)emalloc(sizeof(Vertex) *
748 (osc->nverts+(CHUNKSIZ-1)));
749 memcpy((void *)sc->vert, (const void *)osc->vert,
750 sizeof(Vertex)*osc->nverts);
751 sc->nverts = osc->nverts;
752 for (i = 0; i < sc->nverts; i++)
753 sc->vert[i].vflist = NULL;
754 }
755 if (osc->ntex) {
756 sc->tex = (TexCoord *)emalloc(sizeof(TexCoord) *
757 (osc->ntex+(CHUNKSIZ-1)));
758 memcpy((void *)sc->tex, (const void *)osc->tex,
759 sizeof(TexCoord)*osc->ntex);
760 sc->ntex = osc->ntex;
761 }
762 if (osc->nnorms) {
763 sc->norm = (Normal *)emalloc(sizeof(Normal) *
764 (osc->nnorms+CHUNKSIZ));
765 memcpy((void *)sc->norm, (const void *)osc->norm,
766 sizeof(Normal)*osc->nnorms);
767 sc->nnorms = osc->nnorms;
768 }
769 for (fo = osc->flist; fo != NULL; fo = fo->next) {
770 if ((fo->flags & fltest) != flreq)
771 continue;
772 f = (Face *)emalloc(sizeof(Face) +
773 sizeof(VertEnt)*(fo->nv-3));
774 memcpy((void *)f, (const void *)fo, sizeof(Face) +
775 sizeof(VertEnt)*(fo->nv-3));
776 for (i = 0; i < f->nv; i++)
777 add2facelist(sc, f, i);
778 f->next = sc->flist;
779 sc->flist = f;
780 sc->nfaces++;
781 }
782 deleteUnreferenced(sc); /* jetsam */
783 return(sc);
784 }
785
786 /* Add one scene to another, not checking for redundancies */
787 int
788 addScene(Scene *scdst, const Scene *scsrc)
789 {
790 VNDX my_vlist[4];
791 int *vert_map = NULL;
792 int *norm_map = NULL;
793 int *tex_map = NULL;
794 VNDX *vlist = my_vlist;
795 int vllen = sizeof(my_vlist)/sizeof(VNDX);
796 int cur_mat = 0;
797 int cur_grp = 0;
798 int fcnt = 0;
799 const Face *f;
800 int i;
801
802 if ((scdst == NULL) | (scsrc == NULL))
803 return(-1);
804 if (scsrc->nfaces <= 0)
805 return(0);
806 /* map vertices */
807 vert_map = (int *)emalloc(sizeof(int *)*scsrc->nverts);
808 for (i = 0; i < scsrc->nverts; i++) {
809 const Vertex *v = scsrc->vert + i;
810 if (v->vflist == NULL) {
811 vert_map[i] = -1;
812 continue;
813 }
814 vert_map[i] = addVertex(scdst, v->p[0], v->p[1], v->p[2]);
815 }
816 if (scsrc->ntex > 0) /* map texture coords */
817 tex_map = (int *)emalloc(sizeof(int *)*scsrc->ntex);
818 for (i = 0; i < scsrc->ntex; i++) {
819 const TexCoord *t = scsrc->tex + i;
820 tex_map[i] = addTexture(scdst, t->u, t->v);
821 }
822 if (scsrc->nnorms > 0) /* map normals */
823 norm_map = (int *)emalloc(sizeof(int *)*scsrc->nnorms);
824 for (i = 0; i < scsrc->nnorms; i++) {
825 const float *n = scsrc->norm[i];
826 norm_map[i] = addNormal(scdst, n[0], n[1], n[2]);
827 }
828 /* add faces */
829 scdst->lastgrp = scdst->lastmat = 0;
830 for (f = scsrc->flist; f != NULL; f = f->next) {
831 if (f->grp != cur_grp)
832 setGroup(scdst, scsrc->grpname[cur_grp = f->grp]);
833 if (f->mat != cur_mat)
834 setMaterial(scdst, scsrc->matname[cur_mat = f->mat]);
835 if (f->nv > vllen) {
836 if (vlist == my_vlist)
837 vlist = (VNDX *)emalloc(
