root/radiance/ray/src/common/objset.c
Revision: 1.7
Committed: Fri May 10 10:37:14 1991 UTC (33 years ago) by greg
Changes since 1.6: +4 -3 lines
added register variable to nonsurfinset()
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * objset.c - routines for maintaining object sets.
9 *
10 * 7/28/85
11 */
12
13 #include "standard.h"
14
15 #include "octree.h"
16
17 #include "object.h"
18
19 #include "otypes.h"
20
21 #ifndef OSTSIZ
22 #define OSTSIZ 12329 /* object table size (a prime!) */
23 #endif
24
25 static OBJECT *ostable[OSTSIZ]; /* the object set table */
26
27
28 insertelem(os, obj) /* insert obj into os, no questions */
29 register OBJECT *os;
30 OBJECT obj;
31 {
32 register int i;
33
34 for (i = os[0]++; i > 0; i--)
35 if (os[i] > obj)
36 os[i+1] = os[i];
37 else
38 break;
39 os[i+1] = obj;
40 }
41
42
43 deletelem(os, obj) /* delete obj from os, no questions */
44 register OBJECT *os;
45 OBJECT obj;
46 {
47 register int i;
48
49 i = (*os)--;
50 os++;
51 while (i > 0 && *os < obj) {
52 i--;
53 os++;
54 }
55 while (--i > 0) {
56 os[0] = os[1];
57 os++;
58 }
59 }
60
61
62 inset(os, obj) /* determine if object is in set */
63 register OBJECT *os;
64 OBJECT obj;
65 {
66 int upper, lower;
67 register int cm, i;
68
69 lower = 1;
70 upper = cm = os[0] + 1;
71
72 while ((i = (lower + upper) >> 1) != cm) {
73 cm = obj - os[i];
74 if (cm > 0)
75 lower = i;
76 else if (cm < 0)
77 upper = i;
78 else
79 return(1);
80 cm = i;
81 }
82 return(0);
83 }
84
85
86 setequal(os1, os2) /* determine if two sets are equal */
87 register OBJECT *os1, *os2;
88 {
89 register int i;
90
91 for (i = *os1; i-- >= 0; )
92 if (*os1++ != *os2++)
93 return(0);
94 return(1);
95 }
96
97
98 setcopy(os1, os2) /* copy object set os2 into os1 */
99 register OBJECT *os1, *os2;
100 {
101 register int i;
102
103 for (i = *os2; i-- >= 0; )
104 *os1++ = *os2++;
105 }
106
107
108 OCTREE
109 fullnode(oset) /* return octree for object set */
110 OBJECT *oset;
111 {
112 int osentry, ntries;
113 long hval;
114 OCTREE ot;
115 register int i;
116 register OBJECT *os;
117 /* hash on set */
118 hval = 0;
119 os = oset;
120 i = *os++;
121 while (i-- > 0)
122 hval += *os++;
123 ntries = 0;
124 tryagain:
125 osentry = (hval + (long)ntries*ntries) % OSTSIZ;
126 os = ostable[osentry];
127 if (os == NULL) {
128 os = ostable[osentry] = (OBJECT *)malloc(
129 (unsigned)(oset[0]+2)*sizeof(OBJECT));
130 if (os == NULL)
131 goto memerr;
132 ot = oseti(osentry);
133 } else {
134 /* look for set */
135 for (i = 0; *os > 0; i++, os += *os + 1)
136 if (setequal(os, oset))
137 break;
138 ot = oseti(i*OSTSIZ + osentry);
139 if (*os > 0) /* found it */
140 return(ot);
141 if (!isfull(ot)) /* entry overflow */
142 if (++ntries < OSTSIZ)
143 goto tryagain;
144 else
145 error(INTERNAL, "hash table overflow in fullnode");
146 /* remember position */
147 i = os - ostable[osentry];
148 os = ostable[osentry] = (OBJECT *)realloc(
149 (char *)ostable[osentry],
150 (unsigned)(i+oset[0]+2)*sizeof(OBJECT));
151 if (os == NULL)
152 goto memerr;
153 os += i; /* last entry */
154 }
155 setcopy(os, oset); /* add new set */
156 os += *os + 1;
157 *os = 0; /* terminator */
158 return(ot);
159 memerr:
160 error(SYSTEM, "out of memory in fullnode");
161 }
162
163
164 objset(oset, ot) /* get object set for full node */
165 register OBJECT *oset;
166 OCTREE ot;
167 {
168 register OBJECT *os;
169 register int i;
170
171 if (!isfull(ot))
172 goto noderr;
173 i = oseti(ot);
174 if ((os = ostable[i%OSTSIZ]) == NULL)
175 goto noderr;
176 for (i /= OSTSIZ; i--; os += *os + 1)
177 if (*os <= 0)
178 goto noderr;
179 for (i = *os; i-- >= 0; ) /* copy set here */
180 *oset++ = *os++;
181 return;
182 noderr:
183 error(CONSISTENCY, "bad node in objset");
184 }
185
186
187 nonsurfinset(orig, nobjs) /* check sets for non-surfaces */
188 int orig, nobjs;
189 {
190 int n;
191 register OBJECT *os;
192 register OBJECT i, s;
193
194 for (n = 0; n < OSTSIZ; n++) {
195 if ((os = ostable[n]) == NULL)
196 continue;
197 while ((i = *os++) > 0)
198 while (i--) {
199 s = *os;
200 if (s >= orig && s < orig+nobjs &&
201 !issurface(objptr(s)->otype))
202 return(1);
203 os++;
204 }
205 }
206 return(0);
207 }
