root/radiance/ray/src/common/objset.c
Revision: 2.8
Committed: Sat Feb 22 02:07:22 2003 UTC (22 years, 4 months ago) by greg
Changes since 2.7: +69 -6 lines
5 * objset.c - routines for maintaining object sets.
6 *
7 * External symbols declared in object.h
8 */
9
10 /* ====================================================================
11 * The Radiance Software License, Version 1.0
12 *
13 * Copyright (c) 1990 - 2002 The Regents of the University of California,
14 * through Lawrence Berkeley National Laboratory. All rights reserved.
15 *
16 * Redistribution and use in source and binary forms, with or without
17 * modification, are permitted provided that the following conditions
18 * are met:
19 *
20 * 1. Redistributions of source code must retain the above copyright
21 * notice, this list of conditions and the following disclaimer.
22 *
23 * 2. Redistributions in binary form must reproduce the above copyright
24 * notice, this list of conditions and the following disclaimer in
25 * the documentation and/or other materials provided with the
26 * distribution.
27 *
28 * 3. The end-user documentation included with the redistribution,
29 * if any, must include the following acknowledgment:
30 * "This product includes Radiance software
31 * (http://radsite.lbl.gov/)
32 * developed by the Lawrence Berkeley National Laboratory
33 * (http://www.lbl.gov/)."
34 * Alternately, this acknowledgment may appear in the software itself,
35 * if and wherever such third-party acknowledgments normally appear.
36 *
37 * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
38 * and "The Regents of the University of California" must
39 * not be used to endorse or promote products derived from this
40 * software without prior written permission. For written
41 * permission, please contact [email protected].
42 *
43 * 5. Products derived from this software may not be called "Radiance",
44 * nor may "Radiance" appear in their name, without prior written
45 * permission of Lawrence Berkeley National Laboratory.
46 *
47 * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
48 * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
49 * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
50 * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
51 * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
52 * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
53 * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
54 * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
55 * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
56 * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
57 * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
58 * SUCH DAMAGE.
59 * ====================================================================
60 *
61 * This software consists of voluntary contributions made by many
62 * individuals on behalf of Lawrence Berkeley National Laboratory. For more
63 * information on Lawrence Berkeley National Laboratory, please see
64 * <http://www.lbl.gov/>.
65 */
66
67 #include "standard.h"
68
69 #include "octree.h"
70
71 #include "object.h"
72
73 #ifndef OSTSIZ
74 #ifdef BIGMEM
75 #define OSTSIZ 262139 /* object table size (a prime!) */
76 #else
77 #define OSTSIZ 32749 /* object table size (a prime!) */
78 #endif
79 #endif
80
81 static OBJECT *ostable[OSTSIZ]; /* the object set table */
82
83
84 void
85 insertelem(os, obj) /* insert obj into os, no questions */
86 register OBJECT *os;
87 OBJECT obj;
88 {
89 register int i;
90
91 for (i = os[0]++; i > 0; i--)
92 if (os[i] > obj)
93 os[i+1] = os[i];
94 else
95 break;
96 os[i+1] = obj;
97 }
98
99
100 void
101 deletelem(os, obj) /* delete obj from os, no questions */
102 register OBJECT *os;
103 OBJECT obj;
104 {
105 register int i;
106
107 i = (*os)--;
108 os++;
109 while (i > 0 && *os < obj) {
110 i--;
111 os++;
112 }
113 while (--i > 0) {
114 os[0] = os[1];
115 os++;
116 }
117 }
118
119
120 int
121 inset(os, obj) /* determine if object is in set */
122 register OBJECT *os;
123 OBJECT obj;
124 {
125 int upper, lower;
126 register int cm, i;
127
128 if ((i = os[0]) <= 6) { /* linear search algorithm */
129 cm = obj;
130 while (i-- > 0)
131 if (*++os == cm)
132 return(1);
133 return(0);
134 }
135 lower = 1;
136 upper = cm = i + 1;
137 /* binary search algorithm */
138 while ((i = (lower + upper) >> 1) != cm) {