838 sizeof(VNDX)*(vllen = f->nv));
839 else
840 vlist = (VNDX *)erealloc((char *)vlist,
841 sizeof(VNDX)*(vllen = f->nv));
842 }
843 memset(vlist, 0xff, sizeof(VNDX)*f->nv);
844 for (i = f->nv; i-- > 0; ) {
845 if (f->v[i].vid >= 0)
846 vlist[i][0] = vert_map[f->v[i].vid];
847 if (f->v[i].tid >= 0)
848 vlist[i][1] = tex_map[f->v[i].tid];
849 if (f->v[i].nid >= 0)
850 vlist[i][2] = norm_map[f->v[i].nid];
851 }
852 fcnt += (addFace(scdst, vlist, f->nv) != NULL);
853 }
854 /* clean up */
855 if (vlist != my_vlist) efree((char *)vlist);
856 if (norm_map != NULL) efree((char *)norm_map);
857 if (tex_map != NULL) efree((char *)tex_map);
858 efree((char *)vert_map);
859 return(fcnt);
860 }
861
862 #define MAXAC 100
863
864 /* Transform entire scene */
865 int
866 xfScene(Scene *sc, int xac, char *xav[])
867 {
868 char comm[24+MAXAC*8];
869 char *cp;
870 XF myxf;
871 FVECT vec;
872 int i;
873
874 if ((sc == NULL) | (xac <= 0) | (xav == NULL))
875 return(0);
876 /* compute matrix */
877 if (xf(&myxf, xac, xav) < xac)
878 return(0);
879 /* transform vertices */
880 for (i = 0; i < sc->nverts; i++) {
881 VCOPY(vec, sc->vert[i].p);
882 multp3(vec, vec, myxf.xfm);
883 VCOPY(sc->vert[i].p, vec);
884 }
885 /* transform normals */
886 for (i = 0; i < sc->nnorms; i++) {
887 VCOPY(vec, sc->norm[i]);
888 multv3(vec, vec, myxf.xfm);
889 vec[0] /= myxf.sca; vec[1] /= myxf.sca; vec[2] /= myxf.sca;
890 VCOPY(sc->norm[i], vec);
891 }
892 /* add comment */
893 cp = strcpy(comm, "Transformed by:");
894 for (i = 0; i < xac; i++) {
895 while (*cp) cp++;
896 *cp++ = ' ';
897 strcpy(cp, xav[i]);
898 }
899 addComment(sc, comm);
900 return(xac); /* all done */
901 }
902
903 /* Ditto, using transform string rather than pre-parsed words */
904 int
905 xfmScene(Scene *sc, const char *xfm)
906 {
907 char *xav[MAXAC+1];
908 int xac, i;
909
910 if ((sc == NULL) | (xfm == NULL))
911 return(0);
912 /* skip spaces at beginning */
913 while (isspace(*xfm))
914 xfm++;
915 if (!*xfm)
916 return(0);
917 /* parse string into words */
918 xav[0] = strcpy((char *)emalloc(strlen(xfm)+1), xfm);
919 xac = 1; i = 0;
920 for ( ; ; ) {
921 while (!isspace(xfm[++i]))
922 if (!xfm[i])
923 break;
924 while (isspace(xfm[i]))
925 xav[0][i++] = '\0';
926 if (!xfm[i])
927 break;
928 if (xac >= MAXAC-1) {
929 free(xav[0]);
930 return(0);
931 }
932 xav[xac++] = xav[0] + i;
933 }
934 xav[xac] = NULL;
935 i = xfScene(sc, xac, xav);
936 efree((char *)xav[0]);
937 return(i);
938 }
939 #undef MAXAC
940
941 /* Delete unreferenced vertices, normals, texture coords */
942 void
943 deleteUnreferenced(Scene *sc)
944 {
945 int *vmap;
946 Face *f;
947 int nused, i;
948 /* allocate index map */
949 if (!sc->nverts)
950 return;
951 i = sc->nverts;
952 if (sc->ntex > i)
953 i = sc->ntex;
954 if (sc->nnorms > i)
955 i = sc->nnorms;
