root/radiance/ray/src/common/objset.c
Revision: 1.3
Committed: Fri Sep 7 08:32:36 1990 UTC (33 years, 8 months ago) by greg
Changes since 1.2: +9 -27 lines
went back to simpler surfinset(), which is probably faster!
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * objset.c - routines for maintaining object sets.
9 *
10 * 7/28/85
11 */
12
13 #include "standard.h"
14
15 #include "octree.h"
16
17 #include "object.h"
18
19 #include "otypes.h"
20
21 #define OSTSIZ 3037 /* object table size (a prime!) */
22
23 static OBJECT *ostable[OSTSIZ]; /* the object set table */
24
25
26 insertelem(os, obj) /* insert obj into os, no questions */
27 register OBJECT *os;
28 OBJECT obj;
29 {
30 register int i;
31
32 for (i = os[0]++; i > 0; i--)
33 if (os[i] > obj)
34 os[i+1] = os[i];
35 else
36 break;
37 os[i+1] = obj;
38 }
39
40
41 deletelem(os, obj) /* delete obj from os, no questions */
42 register OBJECT *os;
43 OBJECT obj;
44 {
45 register int i;
46
47 for (i = (*os++)--; i > 0 && *os < obj; i--, os++)
48 ;
49 while (--i > 0) {
50 os[0] = os[1];
51 os++;
52 }
53 }
54
55
56 inset(os, obj) /* determine if object is in set */
57 register OBJECT *os;
58 OBJECT obj;
59 {
60 int upper, lower;
61 register int cm, i;
62
63 lower = 1;
64 upper = cm = os[0] + 1;
65
66 while ((i = (lower + upper) >> 1) != cm) {
67 cm = obj - os[i];
68 if (cm > 0)
69 lower = i;
70 else if (cm < 0)
71 upper = i;
72 else
73 return(1);
74 cm = i;
75 }
76 return(0);
77 }
78
79
80 setequal(os1, os2) /* determine if two sets are equal */
81 register OBJECT *os1, *os2;
82 {
83 register int i;
84
85 for (i = *os1; i-- >= 0; )
86 if (*os1++ != *os2++)
87 return(0);
88 return(1);
89 }
90
91
92 setcopy(os1, os2) /* copy object set os2 into os1 */
93 register OBJECT *os1, *os2;
94 {
95 register int i;
96
97 for (i = *os2; i-- >= 0; )
98 *os1++ = *os2++;
99 }
100
101
102 OCTREE
103 fullnode(oset) /* return octree for object set */
104 OBJECT *oset;
105 {
106 int osentry, ntries;
107 long hval;
108 OCTREE ot;
109 register int i;
110 register OBJECT *os;
111 /* hash on set */
112 hval = 0;
113 os = oset;
114 i = *os++;
115 while (i-- > 0)
116 hval += *os++;
117 ntries = 0;
118 tryagain:
119 osentry = (hval + (long)ntries*ntries) % OSTSIZ;
120 os = ostable[osentry];
121 if (os == NULL) {
122 os = ostable[osentry] = (OBJECT *)malloc(
123 (unsigned)(oset[0]+2)*sizeof(OBJECT));
124 if (os == NULL)
125 goto memerr;
126 ot = oseti(osentry);
127 } else {
128 /* look for set */
129 for (i = 0; *os > 0; i++, os += *os + 1)
130 if (setequal(os, oset))
131 break;
132 ot = oseti(i*OSTSIZ + osentry);
133 if (*os > 0) /* found it */
134 return(ot);
135 if (!isfull(ot)) /* entry overflow */
136 if (++ntries < OSTSIZ)
137 goto tryagain;
138 else
139 error(INTERNAL, "hash table overflow in fullnode");
140 /* remember position */
141 i = os - ostable[osentry];
142 os = ostable[osentry] = (OBJECT *)realloc(
143 (char *)ostable[osentry],
144 (unsigned)(i+oset[0]+2)*sizeof(OBJECT));
145 if (os == NULL)
146 goto memerr;
147 os += i; /* last entry */
148 }
149 setcopy(os, oset); /* add new set */
150 os += *os + 1;
151 *os = 0; /* terminator */
152 return(ot);
153 memerr:
154 error(SYSTEM, "out of memory in fullnode");
155 }
156
157
158 objset(oset, ot) /* get object set for full node */
159 register OBJECT *oset;
160 OCTREE ot;
161 {
162 register OBJECT *os;
163 register int i;
164
165 if (!isfull(ot))
166 goto noderr;
167 i = oseti(ot);
168 if ((os = ostable[i%OSTSIZ]) == NULL)
169 goto noderr;
170 for (i /= OSTSIZ; i--; os += *os + 1)
171 if (*os <= 0)
172 goto noderr;
173 for (i = *os; i-- >= 0; ) /* copy set here */
174 *oset++ = *os++;
175 return;
176 noderr:
177 error(CONSISTENCY, "bad node in objset");
178 }
179
180
181 nonsurfinset(orig, nobjs) /* check sets for non-surfaces */
182 int orig, nobjs;
183 {
184 int n;
185 register OBJECT *os;
186 register OBJECT i, t;
187
188 for (n = 0; n < OSTSIZ; n++) {
189 if ((os = ostable[n]) == NULL)
190 continue;
191 while ((i = *os++) > 0)
192 while (i--) {
193 t = *os++;
194 if (t >= orig && t < orig+nobjs) {
195 t = objptr(t)->otype;
196 if (!issurface(t))
197 return(1);
198 }
199 }
200 }
201 return(0);
202 }
