root/radiance/ray/src/common/object.h
Revision: 1.1
Committed: Thu Feb 2 10:34:17 1989 UTC (36 years, 4 months ago) by greg
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 /* SCCSid "$SunId$ LBL" */
4
5 /*
6 * object.h - header file for routines using objects and object sets.
7 *
8 * 7/28/85
9 */
10
11 /*
12 * Object definitions require general specifications
13 * which may include a number of different argument types.
14 * The following structure aids in the storage of such
15 * argument lists.
16 */
17
18 typedef struct {
19 short nsargs; /* # of string arguments */
20 short nfargs; /* # of real arguments */
21 char **sarg; /* string arguments */
22 double *farg; /* real arguments */
23 #ifdef IARGS
24 short niargs; /* # of integer arguments */
25 long *iarg; /* integer arguments */
26 #endif
27 } FUNARGS;
28
29 #define MAXSTR 512 /* maximum string length */
30
31 /*
32 * An object is defined as an index into an array of
33 * structures containing the object type and specification
34 * and the modifier index.
35 */
36
37 typedef short OBJECT; /* index into object array */
38
39 typedef struct {
40 OBJECT omod; /* modifier number */
41 short otype; /* object type number */
42 char *oname; /* object name */
43 FUNARGS oargs; /* object specification */
44 char *os; /* object structure */
45 long lastrno; /* last ray this was used with */
46 } OBJREC;
47
48 #define MAXOBJBLK 511 /* maximum number of object blocks */
49
50 extern OBJREC *objblock[MAXOBJBLK]; /* the object blocks */
51 extern int nobjects; /* # of objects */
52
53 #define objptr(obj) (objblock[(obj)>>6]+((obj)&077))
54
55 #define OVOID (-1) /* void object */
56 #define VOIDID "void" /* void identifier */
57
58 /*
59 * Object sets begin with the number of objects and proceed with
60 * the objects in ascending order.
61 */
62
63 #define MAXSET 127 /* maximum object set size */