956 vmap = (int *)emalloc(sizeof(int)*i);
957 /* remap positions */
958 for (i = nused = 0; i < sc->nverts; i++) {
959 if (sc->vert[i].vflist == NULL) {
960 vmap[i] = -1;
961 continue;
962 }
963 if (nused != i)
964 sc->vert[nused] = sc->vert[i];
965 vmap[i] = nused++;
966 }
967 if (nused == sc->nverts)
968 goto skip_pos;
969 sc->vert = (Vertex *)erealloc((char *)sc->vert,
970 sizeof(Vertex)*(nused+(CHUNKSIZ-1)));
971 sc->nverts = nused;
972 for (f = sc->flist; f != NULL; f = f->next)
973 for (i = f->nv; i--; )
974 if ((f->v[i].vid = vmap[f->v[i].vid]) < 0)
975 error(CONSISTENCY,
976 "Link error in del_unref_verts()");
977 skip_pos:
978 /* remap texture coord's */
979 if (!sc->ntex)
980 goto skip_tex;
981 memset((void *)vmap, 0, sizeof(int)*sc->ntex);
982 for (f = sc->flist; f != NULL; f = f->next)
983 for (i = f->nv; i--; )
984 if (f->v[i].tid >= 0)
985 vmap[f->v[i].tid] = 1;
986 for (i = nused = 0; i < sc->ntex; i++) {
987 if (!vmap[i])
988 continue;
989 if (nused != i)
990 sc->tex[nused] = sc->tex[i];
991 vmap[i] = nused++;
992 }
993 if (nused == sc->ntex)
994 goto skip_tex;
995 sc->tex = (TexCoord *)erealloc((char *)sc->tex,
996 sizeof(TexCoord)*(nused+(CHUNKSIZ-1)));
997 sc->ntex = nused;
998 for (f = sc->flist; f != NULL; f = f->next)
999 for (i = f->nv; i--; )
1000 if (f->v[i].tid >= 0)
1001 f->v[i].tid = vmap[f->v[i].tid];
1002 skip_tex:
1003 /* remap normals */
1004 if (!sc->nnorms)
1005 goto skip_norms;
1006 memset((void *)vmap, 0, sizeof(int)*sc->nnorms);
1007 for (f = sc->flist; f != NULL; f = f->next)
1008 for (i = f->nv; i--; )
1009 if (f->v[i].nid >= 0)
1010 vmap[f->v[i].nid] = 1;
1011 for (i = nused = 0; i < sc->nnorms; i++) {
1012 if (!vmap[i])
1013 continue;
1014 if (nused != i)
1015 memcpy((void *)sc->norm[nused],
1016 (void *)sc->norm[i],
1017 sizeof(Normal));
1018 vmap[i] = nused++;
1019 }
1020 if (nused == sc->nnorms)
1021 goto skip_norms;
1022 sc->norm = (Normal *)erealloc((char *)sc->norm,
1023 sizeof(Normal)*(nused+(CHUNKSIZ-1)));
1024 sc->nnorms = nused;
1025 for (f = sc->flist; f != NULL; f = f->next)
1026 for (i = f->nv; i--; )
1027 if (f->v[i].nid >= 0)
1028 f->v[i].nid = vmap[f->v[i].nid];
1029 skip_norms:
1030 /* clean up */
1031 efree((char *)vmap);
1032 }
1033
1034 /* Free a scene */
1035 void
1036 freeScene(Scene *sc)
1037 {
1038 int i;
1039 Face *f;
1040
1041 if (sc == NULL)
1042 return;
1043 clearComments(sc);
1044 for (i = sc->ngrps; i-- > 0; )
1045 freeqstr(sc->grpname[i]);
1046 efree((char *)sc->grpname);
1047 for (i = sc->nmats; i-- > 0; )
1048 freeqstr(sc->matname[i]);
1049 efree((char *)sc->matname);
1050 efree((char *)sc->vert);
1051 efree((char *)sc->tex);
1052 efree((char *)sc->norm);
1053 while ((f = sc->flist) != NULL) {
1054 sc->flist = f->next;
1055 efree((char *)f);
1056 }
1057 efree((char *)sc);
1058 }
