--- ray/src/common/objset.c 1992/03/12 11:41:18 2.2 +++ ray/src/common/objset.c 1997/03/07 15:45:28 2.4 @@ -16,8 +16,6 @@ static char SCCSid[] = "$SunId$ LBL"; #include "object.h" -#include "otypes.h" - #ifndef OSTSIZ #ifdef BIGMEM #define OSTSIZ 56437 /* object table size (a prime!) */ @@ -72,7 +70,7 @@ OBJECT obj; lower = 1; upper = cm = os[0] + 1; - + /* binary search algorithm */ while ((i = (lower + upper) >> 1) != cm) { cm = obj - os[i]; if (cm > 0) @@ -109,6 +107,62 @@ register OBJECT *os1, *os2; } +OBJECT * +setsave(os) /* allocate space and save set */ +register OBJECT *os; +{ + OBJECT *osnew; + register OBJECT *oset; + register int i; + + if ((osnew = oset = (OBJECT *)malloc((*os+1)*sizeof(OBJECT))) == NULL) + error(SYSTEM, "out of memory in setsave\n"); + for (i = *os; i-- >= 0; ) /* inline setcopy */ + *oset++ = *os++; + return(osnew); +} + + +setunion(osr, os1, os2) /* osr = os1 Union os2 */ +register OBJECT *osr, *os1, *os2; +{ + register int i1, i2; + + osr[0] = 0; + for (i1 = i2 = 1; i1 <= os1[0] || i2 <= os2[0]; ) { + while (i1 <= os1[0] && (i2 > os2[0] || os1[i1] <= os2[i2])) { + osr[++osr[0]] = os1[i1]; + if (i2 <= os2[0] && os2[i2] == os1[i1]) + i2++; + i1++; + } + while (i2 <= os2[0] && (i1 > os1[0] || os2[i2] < os1[i1])) + osr[++osr[0]] = os2[i2++]; + } +} + + +setintersect(osr, os1, os2) /* osr = os1 Intersect os2 */ +register OBJECT *osr, *os1, *os2; +{ + register int i1, i2; + + osr[0] = 0; + if (os1[0] <= 0) + return; + for (i1 = i2 = 1; i2 <= os2[0]; ) { + while (os1[i1] < os2[i2]) + if (++i1 > os1[0]) + return; + while (os2[i2] < os1[i1]) + if (++i2 > os2[0]) + return; + if (os1[i1] == os2[i2]) + osr[++osr[0]] = os2[i2++]; + } +} + + OCTREE fullnode(oset) /* return octree for object set */ OBJECT *oset; @@ -188,24 +242,33 @@ noderr: } -nonsurfinset(orig, nobjs) /* check sets for non-surfaces */ -int orig, nobjs; +int +dosets(f) /* loop through all sets */ +int (*f)(); { + int res = 0; int n; register OBJECT *os; - register OBJECT i, s; for (n = 0; n < OSTSIZ; n++) { if ((os = ostable[n]) == NULL) continue; - while ((i = *os++) > 0) - while (i--) { - s = *os; - if (s >= orig && s < orig+nobjs && - ismodifier(objptr(s)->otype)) - return(1); - os++; - } + while (*os > 0) { + res += (*f)(os); + os += *os + 1; + } } - return(0); + return(res); +} + + +donesets() /* free ALL SETS in our table */ +{ + register int n; + + for (n = 0; n < OSTSIZ; n++) + if (ostable[n] != NULL) { + free((char *)ostable[n]); + ostable[n] = NULL; + } }
