root/Development/ray/src/common/objset.c
Revision: 2.15
Committed: Wed Dec 15 22:02:04 2004 UTC (21 years ago) by greg
CVS Tags: rad3R7P2, rad3R7P1
Changes since 2.14: +1 -21 lines
Fixed bug that caused inappropriate fatal error mixing meshes and instances
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.15 static const char RCSid[] = "$Id: objset.c,v 2.14 2003/10/20 15:10:18 greg Exp $";
3 greg 1.1 #endif
4     /*
5     * objset.c - routines for maintaining object sets.
6     *
7 greg 2.8 * External symbols declared in object.h
8     */
9
10 greg 2.9 #include "copyright.h"
11 greg 1.1
12     #include "standard.h"
13
14     #include "octree.h"
15
16     #include "object.h"
17
18 greg 1.4 #ifndef OSTSIZ
19 greg 2.11 #ifdef SMLMEM
20     #define OSTSIZ 32749 /* object table size (a prime!) */
21     #else
22 gregl 2.5 #define OSTSIZ 262139 /* object table size (a prime!) */
23 greg 1.8 #endif
24 greg 1.4 #endif
25 greg 1.1
26     static OBJECT *ostable[OSTSIZ]; /* the object set table */
27
28
29 greg 2.8 void
30 greg 1.1 insertelem(os, obj) /* insert obj into os, no questions */
31     register OBJECT *os;
32     OBJECT obj;
33     {
34     register int i;
35
36     for (i = os[0]++; i > 0; i--)
37     if (os[i] > obj)
38     os[i+1] = os[i];
39     else
40     break;
41     os[i+1] = obj;
42     }
43
44
45 greg 2.8 void
46 greg 1.1 deletelem(os, obj) /* delete obj from os, no questions */
47     register OBJECT *os;
48     OBJECT obj;
49     {
50     register int i;
51
52 greg 1.6 i = (*os)--;
53     os++;
54     while (i > 0 && *os < obj) {
55     i--;
56     os++;
57     }
58 greg 1.1 while (--i > 0) {
59     os[0] = os[1];
60     os++;
61     }
62     }
63
64
65 greg 2.8 int
66 greg 1.1 inset(os, obj) /* determine if object is in set */
67     register OBJECT *os;
68     OBJECT obj;
69     {
70     int upper, lower;
71     register int cm, i;
72
73 gwlarson 2.7 if ((i = os[0]) <= 6) { /* linear search algorithm */
74     cm = obj;
75     while (i-- > 0)
76     if (*++os == cm)
77     return(1);
78     return(0);
79     }
80 greg 1.1 lower = 1;
81 gwlarson 2.7 upper = cm = i + 1;
82 greg 2.4 /* binary search algorithm */
83 greg 1.1 while ((i = (lower + upper) >> 1) != cm) {
84     cm = obj - os[i];
85     if (cm > 0)
86     lower = i;
87     else if (cm < 0)
88     upper = i;
89     else
90     return(1);
91     cm = i;
92     }
93     return(0);
94     }
95
96
97 greg 2.8 int
98 greg 1.1 setequal(os1, os2) /* determine if two sets are equal */
99     register OBJECT *os1, *os2;
100     {
101     register int i;
102
103     for (i = *os1; i-- >= 0; )
104     if (*os1++ != *os2++)
105     return(0);
106     return(1);
107     }
108
109
110 greg 2.8 void
111 greg 1.1 setcopy(os1, os2) /* copy object set os2 into os1 */
112     register OBJECT *os1, *os2;
113     {
114     register int i;
115
116     for (i = *os2; i-- >= 0; )
117     *os1++ = *os2++;
118     }
119
120
121 greg 2.4 OBJECT *
122     setsave(os) /* allocate space and save set */
123     register OBJECT *os;
124     {
125     OBJECT *osnew;
126     register OBJECT *oset;
127     register int i;
128
129     if ((osnew = oset = (OBJECT *)malloc((*os+1)*sizeof(OBJECT))) == NULL)
130     error(SYSTEM, "out of memory in setsave\n");
131     for (i = *os; i-- >= 0; ) /* inline setcopy */
132     *oset++ = *os++;
133     return(osnew);
134     }
135
136
137 greg 2.8 void
138 greg 2.4 setunion(osr, os1, os2) /* osr = os1 Union os2 */
139     register OBJECT *osr, *os1, *os2;
140     {
141     register int i1, i2;
142
