1 |
/* RCSid: $Id$ */ |
2 |
3 |
* object.h - header file for routines using objects and object sets. |
4 |
5 |
6 |
7 |
* The Radiance Software License, Version 1.0 |
8 |
9 |
* Copyright (c) 1990 - 2002 The Regents of the University of California, |
10 |
* through Lawrence Berkeley National Laboratory. All rights reserved. |
11 |
12 |
* Redistribution and use in source and binary forms, with or without |
13 |
* modification, are permitted provided that the following conditions |
14 |
* are met: |
15 |
16 |
* 1. Redistributions of source code must retain the above copyright |
17 |
* notice, this list of conditions and the following disclaimer. |
18 |
19 |
* 2. Redistributions in binary form must reproduce the above copyright |
20 |
* notice, this list of conditions and the following disclaimer in |
21 |
* the documentation and/or other materials provided with the |
22 |
* distribution. |
23 |
24 |
* 3. The end-user documentation included with the redistribution, |
25 |
* if any, must include the following acknowledgment: |
26 |
* "This product includes Radiance software |
27 |
* (http://radsite.lbl.gov/) |
28 |
* developed by the Lawrence Berkeley National Laboratory |
29 |
* (http://www.lbl.gov/)." |
30 |
* Alternately, this acknowledgment may appear in the software itself, |
31 |
* if and wherever such third-party acknowledgments normally appear. |
32 |
33 |
* 4. The names "Radiance," "Lawrence Berkeley National Laboratory" |
34 |
* and "The Regents of the University of California" must |
35 |
* not be used to endorse or promote products derived from this |
36 |
* software without prior written permission. For written |
37 |
* permission, please contact [email protected]. |
38 |
39 |
* 5. Products derived from this software may not be called "Radiance", |
40 |
* nor may "Radiance" appear in their name, without prior written |
41 |
* permission of Lawrence Berkeley National Laboratory. |
42 |
43 |
* THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED |
44 |
* WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES |
45 |
* OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE |
46 |
* DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR |
47 |
* ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, |
48 |
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT |
49 |
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF |
50 |
* USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND |
51 |
* ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, |
52 |
* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT |
53 |
* OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF |
54 |
* SUCH DAMAGE. |
55 |
56 |
57 |
* This software consists of voluntary contributions made by many |
58 |
* individuals on behalf of Lawrence Berkeley National Laboratory. For more |
59 |
* information on Lawrence Berkeley National Laboratory, please see |
60 |
* <http://www.lbl.gov/>. |
61 |
62 |
63 |
#ifndef OCTREE |
64 |
#define OCTREE int |
65 |
#endif |
66 |
67 |
68 |
* Object definitions require general specifications |
69 |
* which may include a number of different argument types. |
70 |
* The following structure aids in the storage of such |
71 |
* argument lists. |
72 |
73 |
74 |
typedef struct { |
75 |
short nsargs; /* # of string arguments */ |
76 |
short nfargs; /* # of real arguments */ |
77 |
char **sarg; /* string arguments */ |
78 |
FLOAT *farg; /* real arguments */ |
79 |
#ifdef IARGS |
80 |
short niargs; /* # of integer arguments */ |
81 |
long *iarg; /* integer arguments */ |
82 |
#endif |
83 |
} FUNARGS; |
84 |
85 |
#define MAXSTR 128 /* maximum string length */ |
86 |
87 |
88 |
* An object is defined as an index into an array of |
89 |
* structures containing the object type and specification |
90 |
* and the modifier index. |
91 |
92 |
93 |
#ifndef OBJECT |
94 |
