1 |
/* Copyright (c) 1986 Regents of the University of California */ |
2 |
3 |
/* SCCSid "$SunId$ LBL" */ |
4 |
5 |
6 |
* object.h - header file for routines using objects and object sets. |
7 |
8 |
* 7/28/85 |
9 |
10 |
11 |
12 |
* Object definitions require general specifications |
13 |
* which may include a number of different argument types. |
14 |
* The following structure aids in the storage of such |
15 |
* argument lists. |
16 |
17 |
18 |
typedef struct { |
19 |
short nsargs; /* # of string arguments */ |
20 |
short nfargs; /* # of real arguments */ |
21 |
char **sarg; /* string arguments */ |
22 |
double *farg; /* real arguments */ |
23 |
#ifdef IARGS |
24 |
short niargs; /* # of integer arguments */ |
25 |
long *iarg; /* integer arguments */ |
26 |
#endif |
27 |
} FUNARGS; |
28 |
29 |
#define MAXSTR 512 /* maximum string length */ |
30 |
31 |
32 |
* An object is defined as an index into an array of |
33 |
* structures containing the object type and specification |
34 |
* and the modifier index. |
35 |
36 |
37 |
typedef short OBJECT; /* index into object array */ |
38 |
39 |
typedef struct { |
40 |
OBJECT omod; /* modifier number */ |
41 |
short otype; /* object type number */ |
42 |
char *oname; /* object name */ |
43 |
FUNARGS oargs; /* object specification */ |
44 |
char *os; /* object structure */ |
45 |
long lastrno; /* last ray this was used with */ |
46 |
} OBJREC; |
47 |
48 |
#define MAXOBJBLK 511 /* maximum number of object blocks */ |
49 |
50 |
extern OBJREC *objblock[MAXOBJBLK]; /* the object blocks */ |
51 |
extern OBJECT nobjects; /* # of objects */ |
52 |
53 |
#define objptr(obj) (objblock[(obj)>>6]+((obj)&077)) |
54 |
55 |
#define OVOID (-1) /* void object */ |
56 |
#define VOIDID "void" /* void identifier */ |
57 |
58 |
59 |
* Object sets begin with the number of objects and proceed with |
60 |
* the objects in ascending order. |
61 |
62 |
63 |
#define MAXSET 127 /* maximum object set size */ |