139 cm = obj - os[i];
140 if (cm > 0)
141 lower = i;
142 else if (cm < 0)
143 upper = i;
144 else
145 return(1);
146 cm = i;
147 }
148 return(0);
149 }
150
151
152 int
153 setequal(os1, os2) /* determine if two sets are equal */
154 register OBJECT *os1, *os2;
155 {
156 register int i;
157
158 for (i = *os1; i-- >= 0; )
159 if (*os1++ != *os2++)
160 return(0);
161 return(1);
162 }
163
164
165 void
166 setcopy(os1, os2) /* copy object set os2 into os1 */
167 register OBJECT *os1, *os2;
168 {
169 register int i;
170
171 for (i = *os2; i-- >= 0; )
172 *os1++ = *os2++;
173 }
174
175
176 OBJECT *
177 setsave(os) /* allocate space and save set */
178 register OBJECT *os;
179 {
180 OBJECT *osnew;
181 register OBJECT *oset;
182 register int i;
183
184 if ((osnew = oset = (OBJECT *)malloc((*os+1)*sizeof(OBJECT))) == NULL)
185 error(SYSTEM, "out of memory in setsave\n");
186 for (i = *os; i-- >= 0; ) /* inline setcopy */
187 *oset++ = *os++;
188 return(osnew);
189 }
190
191
192 void
193 setunion(osr, os1, os2) /* osr = os1 Union os2 */
194 register OBJECT *osr, *os1, *os2;
195 {
196 register int i1, i2;
197
198 osr[0] = 0;
199 for (i1 = i2 = 1; i1 <= os1[0] || i2 <= os2[0]; ) {
200 while (i1 <= os1[0] && (i2 > os2[0] || os1[i1] <= os2[i2])) {
201 osr[++osr[0]] = os1[i1];
202 if (i2 <= os2[0] && os2[i2] == os1[i1])
203 i2++;
204 i1++;
205 }
206 while (i2 <= os2[0] && (i1 > os1[0] || os2[i2] < os1[i1]))
207 osr[++osr[0]] = os2[i2++];
208 }
209 }
210
211
212 void
213 setintersect(osr, os1, os2) /* osr = os1 Intersect os2 */
214 register OBJECT *osr, *os1, *os2;
215 {
216 register int i1, i2;
217
218 osr[0] = 0;
219 if (os1[0] <= 0)
220 return;
221 for (i1 = i2 = 1; i2 <= os2[0]; ) {
222 while (os1[i1] < os2[i2])
223 if (++i1 > os1[0])
224 return;
225 while (os2[i2] < os1[i1])
226 if (++i2 > os2[0])
227 return;
228 if (os1[i1] == os2[i2])
229 osr[++osr[0]] = os2[i2++];
230 }
231 }
232
233
234 OCTREE
235 fullnode(oset) /* return octree for object set */
236 OBJECT *oset;
237 {
238 int osentry, ntries;
239 long hval;
240 OCTREE ot;
241 register int i;
242 register OBJECT *os;
243 /* hash on set */
244 hval = 0;
245 os = oset;
246 i = *os++;
247 while (i-- > 0)
248 hval += *os++;
249 ntries = 0;
250 tryagain:
251 osentry = (hval + (long)ntries*ntries) % OSTSIZ;
252 os = ostable[osentry];
253 if (os == NULL) {
254 os = ostable[osentry] = (OBJECT *)malloc(
255 (unsigned)(oset[0]+2)*sizeof(OBJECT));
256 if (os == NULL)
257 goto memerr;
258 ot = oseti(osentry);
259 } else {
260 /* look for set */
261 for (i = 0; *os > 0; i++, os += *os + 1)
262 if (setequal(os, oset))
263 break;
264 ot = oseti(i*OSTSIZ + osentry);
265 if (*os > 0) /* found it */
266 return(ot);
267 if (!isfull(ot)) /* entry overflow */
268 if (++ntries < OSTSIZ)
269 goto tryagain;
270 else
271 error(INTERNAL, "hash table overflow in fullnode");
272 /* remember position */
273 i = os - ostable[osentry];
274 os = ostable[osentry] = (OBJECT *)realloc(
275 (char *)ostable[osentry],
276 (unsigned)(i+oset[0]+2)*sizeof(OBJECT));
277 if (os == NULL)
278 goto memerr;
279 os += i; /* last entry */
280 }
281 setcopy(os, oset); /* add new set */
282 os += *os + 1;
283 *os = 0; /* terminator */
284 return(ot);
285 memerr:
286 error(SYSTEM, "out of memory in fullnode");
287 }
288
289
290 void
291 objset(oset, ot) /* get object set for full node */
292 register OBJECT *oset;
293 OCTREE ot;
294 {
295 register OBJECT *os;
296 register int i;
297
298 if (!isfull(ot))
299 goto noderr;
300 ot = oseti(ot);
301 if ((os = ostable[ot%OSTSIZ]) == NULL)
302 goto noderr;
303 for (i = ot/OSTSIZ; i--; os += *os + 1)
304 if (*os <= 0)
305 goto noderr;
306 for (i = *os; i-- >= 0; ) /* copy set here */
307 *oset++ = *os++;
308 return;
309 noderr:
310 error(CONSISTENCY, "bad node in objset");
311 }
312
313
314 int
315 dosets(f) /* loop through all sets */
316 int (*f)();
317 {
318 int res = 0;
319 int n;
320 register OBJECT *os;
321
322 for (n = 0; n < OSTSIZ; n++) {
323 if ((os = ostable[n]) == NULL)
324 continue;
325 while (*os > 0) {
326 res += (*f)(os);
327 os += *os + 1;
328 }
329 }
330 return(res);
331 }
332
333
334 void
335 donesets() /* free ALL SETS in our table */
336 {
337 register int n;
338
339 for (n = 0; n < OSTSIZ; n++)
340 if (ostable[n] != NULL) {
341 free((void *)ostable[n]);
342 ostable[n] = NULL;
343 }
344 }
