--- ray/src/common/object.h 2003/06/26 00:58:09 2.15 +++ ray/src/common/object.h 2023/02/06 22:40:21 2.25 @@ -1,4 +1,4 @@ -/* RCSid $Id: object.h,v 2.15 2003/06/26 00:58:09 schorsch Exp $ */ +/* RCSid $Id: object.h,v 2.25 2023/02/06 22:40:21 greg Exp $ */ /* * object.h - header file for routines using objects and object sets. * @@ -10,8 +10,6 @@ extern "C" { #endif -#include "copyright.h" - #ifndef OCTREE #define OCTREE int #endif @@ -24,17 +22,17 @@ extern "C" { */ typedef struct { - short nsargs; /* # of string arguments */ - short nfargs; /* # of real arguments */ char **sarg; /* string arguments */ RREAL *farg; /* real arguments */ + short nsargs; /* # of string arguments */ + short nfargs; /* # of real arguments */ #ifdef IARGS short niargs; /* # of integer arguments */ long *iarg; /* integer arguments */ #endif } FUNARGS; -#define MAXSTR 128 /* maximum string length */ +#define MAXSTR 512 /* maximum string (word) length */ /* * An object is defined as an index into an array of @@ -60,16 +58,16 @@ typedef struct { #ifndef MAXOBJBLK #ifdef SMLMEM -#define MAXOBJBLK 63 /* maximum number of object blocks */ +#define MAXOBJBLK 1023 /* maximum number of object blocks */ #else -#define MAXOBJBLK 65535 /* maximum number of object blocks */ +#define MAXOBJBLK 131071 /* maximum number of object blocks */ #endif #endif extern OBJREC *objblock[MAXOBJBLK]; /* the object blocks */ extern OBJECT nobjects; /* # of objects */ -#define OBJBLKSHFT 9 +#define OBJBLKSHFT 11 #define OBJBLKSIZ (1<>OBJBLKSHFT]+((obj)&(OBJBLKSIZ-1))) @@ -81,19 +79,21 @@ extern OBJECT nobjects; /* # of objects */ * the objects in ascending order. */ -#define MAXSET 511 /* maximum object set size */ +#define MAXSET 8191 /* maximum object set size */ #define setfree(os) free((void *)(os)) -extern void (*addobjnotify[])(); /* people to notify of new objects */ +extern void (*addobjnotify[])(OBJECT); /* people to notify of new objects */ /* defined in modobject.c */ extern OBJECT objndx(OBJREC *op); extern OBJECT lastmod(OBJECT obj, char *mname); extern OBJECT modifier(char *name); extern OBJECT object(char *oname); +extern int eqreal(double d1, double d2); +extern int eqobjects(OBJECT obj1, OBJECT obj2); extern void insertobject(OBJECT obj); -extern void clearobjndx(void); +extern void truncobjndx(void); /* defined in objset.c */ extern void insertelem(OBJECT *os, OBJECT obj); extern void deletelem(OBJECT *os, OBJECT obj); @@ -117,7 +117,7 @@ extern void freefargs(FUNARGS *fa); /* defined in readobj.c */ extern void readobj(char *inpspec); extern void getobject(char *name, FILE *fp); -extern OBJECT newobject(); +extern OBJECT newobject(void); extern void freeobjects(int firstobj, int nobjs); /* defined in free_os.c */ extern int free_os(OBJREC *op);
