| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: objset.c,v 2.16 2006/02/22 17:05:36 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* objset.c - routines for maintaining object sets.
| 6 |
| 7 |
* External symbols declared in object.h
| 8 |
| 9 |
| 10 |
#include "copyright.h"
| 11 |
| 12 |
#include "standard.h"
| 13 |
| 14 |
#include "octree.h"
| 15 |
| 16 |
#include "object.h"
| 17 |
| 18 |
#ifndef OSTSIZ
| 19 |
#ifdef SMLMEM
| 20 |
#define OSTSIZ 32749 /* object table size (a prime!) */
| 21 |
#else
| 22 |
#define OSTSIZ 262139 /* object table size (a prime!) */
| 23 |
#endif
| 24 |
#endif
| 25 |
| 26 |
#undef xtra_long
| 27 |
#ifdef _WIN64
| 28 |
typedef unsigned long long int xtra_long;
| 29 |
#else
| 30 |
typedef unsigned long int xtra_long;
| 31 |
#endif
| 32 |
| 33 |
static OBJECT *ostable[OSTSIZ]; /* the object set table */
| 34 |
| 35 |
| 36 |
void
| 37 |
insertelem( /* insert obj into os, no questions */
| 38 |
OBJECT *os,
| 39 |
OBJECT obj
| 40 |
| 41 |
| 42 |
int i;
| 43 |
| 44 |
for (i = os[0]++; i > 0; i--)
| 45 |
if (os[i] > obj)
| 46 |
os[i+1] = os[i];
| 47 |
else
| 48 |
break;
| 49 |
os[i+1] = obj;
| 50 |
| 51 |
| 52 |
| 53 |
void
| 54 |
deletelem( /* delete obj from os, no questions */
| 55 |
OBJECT *os,
| 56 |
OBJECT obj
| 57 |
| 58 |
| 59 |
int i;
| 60 |
| 61 |
i = (*os)--;
| 62 |
os++;
| 63 |
while (i > 0 && *os < obj) {
| 64 |
i--;
| 65 |
os++;
| 66 |
| 67 |
while (--i > 0) {
| 68 |
os[0] = os[1];
| 69 |
os++;
| 70 |
| 71 |
| 72 |
| 73 |
| 74 |
int
| 75 |
inset( /* determine if object is in set */
| 76 |
OBJECT *os,
| 77 |
OBJECT obj
| 78 |
| 79 |
| 80 |
int upper, lower;
| 81 |
int cm, i;
| 82 |
| 83 |
if ((i = os[0]) <= 12) { /* linear search algorithm */
| 84 |
cm = obj;
| 85 |
while (i-- > 0)
| 86 |
if (*++os == cm)
| 87 |
return(1);
| 88 |
return(0);
| 89 |
| 90 |
lower = 1;
| 91 |
upper = cm = i + 1;
| 92 |
/* binary search algorithm */
| 93 |
while ((i = (lower + upper) >> 1) != cm) {
| 94 |
cm = obj - os[i];
| 95 |
if (cm > 0)
| 96 |
lower = i;
| 97 |
else if (cm < 0)
| 98 |
upper = i;
| 99 |
else
| 100 |
return(1);
| 101 |
cm = i;
| 102 |
| 103 |
return(0);
| 104 |
| 105 |
| 106 |
| 107 |
int
| 108 |
setequal( /* determine if two sets are equal */
| 109 |
OBJECT *os1,
| 110 |
OBJECT *os2
| 111 |
| 112 |
| 113 |
int i;
| 114 |
| 115 |
for (i = *os1; i-- >= 0; )
| 116 |
if (*os1++ != *os2++)
| 117 |
return(0);
| 118 |
return(1);
| 119 |
| 120 |
| 121 |
| 122 |
void
| 123 |
setcopy( /* copy object set os2 into os1 */
| 124 |
OBJECT *os1,
| 125 |
OBJECT *os2
| 126 |
| 127 |
| 128 |
int i;
| 129 |
| 130 |
for (i = *os2; i-- >= 0; )
| 131 |
*os1++ = *os2++;
| 132 |
| 133 |
| 134 |
| 135 |
OBJECT *
| 136 |
setsave( /* allocate space and save set */
| 137 |
OBJECT *os
| 138 |
| 139 |
| 140 |
OBJECT *osnew;
| 141 |
OBJECT *oset;
| 142 |
int i;
| 143 |
| 144 |
if ((osnew = oset = (OBJECT *)malloc((*os+1)*sizeof(OBJECT))) == NULL)
| 145 |
error(SYSTEM, "out of memory in setsave\n");
| 146 |
for (i = *os; i-- >= 0; ) /* inline setcopy */
| 147 |
*oset++ = *os++;
| 148 |
return(osnew);
| 149 |
| 150 |
| 151 |
| 152 |
void
| 153 |
setunion( /* osr = os1 Union os2 */
| 154 |
OBJECT *osr,
| 155 |
OBJECT *os1,
| 156 |
OBJECT *os2
| 157 |
| 158 |
| 159 |
int i1, i2;
| 160 |
| 161 |
osr[0] = 0;
| 162 |
for (i1 = i2 = 1; i1 <= os1[0] || i2 <= os2[0]; ) {
