root/radiance/ray/src/common/objset.c
Wed Feb 22 17:05:36 2006 UTC (19 years, 2 months ago) by greg
CVS Tags: rad3R8, rad3R9, rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2
Diff to previous 2.15 , to selected 1.3
Increased trace modifier limit to 8192 in rtrace
Wed Dec 15 22:02:04 2004 UTC (20 years, 4 months ago) by greg
Changes since 2.14: +1 -21 lines
Diff to previous 2.14 , to selected 1.3
Fixed bug that caused inappropriate fatal error mixing meshes and instances
Mon Oct 20 15:10:18 2003 UTC (21 years, 6 months ago) by greg
Diff to previous 2.13 , to selected 1.3
Mon Jul 21 22:30:17 2003 UTC (21 years, 9 months ago) by schorsch
Diff to previous 2.12 , to selected 1.3
Sat Jun 7 12:50:20 2003 UTC (21 years, 11 months ago) by schorsch
Diff to previous 2.11 , to selected 1.3
Thu May 15 05:13:35 2003 UTC (21 years, 11 months ago) by greg
Diff to previous 2.10 , to selected 1.3
Wed Apr 23 00:52:33 2003 UTC (22 years ago) by greg
Diff to previous 2.9 , to selected 1.3
Tue Feb 25 02:47:21 2003 UTC (22 years, 2 months ago) by greg
Diff to previous 2.8 , to selected 1.3
Sat Feb 22 02:07:22 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.7: +69 -6 lines
Diff to previous 2.7 , to selected 1.3
Fri Sep 11 15:26:43 1998 UTC (26 years, 7 months ago) by gwlarson
Changes since 2.6: +8 -1 lines
Diff to previous 2.6 , to selected 1.3
added linear search for small sets in inset()
Tue Aug 18 17:18:51 1998 UTC (26 years, 8 months ago) by gwlarson
Diff to previous 2.5 , to selected 1.3
fixed potential integer size problem in objset()
Wed Dec 3 11:14:00 1997 UTC (27 years, 5 months ago) by gregl
Diff to previous 2.4 , to selected 1.3
increased table sizes
Fri Mar 7 15:45:28 1997 UTC (28 years, 2 months ago) by greg
Changes since 2.3: +78 -13 lines
Diff to previous 2.3 , to selected 1.3
added new set routines
Mon Jul 13 14:23:21 1992 UTC (32 years, 9 months ago) by greg
Changes since 2.2: +3 -5 lines
Diff to previous 2.2 , to selected 1.3
slight improvement in nonsurfinset()
Thu Mar 12 11:41:18 1992 UTC (33 years, 1 month ago) by greg
Diff to previous 2.1 , to selected 1.3
volumes are no longer surfaces
Tue Nov 12 16:54:35 1991 UTC (33 years, 5 months ago) by greg
Diff to previous 1.8 , to selected 1.3
Wed Oct 23 11:52:55 1991 UTC (33 years, 6 months ago) by greg
Changes since 1.7: +4 -0 lines
Diff to previous 1.7 , to selected 1.3
added conditional sizing of structures from BIGMEM
Fri May 10 10:37:14 1991 UTC (34 years ago) by greg
Changes since 1.6: +4 -3 lines
Diff to previous 1.6 , to selected 1.3
added register variable to nonsurfinset()
Fri Dec 14 10:06:33 1990 UTC (34 years, 4 months ago) by greg
Changes since 1.5: +6 -2 lines
Diff to previous 1.5 , to selected 1.3
removed code associated with A/UX compiler bug
Thu Dec 13 11:39:07 1990 UTC (34 years, 4 months ago) by greg
Changes since 1.4: +5 -7 lines
Diff to previous 1.4 , to selected 1.3
minor optimization in nonsurfinset()
Wed Sep 19 08:26:02 1990 UTC (34 years, 7 months ago) by greg
Diff to previous 1.3
increased OSTSIZ for efficient conversion of large models
Revision 1.3 - (view) (download) (annotate) - [selected]
Fri Sep 7 08:32:36 1990 UTC (34 years, 8 months ago) by greg
Changes since 1.2: +9 -27 lines
Diff to previous 1.2
went back to simpler surfinset(), which is probably faster!
Thu Sep 6 23:32:41 1990 UTC (34 years, 8 months ago) by greg
Changes since 1.1: +44 -0 lines
Diff to previous 1.1 , to selected 1.3
added consistency checks to detect stale octrees
Thu Feb 2 10:34:37 1989 UTC (36 years, 3 months ago) by greg
Diff to selected 1.3
