--- ray/src/common/objset.c 2003/10/20 15:10:18 2.14 +++ ray/src/common/objset.c 2006/02/22 17:05:36 2.16 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: objset.c,v 2.14 2003/10/20 15:10:18 greg Exp $"; +static const char RCSid[] = "$Id: objset.c,v 2.16 2006/02/22 17:05:36 greg Exp $"; #endif /* * objset.c - routines for maintaining object sets. @@ -70,7 +70,7 @@ OBJECT obj; int upper, lower; register int cm, i; - if ((i = os[0]) <= 6) { /* linear search algorithm */ + if ((i = os[0]) <= 12) { /* linear search algorithm */ cm = obj; while (i-- > 0) if (*++os == cm) @@ -255,26 +255,6 @@ OCTREE ot; return; noderr: error(CONSISTENCY, "bad node in objset"); -} - - -int -dosets(f) /* loop through all sets */ -int (*f)(); -{ - int res = 0; - int n; - register OBJECT *os; - - for (n = 0; n < OSTSIZ; n++) { - if ((os = ostable[n]) == NULL) - continue; - while (*os > 0) { - res += (*f)(os); - os += *os + 1; - } - } - return(res); }
