root/radiance/ray/src/common/objset.c
Revision: 2.17
Committed: Tue Apr 28 16:56:10 2015 UTC (10 years, 2 months ago) by greg
CVS Tags: rad5R2, rad5R0, rad5R1, rad5R3
Changes since 2.16: +66 -43 lines
Fix for Windows, whose 64-bit long is only 32 bits
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.17 static const char RCSid[] = "$Id: objset.c,v 2.16 2006/02/22 17:05:36 greg Exp $";
3 greg 1.1 #endif
4     /*
5     * objset.c - routines for maintaining object sets.
6     *
7 greg 2.8 * External symbols declared in object.h
8     */
9
10 greg 2.9 #include "copyright.h"
11 greg 1.1
12     #include "standard.h"
13
14     #include "octree.h"
15
16     #include "object.h"
17
18 greg 1.4 #ifndef OSTSIZ
19 greg 2.11 #ifdef SMLMEM
20     #define OSTSIZ 32749 /* object table size (a prime!) */
21     #else
22 gregl 2.5 #define OSTSIZ 262139 /* object table size (a prime!) */
23 greg 1.8 #endif
24 greg 1.4 #endif
25 greg 1.1
26 greg 2.17 #undef xtra_long
27     #ifdef _WIN64
28     typedef unsigned long long int xtra_long;
29     #else
30     typedef unsigned long int xtra_long;
31     #endif
32
33 greg 1.1 static OBJECT *ostable[OSTSIZ]; /* the object set table */
34
35
36 greg 2.8 void
37 greg 2.17 insertelem( /* insert obj into os, no questions */
38     OBJECT *os,
39     OBJECT obj
40     )
41 greg 1.1 {
42 greg 2.17 int i;
43 greg 1.1
44     for (i = os[0]++; i > 0; i--)
45     if (os[i] > obj)
46     os[i+1] = os[i];
47     else
48     break;
49     os[i+1] = obj;
50     }
51
52
53 greg 2.8 void
54 greg 2.17 deletelem( /* delete obj from os, no questions */
55     OBJECT *os,
56     OBJECT obj
57     )
58 greg 1.1 {
59 greg 2.17 int i;
60 greg 1.1
61 greg 1.6 i = (*os)--;
62     os++;
63     while (i > 0 && *os < obj) {
64     i--;
65     os++;
66     }
67 greg 1.1 while (--i > 0) {
68     os[0] = os[1];
69     os++;
70     }
71     }
72
73
74 greg 2.8 int
75 greg 2.17 inset( /* determine if object is in set */
76     OBJECT *os,
77     OBJECT obj
78     )
79 greg 1.1 {
80     int upper, lower;
81 greg 2.17 int cm, i;
82 greg 1.1
83 greg 2.16 if ((i = os[0]) <= 12) { /* linear search algorithm */
84 gwlarson 2.7 cm = obj;
85     while (i-- > 0)
86     if (*++os == cm)
87     return(1);
88     return(0);
89     }
90 greg 1.1 lower = 1;
91 gwlarson 2.7 upper = cm = i + 1;
92 greg 2.4 /* binary search algorithm */
93 greg 1.1 while ((i = (lower + upper) >> 1) != cm) {
94     cm = obj - os[i];
95     if (cm > 0)
96     lower = i;
97     else if (cm < 0)
98     upper = i;
99     else
100     return(1);
101     cm = i;
102     }
103     return(0);
104     }
105
106
107 greg 2.8 int
108 greg 2.17 setequal( /* determine if two sets are equal */
109     OBJECT *os1,
110     OBJECT *os2
111     )
112 greg 1.1 {
113 greg 2.17 int i;
114 greg 1.1
115     for (i = *os1; i-- >= 0; )
116     if (*os1++ != *os2++)
117     return(0);
118     return(1);
119     }
120
121
122 greg 2.8 void
123 greg 2.17 setcopy( /* copy object set os2 into os1 */
124     OBJECT *os1,
125     OBJECT *os2
126     )
127 greg 1.1 {
128 greg 2.17 int i;
129 greg 1.1
130     for (i = *os2; i-- >= 0; )
131     *os1++ = *os2++;
132     }
133
134
135 greg 2.4 OBJECT *
136 greg 2.17 setsave( /* allocate space and save set */
137     OBJECT *os
138     )
139 greg 2.4 {
140     OBJECT *osnew;
141 greg 2.17 OBJECT *oset;
142     int i;
143 greg 2.4
144     if ((osnew = oset = (OBJECT *)malloc((*os+1)*sizeof(OBJECT))) == NULL)
145     error(SYSTEM, "out of memory in setsave\n");
146     for (i = *os; i-- >= 0; ) /* inline setcopy */
147     *oset++ = *os++;
148     return(osnew);
149     }
150
151
152 greg 2.8 void
153 greg 2.17 setunion( /* osr = os1 Union os2 */
154     OBJECT *osr,
155     OBJECT *os1,
