Fixed bug that caused inappropriate fatal error mixing meshes and instances
Eliminated copystruct() macro, which is unnecessary in ANSI. Reduced ambiguity warnings for nested if/if/else clauses.
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
added linear search for small sets in inset()
fixed potential integer size problem in objset()
increased table sizes
added new set routines
slight improvement in nonsurfinset()
volumes are no longer surfaces
added conditional sizing of structures from BIGMEM
added register variable to nonsurfinset()
removed code associated with A/UX compiler bug
minor optimization in nonsurfinset()
increased OSTSIZ for efficient conversion of large models
went back to simpler surfinset(), which is probably faster!
added consistency checks to detect stale octrees
