root/radiance/ray/src/common/objset.c
Revision: 1.1
Committed: Thu Feb 2 10:34:37 1989 UTC (36 years, 6 months ago) by greg
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * objset.c - routines for maintaining object sets.
9 *
10 * 7/28/85
11 */
12
13 #include "standard.h"
14
15 #include "octree.h"
16
17 #include "object.h"
18
19 #define OSTSIZ 3037 /* object table size (a prime!) */
20
21 static OBJECT *ostable[OSTSIZ]; /* the object set table */
22
23
24 insertelem(os, obj) /* insert obj into os, no questions */
25 register OBJECT *os;
26 OBJECT obj;
27 {
28 register int i;
29
30 for (i = os[0]++; i > 0; i--)
31 if (os[i] > obj)
32 os[i+1] = os[i];
33 else
34 break;
35 os[i+1] = obj;
36 }
37
38
39 deletelem(os, obj) /* delete obj from os, no questions */
40 register OBJECT *os;
41 OBJECT obj;
42 {
43 register int i;
44
45 for (i = (*os++)--; i > 0 && *os < obj; i--, os++)
46 ;
47 while (--i > 0) {
48 os[0] = os[1];
49 os++;
50 }
51 }
52
53
54 inset(os, obj) /* determine if object is in set */
55 register OBJECT *os;
56 OBJECT obj;
57 {
58 int upper, lower;
59 register int cm, i;
60
61 lower = 1;
62 upper = cm = os[0] + 1;
63
64 while ((i = (lower + upper) >> 1) != cm) {
65 cm = obj - os[i];
66 if (cm > 0)
67 lower = i;
68 else if (cm < 0)
69 upper = i;
70 else
71 return(1);
72 cm = i;
73 }
74 return(0);
75 }
76
77
78 setequal(os1, os2) /* determine if two sets are equal */
79 register OBJECT *os1, *os2;
80 {
81 register int i;
82
83 for (i = *os1; i-- >= 0; )
84 if (*os1++ != *os2++)
85 return(0);
86 return(1);
87 }
88
89
90 setcopy(os1, os2) /* copy object set os2 into os1 */
91 register OBJECT *os1, *os2;
92 {
93 register int i;
94
95 for (i = *os2; i-- >= 0; )
96 *os1++ = *os2++;
97 }
98
99
100 OCTREE
101 fullnode(oset) /* return octree for object set */
102 OBJECT *oset;
103 {
104 int osentry, ntries;
105 long hval;
106 OCTREE ot;
107 register int i;
108 register OBJECT *os;
109 /* hash on set */
110 hval = 0;
111 os = oset;
112 i = *os++;
113 while (i-- > 0)
114 hval += *os++;
115 ntries = 0;
116 tryagain:
117 osentry = (hval + (long)ntries*ntries) % OSTSIZ;
118 os = ostable[osentry];
119 if (os == NULL) {
120 os = ostable[osentry] = (OBJECT *)malloc(
121 (unsigned)(oset[0]+2)*sizeof(OBJECT));
122 if (os == NULL)
123 goto memerr;
124 ot = oseti(osentry);
125 } else {
126 /* look for set */
127 for (i = 0; *os > 0; i++, os += *os + 1)
128 if (setequal(os, oset))
129 break;
130 ot = oseti(i*OSTSIZ + osentry);
131 if (*os > 0) /* found it */
132 return(ot);
133 if (!isfull(ot)) /* entry overflow */
134 if (++ntries < OSTSIZ)
135 goto tryagain;
136 else
137 error(INTERNAL, "hash table overflow in fullnode");
138 /* remember position */
139 i = os - ostable[osentry];
140 os = ostable[osentry] = (OBJECT *)realloc(
141 (char *)ostable[osentry],
142 (unsigned)(i+oset[0]+2)*sizeof(OBJECT));
143 if (os == NULL)
144 goto memerr;
145 os += i; /* last entry */
146 }
147 setcopy(os, oset); /* add new set */
148 os += *os + 1;
149 *os = 0; /* terminator */
150 return(ot);
151 memerr:
152 error(SYSTEM, "out of memory in fullnode");
153 }
154
155
156 objset(oset, ot) /* get object set for full node */
157 register OBJECT *oset;
158 OCTREE ot;
159 {
160 register OBJECT *os;
161 register int i;
162
163 if (!isfull(ot))
164 goto noderr;
165 i = oseti(ot);
166 if ((os = ostable[i%OSTSIZ]) == NULL)
167 goto noderr;
168 for (i /= OSTSIZ; i--; os += *os + 1)
169 if (*os <= 0)
170 goto noderr;
171 for (i = *os; i-- >= 0; ) /* copy set here */
172 *oset++ = *os++;
173 return;
174 noderr:
175 error(CONSISTENCY, "bad node in objset");
176 }