156     OBJECT *os2
157     )
158 greg 2.4 {
159 greg 2.17 int i1, i2;
160 greg 2.4
161     osr[0] = 0;
162     for (i1 = i2 = 1; i1 <= os1[0] || i2 <= os2[0]; ) {
163     while (i1 <= os1[0] && (i2 > os2[0] || os1[i1] <= os2[i2])) {
164     osr[++osr[0]] = os1[i1];
165     if (i2 <= os2[0] && os2[i2] == os1[i1])
166     i2++;
167     i1++;
168     }
169     while (i2 <= os2[0] && (i1 > os1[0] || os2[i2] < os1[i1]))
170     osr[++osr[0]] = os2[i2++];
171     }
172     }
173
174
175 greg 2.8 void
176 greg 2.17 setintersect( /* osr = os1 Intersect os2 */
177     OBJECT *osr,
178     OBJECT *os1,
179     OBJECT *os2
180     )
181 greg 2.4 {
182 greg 2.17 int i1, i2;
183 greg 2.4
184     osr[0] = 0;
185     if (os1[0] <= 0)
186     return;
187     for (i1 = i2 = 1; i2 <= os2[0]; ) {
188     while (os1[i1] < os2[i2])
189     if (++i1 > os1[0])
190     return;
191     while (os2[i2] < os1[i1])
192     if (++i2 > os2[0])
193     return;
194     if (os1[i1] == os2[i2])
195     osr[++osr[0]] = os2[i2++];
196     }
197     }
198
199
200 greg 1.1 OCTREE
201 greg 2.17 fullnode( /* return octree for object set */
202     OBJECT *oset
203     )
204 greg 1.1 {
205 greg 2.17 unsigned int ntries;
206     xtra_long hval;
207 greg 1.1 OCTREE ot;
208 greg 2.17 int osentry, i;
209     OBJECT *os;
210 greg 1.1 /* hash on set */
211     hval = 0;
212     os = oset;
213     i = *os++;
214     while (i-- > 0)
215     hval += *os++;
216     ntries = 0;
217     tryagain:
218 greg 2.17 osentry = (hval + (xtra_long)ntries*ntries) % OSTSIZ;
219 greg 1.1 os = ostable[osentry];
220     if (os == NULL) {
221     os = ostable[osentry] = (OBJECT *)malloc(
222     (unsigned)(oset[0]+2)*sizeof(OBJECT));
223     if (os == NULL)
224     goto memerr;
225     ot = oseti(osentry);
226     } else {
227     /* look for set */
228     for (i = 0; *os > 0; i++, os += *os + 1)
229     if (setequal(os, oset))
230     break;
231     ot = oseti(i*OSTSIZ + osentry);
232     if (*os > 0) /* found it */
233     return(ot);
234 schorsch 2.13 if (!isfull(ot)) { /* entry overflow */
235 greg 1.1 if (++ntries < OSTSIZ)
236     goto tryagain;
237     else
238     error(INTERNAL, "hash table overflow in fullnode");
239 schorsch 2.13 }
240 greg 1.1 /* remember position */
241     i = os - ostable[osentry];
242     os = ostable[osentry] = (OBJECT *)realloc(
243 greg 2.10 (void *)ostable[osentry],
244 greg 1.1 (unsigned)(i+oset[0]+2)*sizeof(OBJECT));
245     if (os == NULL)
246     goto memerr;
247     os += i; /* last entry */
248     }
249     setcopy(os, oset); /* add new set */
250     os += *os + 1;
251     *os = 0; /* terminator */
252     return(ot);
253     memerr:
254     error(SYSTEM, "out of memory in fullnode");
255 greg 2.14 return 0; /* pro forma return */
256 greg 1.1 }
257
258
259 greg 2.8 void
260 greg 2.17 objset( /* get object set for full node */
261     OBJECT *oset,
262     OCTREE ot
263     )
264 greg 1.1 {
265 greg 2.17 OBJECT *os;
266     int i;
267 greg 1.1
268     if (!isfull(ot))
269     goto noderr;
270 gwlarson 2.6 ot = oseti(ot);
271     if ((os = ostable[ot%OSTSIZ]) == NULL)
272 greg 1.1 goto noderr;
273 gwlarson 2.6 for (i = ot/OSTSIZ; i--; os += *os + 1)
274 greg 1.1 if (*os <= 0)
275     goto noderr;
276     for (i = *os; i-- >= 0; ) /* copy set here */
277     *oset++ = *os++;
278     return;
279     noderr:
280     error(CONSISTENCY, "bad node in objset");
281 greg 1.2 }
282
283
284 greg 2.8 void
285 greg 2.17 donesets(void) /* free ALL SETS in our table */
286 greg 2.4 {
287 greg 2.17 int n;
288 greg 2.4
289     for (n = 0; n < OSTSIZ; n++)
290     if (ostable[n] != NULL) {
291 greg 2.8 free((void *)ostable[n]);
292 greg 2.4 ostable[n] = NULL;
293     }
294 greg 1.1 }
