root/radiance/ray/src/common/objset.c
Revision: 2.2
Committed: Thu Mar 12 11:41:18 1992 UTC (32 years, 1 month ago) by greg
volumes are no longer surfaces
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * objset.c - routines for maintaining object sets.
9 *
10 * 7/28/85
11 */
12
13 #include "standard.h"
14
15 #include "octree.h"
16
17 #include "object.h"
18
19 #include "otypes.h"
20
21 #ifndef OSTSIZ
22 #ifdef BIGMEM
23 #define OSTSIZ 56437 /* object table size (a prime!) */
24 #else
25 #define OSTSIZ 12329 /* object table size (a prime!) */
26 #endif
27 #endif
28
29 static OBJECT *ostable[OSTSIZ]; /* the object set table */
30
31
32 insertelem(os, obj) /* insert obj into os, no questions */
33 register OBJECT *os;
34 OBJECT obj;
35 {
36 register int i;
37
38 for (i = os[0]++; i > 0; i--)
39 if (os[i] > obj)
40 os[i+1] = os[i];
41 else
42 break;
43 os[i+1] = obj;
44 }
45
46
47 deletelem(os, obj) /* delete obj from os, no questions */
48 register OBJECT *os;
49 OBJECT obj;
50 {
51 register int i;
52
53 i = (*os)--;
54 os++;
55 while (i > 0 && *os < obj) {
56 i--;
57 os++;
58 }
59 while (--i > 0) {
60 os[0] = os[1];
61 os++;
62 }
63 }
64
65
66 inset(os, obj) /* determine if object is in set */
67 register OBJECT *os;
68 OBJECT obj;
69 {
70 int upper, lower;
71 register int cm, i;
72
73 lower = 1;
74 upper = cm = os[0] + 1;
75
76 while ((i = (lower + upper) >> 1) != cm) {
77 cm = obj - os[i];
78 if (cm > 0)
79 lower = i;
80 else if (cm < 0)
81 upper = i;
82 else
83 return(1);
84 cm = i;
85 }
86 return(0);
87 }
88
89
90 setequal(os1, os2) /* determine if two sets are equal */
91 register OBJECT *os1, *os2;
92 {
93 register int i;
94
95 for (i = *os1; i-- >= 0; )
96 if (*os1++ != *os2++)
97 return(0);
98 return(1);
99 }
100
101
102 setcopy(os1, os2) /* copy object set os2 into os1 */
103 register OBJECT *os1, *os2;
104 {
105 register int i;
106
107 for (i = *os2; i-- >= 0; )
108 *os1++ = *os2++;
109 }
110
111
112 OCTREE
113 fullnode(oset) /* return octree for object set */
114 OBJECT *oset;
115 {
116 int osentry, ntries;
117 long hval;
118 OCTREE ot;
119 register int i;
120 register OBJECT *os;
121 /* hash on set */
122 hval = 0;
123 os = oset;
124 i = *os++;
125 while (i-- > 0)
126 hval += *os++;
127 ntries = 0;
128 tryagain:
129 osentry = (hval + (long)ntries*ntries) % OSTSIZ;
130 os = ostable[osentry];
131 if (os == NULL) {
132 os = ostable[osentry] = (OBJECT *)malloc(
133 (unsigned)(oset[0]+2)*sizeof(OBJECT));
134 if (os == NULL)
135 goto memerr;
136 ot = oseti(osentry);
137 } else {
138 /* look for set */
139 for (i = 0; *os > 0; i++, os += *os + 1)
140 if (setequal(os, oset))
141 break;
142 ot = oseti(i*OSTSIZ + osentry);
143 if (*os > 0) /* found it */
144 return(ot);
145 if (!isfull(ot)) /* entry overflow */
146 if (++ntries < OSTSIZ)
147 goto tryagain;
148 else
149 error(INTERNAL, "hash table overflow in fullnode");
150 /* remember position */
151 i = os - ostable[osentry];
152 os = ostable[osentry] = (OBJECT *)realloc(
153 (char *)ostable[osentry],
154 (unsigned)(i+oset[0]+2)*sizeof(OBJECT));
155 if (os == NULL)
156 goto memerr;
157 os += i; /* last entry */
158 }
159 setcopy(os, oset); /* add new set */
160 os += *os + 1;
161 *os = 0; /* terminator */
162 return(ot);
163 memerr:
164 error(SYSTEM, "out of memory in fullnode");
165 }
166
167
168 objset(oset, ot) /* get object set for full node */
169 register OBJECT *oset;
170 OCTREE ot;
171 {
172 register OBJECT *os;
173 register int i;
174
175 if (!isfull(ot))
176 goto noderr;
177 i = oseti(ot);
178 if ((os = ostable[i%OSTSIZ]) == NULL)
179 goto noderr;
180 for (i /= OSTSIZ; i--; os += *os + 1)
181 if (*os <= 0)
182 goto noderr;
183 for (i = *os; i-- >= 0; ) /* copy set here */
184 *oset++ = *os++;
185 return;
186 noderr:
187 error(CONSISTENCY, "bad node in objset");
188 }
189
190
191 nonsurfinset(orig, nobjs) /* check sets for non-surfaces */
192 int orig, nobjs;
193 {
194 int n;
195 register OBJECT *os;
196 register OBJECT i, s;
197
198 for (n = 0; n < OSTSIZ; n++) {
199 if ((os = ostable[n]) == NULL)
200 continue;
201 while ((i = *os++) > 0)
202 while (i--) {
203 s = *os;
204 if (s >= orig && s < orig+nobjs &&
205 ismodifier(objptr(s)->otype))
206 return(1);
207 os++;
208 }
209 }
210 return(0);
211 }
