1 |
/* RCSid $Id: object.h,v 2.17 2003/07/17 09:21:29 schorsch Exp $ */ |
2 |
3 |
* object.h - header file for routines using objects and object sets. |
4 |
5 |
* Include after "standard.h" |
6 |
7 |
#ifndef _RAD_OBJECT_H_ |
8 |
#define _RAD_OBJECT_H_ |
9 |
#ifdef __cplusplus |
10 |
extern "C" { |
11 |
#endif |
12 |
13 |
#ifndef OCTREE |
14 |
#define OCTREE int |
15 |
#endif |
16 |
17 |
18 |
* Object definitions require general specifications |
19 |
* which may include a number of different argument types. |
20 |
* The following structure aids in the storage of such |
21 |
* argument lists. |
22 |
23 |
24 |
typedef struct { |
25 |
char **sarg; /* string arguments */ |
26 |
RREAL *farg; /* real arguments */ |
27 |
short nsargs; /* # of string arguments */ |
28 |
short nfargs; /* # of real arguments */ |
29 |
#ifdef IARGS |
30 |
short niargs; /* # of integer arguments */ |
31 |
long *iarg; /* integer arguments */ |
32 |
#endif |
33 |
} FUNARGS; |
34 |
35 |
#define MAXSTR 128 /* maximum string length */ |
36 |
37 |
38 |
* An object is defined as an index into an array of |
39 |
* structures containing the object type and specification |
40 |
* and the modifier index. |
41 |
42 |
43 |
#ifndef OBJECT |
44 |
#ifdef SMLMEM |
45 |
#define OBJECT int16 /* index to object array */ |
46 |
#else |
47 |
#define OBJECT int32 /* index to object array */ |
48 |
#endif |
49 |
#endif |
50 |
51 |
typedef struct { |
52 |
OBJECT omod; /* modifier number */ |
53 |
short otype; /* object type number */ |
54 |
char *oname; /* object name */ |
55 |
FUNARGS oargs; /* object specification */ |
56 |
char *os; /* object structure */ |
57 |
} OBJREC; |
58 |
59 |
#ifndef MAXOBJBLK |
60 |
#ifdef SMLMEM |
61 |
#define MAXOBJBLK 63 /* maximum number of object blocks */ |
62 |
#else |
63 |
#define MAXOBJBLK 65535 /* maximum number of object blocks */ |
64 |
#endif |
65 |
#endif |
66 |
67 |
extern OBJREC *objblock[MAXOBJBLK]; /* the object blocks */ |
68 |
extern OBJECT nobjects; /* # of objects */ |
69 |
70 |
#define OBJBLKSHFT 9 |
71 |
#define OBJBLKSIZ (1<<OBJBLKSHFT) /* object block size */ |
72 |
#define objptr(obj) (objblock[(obj)>>OBJBLKSHFT]+((obj)&(OBJBLKSIZ-1))) |
73 |
74 |
#define OVOID (-1) /* void object */ |
75 |
#define VOIDID "void" /* void identifier */ |
76 |
77 |
78 |
* Object sets begin with the number of objects and proceed with |
79 |
* the objects in ascending order. |
80 |
81 |
82 |
#define MAXSET 511 /* maximum object set size */ |
83 |
84 |
#define setfree(os) free((void *)(os)) |
85 |
86 |
extern void (*addobjnotify[])(); /* people to notify of new objects */ |
87 |
88 |
/* defined in modobject.c */ |
89 |
extern OBJECT objndx(OBJREC *op); |
90 |
extern OBJECT lastmod(OBJECT obj, char *mname); |
91 |
extern OBJECT modifier(char *name); |
92 |
extern OBJECT object(char *oname); |
93 |
extern void insertobject(OBJECT obj); |
94 |
extern void clearobjndx(void); |
95 |
/* defined in objset.c */ |
96 |
extern void insertelem(OBJECT *os, OBJECT obj); |
97 |
extern void deletelem(OBJECT *os, OBJECT obj); |
98 |
extern int inset(OBJECT *os, OBJECT obj); |
99 |
extern int setequal(OBJECT *os1, OBJECT *os2); |
100 |
extern void setcopy(OBJECT *os1, OBJECT *os2); |
101 |
extern OBJECT * setsave(OBJECT *os); |
102 |
extern void setunion(OBJECT *osr, OBJECT *os1, OBJECT *os2); |
103 |
extern void setintersect(OBJECT *osr, OBJECT *os1, OBJECT *os2); |
104 |
extern OCTREE fullnode(OBJECT *oset); |
105 |
extern void objset(OBJECT *oset, OCTREE ot); |
106 |
extern int dosets(int (*f)()); |
107 |
extern void donesets(void); |
108 |
109 |
/* defined in otypes.c */ |
110 |
extern int otype(char *ofname); |
111 |
extern void objerror(OBJREC *o, int etyp, char *msg); |
112 |
/* defined in readfargs.c */ |
113 |
extern int readfargs(FUNARGS *fa, FILE *fp); |
114 |
extern void freefargs(FUNARGS *fa); |
115 |
/* defined in readobj.c */ |
116 |
extern void readobj(char *inpspec); |
117 |
extern void getobject(char *name, FILE *fp); |
118 |
extern OBJECT newobject(void); |
119 |
extern void freeobjects(int firstobj, int nobjs); |
120 |
/* defined in free_os.c */ |
121 |
extern int free_os(OBJREC *op); |
122 |
123 |
124 |
125 |
126 |
#endif |
127 |
#endif /* _RAD_OBJECT_H_ */ |
128 |