| 163 |
while (i1 <= os1[0] && (i2 > os2[0] || os1[i1] <= os2[i2])) {
| 164 |
osr[++osr[0]] = os1[i1];
| 165 |
if (i2 <= os2[0] && os2[i2] == os1[i1])
| 166 |
i2++;
| 167 |
i1++;
| 168 |
| 169 |
while (i2 <= os2[0] && (i1 > os1[0] || os2[i2] < os1[i1]))
| 170 |
osr[++osr[0]] = os2[i2++];
| 171 |
| 172 |
| 173 |
| 174 |
| 175 |
void
| 176 |
setintersect( /* osr = os1 Intersect os2 */
| 177 |
OBJECT *osr,
| 178 |
OBJECT *os1,
| 179 |
OBJECT *os2
| 180 |
| 181 |
| 182 |
int i1, i2;
| 183 |
| 184 |
osr[0] = 0;
| 185 |
if (os1[0] <= 0)
| 186 |
return;
| 187 |
for (i1 = i2 = 1; i2 <= os2[0]; ) {
| 188 |
while (os1[i1] < os2[i2])
| 189 |
if (++i1 > os1[0])
| 190 |
return;
| 191 |
while (os2[i2] < os1[i1])
| 192 |
if (++i2 > os2[0])
| 193 |
return;
| 194 |
if (os1[i1] == os2[i2])
| 195 |
| 196 |
| 197 |
| 198 |
| 199 |
| 200 |
OCTREE
| 201 |
fullnode( /* return octree for object set */
| 202 |
OBJECT *oset
| 203 |
| 204 |
| 205 |
unsigned int ntries;
| 206 |
xtra_long hval;
| 207 |
OCTREE ot;
| 208 |
int osentry, i;
| 209 |
OBJECT *os;
| 210 |
/* hash on set */
| 211 |
hval = 0;
| 212 |
os = oset;
| 213 |
i = *os++;
| 214 |
while (i-- > 0)
| 215 |
hval += *os++;
| 216 |
ntries = 0;
| 217 |
tryagain:
| 218 |
osentry = (hval + (xtra_long)ntries*ntries) % OSTSIZ;
| 219 |
os = ostable[osentry];
| 220 |
if (os == NULL) {
| 221 |
os = ostable[osentry] = (OBJECT *)malloc(
| 222 |
(unsigned)(oset[0]+2)*sizeof(OBJECT));
| 223 |
if (os == NULL)
| 224 |
goto memerr;
| 225 |
ot = oseti(osentry);
| 226 |
} else {
| 227 |
/* look for set */
| 228 |
for (i = 0; *os > 0; i++, os += *os + 1)
| 229 |
if (setequal(os, oset))
| 230 |
break;
| 231 |
ot = oseti(i*OSTSIZ + osentry);
| 232 |
if (*os > 0) /* found it */
| 233 |
return(ot);
| 234 |
if (!isfull(ot)) { /* entry overflow */
| 235 |
if (++ntries < OSTSIZ)
| 236 |
goto tryagain;
| 237 |
else
| 238 |
error(INTERNAL, "hash table overflow in fullnode");
| 239 |
| 240 |
/* remember position */
| 241 |
i = os - ostable[osentry];
| 242 |
os = ostable[osentry] = (OBJECT *)realloc(
| 243 |
(void *)ostable[osentry],
| 244 |
(unsigned)(i+oset[0]+2)*sizeof(OBJECT));
| 245 |
if (os == NULL)
| 246 |
goto memerr;
| 247 |
os += i; /* last entry */
| 248 |
| 249 |
setcopy(os, oset); /* add new set */
| 250 |
os += *os + 1;
| 251 |
*os = 0; /* terminator */
| 252 |
return(ot);
| 253 |
memerr:
| 254 |
error(SYSTEM, "out of memory in fullnode");
| 255 |
return 0; /* pro forma return */
| 256 |
| 257 |
| 258 |
| 259 |
void
| 260 |
objset( /* get object set for full node */
| 261 |
OBJECT *oset,
| 262 |
OCTREE ot
| 263 |
| 264 |
| 265 |
OBJECT *os;
| 266 |
int i;
| 267 |
| 268 |
if (!isfull(ot))
| 269 |
goto noderr;
| 270 |
ot = oseti(ot);
| 271 |
if ((os = ostable[ot%OSTSIZ]) == NULL)
| 272 |
goto noderr;
| 273 |
for (i = ot/OSTSIZ; i--; os += *os + 1)
| 274 |
if (*os <= 0)
| 275 |
goto noderr;
| 276 |
for (i = *os; i-- >= 0; ) /* copy set here */
| 277 |
*oset++ = *os++;
| 278 |
return;
| 279 |
noderr:
| 280 |
error(CONSISTENCY, "bad node in objset");
| 281 |
| 282 |
| 283 |
| 284 |
void
| 285 |
donesets(void) /* free ALL SETS in our table */
| 286 |
| 287 |
int n;
| 288 |
| 289 |
for (n = 0; n < OSTSIZ; n++)
| 290 |
if (ostable[n] != NULL) {
| 291 |
free((void *)ostable[n]);
| 292 |
ostable[n] = NULL;
| 293 |
| 294 |
