--- ray/src/common/object.h 2003/06/26 00:58:09 2.15 +++ ray/src/common/object.h 2013/12/08 18:59:53 2.20 @@ -1,4 +1,4 @@ -/* RCSid $Id: object.h,v 2.15 2003/06/26 00:58:09 schorsch Exp $ */ +/* RCSid $Id: object.h,v 2.20 2013/12/08 18:59:53 greg Exp $ */ /* * object.h - header file for routines using objects and object sets. * @@ -10,8 +10,6 @@ extern "C" { #endif -#include "copyright.h" - #ifndef OCTREE #define OCTREE int #endif @@ -24,17 +22,17 @@ extern "C" { */ typedef struct { - short nsargs; /* # of string arguments */ - short nfargs; /* # of real arguments */ char **sarg; /* string arguments */ RREAL *farg; /* real arguments */ + short nsargs; /* # of string arguments */ + short nfargs; /* # of real arguments */ #ifdef IARGS short niargs; /* # of integer arguments */ long *iarg; /* integer arguments */ #endif } FUNARGS; -#define MAXSTR 128 /* maximum string length */ +#define MAXSTR 512 /* maximum string (word) length */ /* * An object is defined as an index into an array of @@ -92,6 +90,7 @@ extern OBJECT objndx(OBJREC *op); extern OBJECT lastmod(OBJECT obj, char *mname); extern OBJECT modifier(char *name); extern OBJECT object(char *oname); +extern int eqobjects(OBJECT obj1, OBJECT obj2); extern void insertobject(OBJECT obj); extern void clearobjndx(void); /* defined in objset.c */ @@ -117,7 +116,7 @@ extern void freefargs(FUNARGS *fa); /* defined in readobj.c */ extern void readobj(char *inpspec); extern void getobject(char *name, FILE *fp); -extern OBJECT newobject(); +extern OBJECT newobject(void); extern void freeobjects(int firstobj, int nobjs); /* defined in free_os.c */ extern int free_os(OBJREC *op);