#ifdef BIGMEM |
95 |
#define OBJECT int4 /* index to object array */ |
96 |
#else |
97 |
#define OBJECT int2 /* index to object array */ |
98 |
#endif |
99 |
#endif |
100 |
101 |
typedef struct { |
102 |
OBJECT omod; /* modifier number */ |
103 |
short otype; /* object type number */ |
104 |
char *oname; /* object name */ |
105 |
FUNARGS oargs; /* object specification */ |
106 |
char *os; /* object structure */ |
107 |
} OBJREC; |
108 |
109 |
#ifndef MAXOBJBLK |
110 |
#ifdef BIGMEM |
111 |
#define MAXOBJBLK 65535 /* maximum number of object blocks */ |
112 |
#else |
113 |
#define MAXOBJBLK 63 /* maximum number of object blocks */ |
114 |
#endif |
115 |
#endif |
116 |
117 |
extern OBJREC *objblock[MAXOBJBLK]; /* the object blocks */ |
118 |
extern OBJECT nobjects; /* # of objects */ |
119 |
120 |
#define OBJBLKSHFT 9 |
121 |
#define OBJBLKSIZ (1<<OBJBLKSHFT) /* object block size */ |
122 |
#define objptr(obj) (objblock[(obj)>>OBJBLKSHFT]+((obj)&(OBJBLKSIZ-1))) |
123 |
124 |
#define OVOID (-1) /* void object */ |
125 |
#define VOIDID "void" /* void identifier */ |
126 |
127 |
128 |
* Object sets begin with the number of objects and proceed with |
129 |
* the objects in ascending order. |
130 |
131 |
132 |
#define MAXSET 127 /* maximum object set size */ |
133 |
134 |
#define setfree(os) free((void *)(os)) |
135 |
136 |
extern void (*addobjnotify[])(); /* people to notify of new objects */ |
137 |
138 |
#ifdef NOPROTO |
139 |
140 |
extern int objndx(); |
141 |
extern int lastmod(); |
142 |
extern int modifier(); |
143 |
extern int object(); |
144 |
extern void insertobject(); |
145 |
extern void clearobjndx(); |
146 |
extern void insertelem(); |
147 |
extern void deletelem(); |
148 |
extern int inset(); |
149 |
extern int setequal(); |
150 |
extern void setcopy(); |
151 |
extern OBJECT * setsave(); |
152 |
extern void setunion(); |
153 |
extern void setintersect(); |
154 |
extern OCTREE fullnode(); |
155 |
extern void objset(); |
156 |
extern int dosets(); |
157 |
extern void donesets(); |
158 |
extern int otype(); |
159 |
extern void objerror(); |
160 |
extern int readfargs(); |
161 |
extern void freefargs(); |
162 |
extern void readobj(); |
163 |
extern void getobject(); |
164 |
extern int newobject(); |
165 |
extern void freeobjects(); |
166 |
extern int free_os(); |
167 |
168 |
#else |
169 |
/* defined in modobject.c */ |
170 |
extern int objndx(OBJREC *op); |
171 |
extern int lastmod(OBJECT obj, char *mname); |
172 |
extern int modifier(char *name); |
173 |
extern int object(char *oname); |
174 |
extern void insertobject(OBJECT obj); |
175 |
extern void clearobjndx(void); |
176 |
/* defined in objset.c */ |
177 |
extern void insertelem(OBJECT *os, OBJECT obj); |
178 |
extern void deletelem(OBJECT *os, OBJECT obj); |
179 |
extern int inset(OBJECT *os, OBJECT obj); |
180 |
extern int setequal(OBJECT *os1, OBJECT *os2); |
181 |
extern void setcopy(OBJECT *os1, OBJECT *os2); |
182 |
extern OBJECT * setsave(OBJECT *os); |
183 |
extern void setunion(OBJECT *osr, OBJECT *os1, OBJECT *os2); |
184 |
extern void setintersect(OBJECT *osr, OBJECT *os1, OBJECT *os2); |
185 |
extern OCTREE fullnode(OBJECT *oset); |
186 |
extern void objset(OBJECT *oset, OCTREE ot); |
187 |
extern int dosets(int (*f)()); |
188 |
extern void donesets(void); |
189 |
190 |
/* defined in otypes.c */ |
191 |
extern int otype(char *ofname); |
192 |
extern void objerror(OBJREC *o, int etyp, char *msg); |
193 |
/* defined in readfargs.c */ |
194 |
extern int readfargs(FUNARGS *fa, FILE *fp); |
195 |
extern void freefargs(FUNARGS *fa); |
196 |
/* defined in readobj.c */ |
197 |
extern void readobj(char *inpspec); |
198 |
extern void getobject(char *name, FILE *fp); |
199 |
200 |
extern void freeobjects(int firstobj, int nobjs); |
201 |
/* defined in free_os.c */ |
202 |
extern int free_os(OBJREC *op); |
203 |
204 |
#endif |
