--- ray/src/common/object.h 2005/09/23 19:04:52 2.18 +++ ray/src/common/object.h 2014/05/11 21:37:40 2.22 @@ -1,4 +1,4 @@ -/* RCSid $Id: object.h,v 2.18 2005/09/23 19:04:52 greg Exp $ */ +/* RCSid $Id: object.h,v 2.22 2014/05/11 21:37:40 greg Exp $ */ /* * object.h - header file for routines using objects and object sets. * @@ -32,7 +32,7 @@ typedef struct { #endif } FUNARGS; -#define MAXSTR 128 /* maximum string length */ +#define MAXSTR 512 /* maximum string (word) length */ /* * An object is defined as an index into an array of @@ -58,16 +58,16 @@ typedef struct { #ifndef MAXOBJBLK #ifdef SMLMEM -#define MAXOBJBLK 63 /* maximum number of object blocks */ +#define MAXOBJBLK 1023 /* maximum number of object blocks */ #else -#define MAXOBJBLK 65535 /* maximum number of object blocks */ +#define MAXOBJBLK 131071 /* maximum number of object blocks */ #endif #endif extern OBJREC *objblock[MAXOBJBLK]; /* the object blocks */ extern OBJECT nobjects; /* # of objects */ -#define OBJBLKSHFT 9 +#define OBJBLKSHFT 11 #define OBJBLKSIZ (1<>OBJBLKSHFT]+((obj)&(OBJBLKSIZ-1))) @@ -90,6 +90,8 @@ extern OBJECT objndx(OBJREC *op); extern OBJECT lastmod(OBJECT obj, char *mname); extern OBJECT modifier(char *name); extern OBJECT object(char *oname); +extern int eqreal(double d1, double d2); +extern int eqobjects(OBJECT obj1, OBJECT obj2); extern void insertobject(OBJECT obj); extern void clearobjndx(void); /* defined in objset.c */
