--- ray/src/common/objset.c 1998/09/11 15:26:43 2.7 +++ ray/src/common/objset.c 2004/12/15 22:02:04 2.15 @@ -1,15 +1,14 @@ -/* Copyright (c) 1986 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: objset.c,v 2.15 2004/12/15 22:02:04 greg Exp $"; #endif - /* * objset.c - routines for maintaining object sets. * - * 7/28/85 + * External symbols declared in object.h */ +#include "copyright.h" + #include "standard.h" #include "octree.h" @@ -17,16 +16,17 @@ static char SCCSid[] = "$SunId$ LBL"; #include "object.h" #ifndef OSTSIZ -#ifdef BIGMEM -#define OSTSIZ 262139 /* object table size (a prime!) */ -#else +#ifdef SMLMEM #define OSTSIZ 32749 /* object table size (a prime!) */ +#else +#define OSTSIZ 262139 /* object table size (a prime!) */ #endif #endif static OBJECT *ostable[OSTSIZ]; /* the object set table */ +void insertelem(os, obj) /* insert obj into os, no questions */ register OBJECT *os; OBJECT obj; @@ -42,6 +42,7 @@ OBJECT obj; } +void deletelem(os, obj) /* delete obj from os, no questions */ register OBJECT *os; OBJECT obj; @@ -61,6 +62,7 @@ OBJECT obj; } +int inset(os, obj) /* determine if object is in set */ register OBJECT *os; OBJECT obj; @@ -92,6 +94,7 @@ OBJECT obj; } +int setequal(os1, os2) /* determine if two sets are equal */ register OBJECT *os1, *os2; { @@ -104,6 +107,7 @@ register OBJECT *os1, *os2; } +void setcopy(os1, os2) /* copy object set os2 into os1 */ register OBJECT *os1, *os2; { @@ -130,6 +134,7 @@ register OBJECT *os; } +void setunion(osr, os1, os2) /* osr = os1 Union os2 */ register OBJECT *osr, *os1, *os2; { @@ -149,6 +154,7 @@ register OBJECT *osr, *os1, *os2; } +void setintersect(osr, os1, os2) /* osr = os1 Intersect os2 */ register OBJECT *osr, *os1, *os2; { @@ -203,15 +209,16 @@ tryagain: ot = oseti(i*OSTSIZ + osentry); if (*os > 0) /* found it */ return(ot); - if (!isfull(ot)) /* entry overflow */ + if (!isfull(ot)) { /* entry overflow */ if (++ntries < OSTSIZ) goto tryagain; else error(INTERNAL, "hash table overflow in fullnode"); + } /* remember position */ i = os - ostable[osentry]; os = ostable[osentry] = (OBJECT *)realloc( - (char *)ostable[osentry], + (void *)ostable[osentry], (unsigned)(i+oset[0]+2)*sizeof(OBJECT)); if (os == NULL) goto memerr; @@ -223,9 +230,11 @@ tryagain: return(ot); memerr: error(SYSTEM, "out of memory in fullnode"); + return 0; /* pro forma return */ } +void objset(oset, ot) /* get object set for full node */ register OBJECT *oset; OCTREE ot; @@ -249,33 +258,14 @@ noderr: } -int -dosets(f) /* loop through all sets */ -int (*f)(); -{ - int res = 0; - int n; - register OBJECT *os; - - for (n = 0; n < OSTSIZ; n++) { - if ((os = ostable[n]) == NULL) - continue; - while (*os > 0) { - res += (*f)(os); - os += *os + 1; - } - } - return(res); -} - - +void donesets() /* free ALL SETS in our table */ { register int n; for (n = 0; n < OSTSIZ; n++) if (ostable[n] != NULL) { - free((char *)ostable[n]); + free((void *)ostable[n]); ostable[n] = NULL; } }
