--- ray/src/common/objset.c 1992/07/13 14:23:21 2.3 +++ ray/src/common/objset.c 2003/04/23 00:52:33 2.10 @@ -1,34 +1,32 @@ -/* Copyright (c) 1986 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: objset.c,v 2.10 2003/04/23 00:52:33 greg Exp $"; #endif - /* * objset.c - routines for maintaining object sets. * - * 7/28/85 + * External symbols declared in object.h */ +#include "copyright.h" + #include "standard.h" #include "octree.h" #include "object.h" -#include "otypes.h" - #ifndef OSTSIZ #ifdef BIGMEM -#define OSTSIZ 56437 /* object table size (a prime!) */ +#define OSTSIZ 262139 /* object table size (a prime!) */ #else -#define OSTSIZ 12329 /* object table size (a prime!) */ +#define OSTSIZ 32749 /* object table size (a prime!) */ #endif #endif static OBJECT *ostable[OSTSIZ]; /* the object set table */ +void insertelem(os, obj) /* insert obj into os, no questions */ register OBJECT *os; OBJECT obj; @@ -44,6 +42,7 @@ OBJECT obj; } +void deletelem(os, obj) /* delete obj from os, no questions */ register OBJECT *os; OBJECT obj; @@ -63,6 +62,7 @@ OBJECT obj; } +int inset(os, obj) /* determine if object is in set */ register OBJECT *os; OBJECT obj; @@ -70,9 +70,16 @@ OBJECT obj; int upper, lower; register int cm, i; + if ((i = os[0]) <= 6) { /* linear search algorithm */ + cm = obj; + while (i-- > 0) + if (*++os == cm) + return(1); + return(0); + } lower = 1; - upper = cm = os[0] + 1; - + upper = cm = i + 1; + /* binary search algorithm */ while ((i = (lower + upper) >> 1) != cm) { cm = obj - os[i]; if (cm > 0) @@ -87,6 +94,7 @@ OBJECT obj; } +int setequal(os1, os2) /* determine if two sets are equal */ register OBJECT *os1, *os2; { @@ -99,6 +107,7 @@ register OBJECT *os1, *os2; } +void setcopy(os1, os2) /* copy object set os2 into os1 */ register OBJECT *os1, *os2; { @@ -109,6 +118,64 @@ register OBJECT *os1, *os2; } +OBJECT * +setsave(os) /* allocate space and save set */ +register OBJECT *os; +{ + OBJECT *osnew; + register OBJECT *oset; + register int i; + + if ((osnew = oset = (OBJECT *)malloc((*os+1)*sizeof(OBJECT))) == NULL) + error(SYSTEM, "out of memory in setsave\n"); + for (i = *os; i-- >= 0; ) /* inline setcopy */ + *oset++ = *os++; + return(osnew); +} + + +void +setunion(osr, os1, os2) /* osr = os1 Union os2 */ +register OBJECT *osr, *os1, *os2; +{ + register int i1, i2; + + osr[0] = 0; + for (i1 = i2 = 1; i1 <= os1[0] || i2 <= os2[0]; ) { + while (i1 <= os1[0] && (i2 > os2[0] || os1[i1] <= os2[i2])) { + osr[++osr[0]] = os1[i1]; + if (i2 <= os2[0] && os2[i2] == os1[i1]) + i2++; + i1++; + } + while (i2 <= os2[0] && (i1 > os1[0] || os2[i2] < os1[i1])) + osr[++osr[0]] = os2[i2++]; + } +} + + +void +setintersect(osr, os1, os2) /* osr = os1 Intersect os2 */ +register OBJECT *osr, *os1, *os2; +{ + register int i1, i2; + + osr[0] = 0; + if (os1[0] <= 0) + return; + for (i1 = i2 = 1; i2 <= os2[0]; ) { + while (os1[i1] < os2[i2]) + if (++i1 > os1[0]) + return; + while (os2[i2] < os1[i1]) + if (++i2 > os2[0]) + return; + if (os1[i1] == os2[i2]) + osr[++osr[0]] = os2[i2++]; + } +} + + OCTREE fullnode(oset) /* return octree for object set */ OBJECT *oset; @@ -150,7 +217,7 @@ tryagain: /* remember position */ i = os - ostable[osentry]; os = ostable[osentry] = (OBJECT *)realloc( - (char *)ostable[osentry], + (void *)ostable[osentry], (unsigned)(i+oset[0]+2)*sizeof(OBJECT)); if (os == NULL) goto memerr; @@ -165,6 +232,7 @@ memerr: } +void objset(oset, ot) /* get object set for full node */ register OBJECT *oset; OCTREE ot; @@ -174,10 +242,10 @@ OCTREE ot; if (!isfull(ot)) goto noderr; - i = oseti(ot); - if ((os = ostable[i%OSTSIZ]) == NULL) + ot = oseti(ot); + if ((os = ostable[ot%OSTSIZ]) == NULL) goto noderr; - for (i /= OSTSIZ; i--; os += *os + 1) + for (i = ot/OSTSIZ; i--; os += *os + 1) if (*os <= 0) goto noderr; for (i = *os; i-- >= 0; ) /* copy set here */ @@ -188,22 +256,34 @@ noderr: } -nonsurfinset(orig, nobjs) /* check sets for non-surfaces */ -int orig, nobjs; +int +dosets(f) /* loop through all sets */ +int (*f)(); { + int res = 0; int n; register OBJECT *os; - register OBJECT i, s; for (n = 0; n < OSTSIZ; n++) { if ((os = ostable[n]) == NULL) continue; - while ((i = *os++) > 0) - do - if ((s = *os++) >= orig && s < orig+nobjs && - ismodifier(objptr(s)->otype)) - return(1); - while (--i); + while (*os > 0) { + res += (*f)(os); + os += *os + 1; + } } - return(0); + return(res); +} + + +void +donesets() /* free ALL SETS in our table */ +{ + register int n; + + for (n = 0; n < OSTSIZ; n++) + if (ostable[n] != NULL) { + free((void *)ostable[n]); + ostable[n] = NULL; + } }
