1 |
/* RCSid $Id$ */ |
2 |
3 |
* object.h - header file for routines using objects and object sets. |
4 |
5 |
6 |
#include "copyright.h" |
7 |
8 |
#ifndef OCTREE |
9 |
#define OCTREE int |
10 |
#endif |
11 |
12 |
13 |
* Object definitions require general specifications |
14 |
* which may include a number of different argument types. |
15 |
* The following structure aids in the storage of such |
16 |
* argument lists. |
17 |
18 |
19 |
typedef struct { |
20 |
short nsargs; /* # of string arguments */ |
21 |
short nfargs; /* # of real arguments */ |
22 |
char **sarg; /* string arguments */ |
23 |
FLOAT *farg; /* real arguments */ |
24 |
#ifdef IARGS |
25 |
short niargs; /* # of integer arguments */ |
26 |
long *iarg; /* integer arguments */ |
27 |
#endif |
28 |
} FUNARGS; |
29 |
30 |
#define MAXSTR 128 /* maximum string length */ |
31 |
32 |
33 |
* An object is defined as an index into an array of |
34 |
* structures containing the object type and specification |
35 |
* and the modifier index. |
36 |
37 |
38 |
#ifndef OBJECT |
39 |
#ifdef BIGMEM |
40 |
#define OBJECT int4 /* index to object array */ |
41 |
#else |
42 |
#define OBJECT int2 /* index to object array */ |
43 |
#endif |
44 |
#endif |
45 |
46 |
typedef struct { |
47 |
OBJECT omod; /* modifier number */ |
48 |
short otype; /* object type number */ |
49 |
char *oname; /* object name */ |
50 |
FUNARGS oargs; /* object specification */ |
51 |
char *os; /* object structure */ |
52 |
} OBJREC; |
53 |
54 |
#ifndef MAXOBJBLK |
55 |
#ifdef BIGMEM |
56 |
#define MAXOBJBLK 65535 /* maximum number of object blocks */ |
57 |
#else |
58 |
#define MAXOBJBLK 63 /* maximum number of object blocks */ |
59 |
#endif |
60 |
#endif |
61 |
62 |
extern OBJREC *objblock[MAXOBJBLK]; /* the object blocks */ |
63 |
extern OBJECT nobjects; /* # of objects */ |
64 |
65 |
#define OBJBLKSHFT 9 |
66 |
#define OBJBLKSIZ (1<<OBJBLKSHFT) /* object block size */ |
67 |
#define objptr(obj) (objblock[(obj)>>OBJBLKSHFT]+((obj)&(OBJBLKSIZ-1))) |
68 |
69 |
#define OVOID (-1) /* void object */ |
70 |
#define VOIDID "void" /* void identifier */ |
71 |
72 |
73 |
* Object sets begin with the number of objects and proceed with |
74 |
* the objects in ascending order. |
75 |
76 |
77 |
#define MAXSET 127 /* maximum object set size */ |
78 |
79 |
#define setfree(os) free((void *)(os)) |
80 |
81 |
extern void (*addobjnotify[])(); /* people to notify of new objects */ |
82 |
83 |
#ifdef NOPROTO |
84 |
85 |
extern OBJECT objndx(); |
86 |
extern OBJECT lastmod(); |
87 |
extern OBJECT modifier(); |
88 |
extern OBJECT object(); |
89 |
extern void insertobject(); |
90 |
extern void clearobjndx(); |
91 |
extern void insertelem(); |
92 |
extern void deletelem(); |
93 |
extern int inset(); |
94 |
extern int setequal(); |
95 |
extern void setcopy(); |
96 |
extern OBJECT * setsave(); |
97 |
extern void setunion(); |
98 |
extern void setintersect(); |
99 |
extern OCTREE fullnode(); |
100 |
extern void objset(); |
101 |
extern int dosets(); |
102 |
extern void donesets(); |
103 |
extern int otype(); |
104 |
extern void objerror(); |
105 |
extern int readfargs(); |
106 |
extern void freefargs(); |
107 |
extern void readobj(); |
108 |
extern void getobject(); |
109 |
extern OBJECT newobject(); |
110 |
extern void freeobjects(); |
111 |
extern int free_os(); |
112 |
113 |
#else |
114 |
/* defined in modobject.c */ |
115 |
extern OBJECT objndx(OBJREC *op); |
116 |
extern OBJECT lastmod(OBJECT obj, char *mname); |
117 |
extern OBJECT modifier(char *name); |
118 |
extern OBJECT object(char *oname); |
119 |
extern void insertobject(OBJECT obj); |
120 |
extern void clearobjndx(void); |
121 |
/* defined in objset.c */ |
122 |
extern void insertelem(OBJECT *os, OBJECT obj); |
123 |
extern void deletelem(OBJECT *os, OBJECT obj); |
124 |
extern int inset(OBJECT *os, OBJECT obj); |
125 |
extern int setequal(OBJECT *os1, OBJECT *os2); |
126 |
extern void setcopy(OBJECT *os1, OBJECT *os2); |
127 |
extern OBJECT * setsave(OBJECT *os); |
128 |
extern void setunion(OBJECT *osr, OBJECT *os1, OBJECT *os2); |
129 |
extern void setintersect(OBJECT *osr, OBJECT *os1, OBJECT *os2); |
130 |
extern OCTREE fullnode(OBJECT *oset); |
131 |
extern void objset(OBJECT *oset, OCTREE ot); |
132 |
extern int dosets(int (*f)()); |
133 |
extern void donesets(void); |
134 |
135 |
/* defined in otypes.c */ |
136 |
extern int otype(char *ofname); |
137 |
extern void objerror(OBJREC *o, int etyp, char *msg); |
138 |
/* defined in readfargs.c */ |
139 |
extern int readfargs(FUNARGS *fa, FILE *fp); |
140 |
extern void freefargs(FUNARGS *fa); |
141 |
/* defined in readobj.c */ |
142 |
extern void readobj(char *inpspec); |
143 |
extern void getobject(char *name, FILE *fp); |
144 |
145 |
extern void freeobjects(int firstobj, int nobjs); |
146 |
/* defined in free_os.c */ |
147 |
extern int free_os(OBJREC *op); |
148 |
149 |
#endif /* NOPROTO */ |