143     osr[0] = 0;
144     for (i1 = i2 = 1; i1 <= os1[0] || i2 <= os2[0]; ) {
145     while (i1 <= os1[0] && (i2 > os2[0] || os1[i1] <= os2[i2])) {
146     osr[++osr[0]] = os1[i1];
147     if (i2 <= os2[0] && os2[i2] == os1[i1])
148     i2++;
149     i1++;
150     }
151     while (i2 <= os2[0] && (i1 > os1[0] || os2[i2] < os1[i1]))
152     osr[++osr[0]] = os2[i2++];
153     }
154     }
155
156
157 greg 2.8 void
158 greg 2.4 setintersect(osr, os1, os2) /* osr = os1 Intersect os2 */
159     register OBJECT *osr, *os1, *os2;
160     {
161     register int i1, i2;
162
163     osr[0] = 0;
164     if (os1[0] <= 0)
165     return;
166     for (i1 = i2 = 1; i2 <= os2[0]; ) {
167     while (os1[i1] < os2[i2])
168     if (++i1 > os1[0])
169     return;
170     while (os2[i2] < os1[i1])
171     if (++i2 > os2[0])
172     return;
173     if (os1[i1] == os2[i2])
174     osr[++osr[0]] = os2[i2++];
175     }
176     }
177
178
179 greg 1.1 OCTREE
180     fullnode(oset) /* return octree for object set */
181     OBJECT *oset;
182     {
183     int osentry, ntries;
184     long hval;
185     OCTREE ot;
186     register int i;
187     register OBJECT *os;
188     /* hash on set */
189     hval = 0;
190     os = oset;
191     i = *os++;
192     while (i-- > 0)
193     hval += *os++;
194     ntries = 0;
195     tryagain:
196     osentry = (hval + (long)ntries*ntries) % OSTSIZ;
197     os = ostable[osentry];
198     if (os == NULL) {
199     os = ostable[osentry] = (OBJECT *)malloc(
200     (unsigned)(oset[0]+2)*sizeof(OBJECT));
201     if (os == NULL)
202     goto memerr;
203     ot = oseti(osentry);
204     } else {
205     /* look for set */
206     for (i = 0; *os > 0; i++, os += *os + 1)
207     if (setequal(os, oset))
208     break;
209     ot = oseti(i*OSTSIZ + osentry);
210     if (*os > 0) /* found it */
211     return(ot);
212 schorsch 2.13 if (!isfull(ot)) { /* entry overflow */
213 greg 1.1 if (++ntries < OSTSIZ)
214     goto tryagain;
215     else
216     error(INTERNAL, "hash table overflow in fullnode");
217 schorsch 2.13 }
218 greg 1.1 /* remember position */
219     i = os - ostable[osentry];
220     os = ostable[osentry] = (OBJECT *)realloc(
221 greg 2.10 (void *)ostable[osentry],
222 greg 1.1 (unsigned)(i+oset[0]+2)*sizeof(OBJECT));
223     if (os == NULL)
224     goto memerr;
225     os += i; /* last entry */
226     }
227     setcopy(os, oset); /* add new set */
228     os += *os + 1;
229     *os = 0; /* terminator */
230     return(ot);
231     memerr:
232     error(SYSTEM, "out of memory in fullnode");
233 greg 2.14 return 0; /* pro forma return */
234 greg 1.1 }
235
236
237 greg 2.8 void
238 greg 1.1 objset(oset, ot) /* get object set for full node */
239     register OBJECT *oset;
240     OCTREE ot;
241     {
242     register OBJECT *os;
243     register int i;
244
245     if (!isfull(ot))
246     goto noderr;
247 gwlarson 2.6 ot = oseti(ot);
248     if ((os = ostable[ot%OSTSIZ]) == NULL)
249 greg 1.1 goto noderr;
250 gwlarson 2.6 for (i = ot/OSTSIZ; i--; os += *os + 1)
251 greg 1.1 if (*os <= 0)
252     goto noderr;
253     for (i = *os; i-- >= 0; ) /* copy set here */
254     *oset++ = *os++;
255     return;
256     noderr:
257     error(CONSISTENCY, "bad node in objset");
258 greg 1.2 }
259
260
261 greg 2.8 void
262 greg 2.4 donesets() /* free ALL SETS in our table */
263     {
264     register int n;
265
266     for (n = 0; n < OSTSIZ; n++)
267     if (ostable[n] != NULL) {
268 greg 2.8 free((void *)ostable[n]);
269 greg 2.4 ostable[n] = NULL;
270     }
271 greg 1.1 }
