root/radiance/ray/src/common/object.h
Sun May 11 21:37:40 2014 UTC (10 years, 1 month ago) by greg
Diff to previous 2.21 , to selected 2.19
Increased maximum number of objects by a factor of 8 to 255 million
Sun Dec 8 19:25:36 2013 UTC (10 years, 6 months ago) by greg
Diff to previous 2.20 , to selected 2.19
Made eqobjects() a little more general and exposed eqreal() to library
Sun Dec 8 18:59:53 2013 UTC (10 years, 6 months ago) by greg
Changes since 2.19: +2 -1 lines
Diff to previous 2.19
Revision 2.19 - (view) (download) (annotate) - [selected]
Fri Sep 7 21:45:22 2012 UTC (11 years, 9 months ago) by greg
Diff to previous 2.18
Increased maximum string length as requested by Dan Glaser
Fri Sep 23 19:04:52 2005 UTC (18 years, 8 months ago) by greg
Diff to previous 2.17 , to selected 2.19
Thu Jul 17 09:21:29 2003 UTC (20 years, 11 months ago) by schorsch
Diff to previous 2.16 , to selected 2.19
Changes since 2.15: +1 -3 lines
Diff to previous 2.15 , to selected 2.19
Diff to previous 2.14 , to selected 2.19
Fri Jun 20 00:25:49 2003 UTC (21 years ago) by greg
Changes since 2.13: +5 -3 lines
Diff to previous 2.13 , to selected 2.19
Fri Jun 6 16:38:47 2003 UTC (21 years ago) by schorsch
Changes since 2.12: +12 -33 lines
Diff to previous 2.12 , to selected 2.19
*** empty log message ***
Thu May 15 05:13:35 2003 UTC (21 years, 1 month ago) by greg
Changes since 2.11: +6 -6 lines
Diff to previous 2.11 , to selected 2.19
Wed Mar 12 04:59:04 2003 UTC (21 years, 3 months ago) by greg
Diff to previous 2.10 , to selected 2.19
Mon Mar 10 17:13:29 2003 UTC (21 years, 3 months ago) by greg
Changes since 2.9: +11 -11 lines
Diff to previous 2.9 , to selected 2.19
Diff to previous 2.8 , to selected 2.19
Changes since 2.7: +131 -7 lines
Diff to previous 2.7 , to selected 2.19
Tue Jan 19 16:01:54 1999 UTC (25 years, 5 months ago) by gwlarson
Diff to previous 2.6 , to selected 2.19
fixed MAXOBJBLK when BIGMEM undefined
Thu Nov 5 16:51:26 1998 UTC (25 years, 7 months ago) by gwlarson
Changes since 2.5: +3 -2 lines
Diff to previous 2.5 , to selected 2.19
fixed problem with new object block sizing
Tue Aug 25 10:16:08 1998 UTC (25 years, 9 months ago) by gwlarson
Changes since 2.4: +6 -5 lines
Diff to previous 2.4 , to selected 2.19
changed object block size and increased object limit to 32 million
Wed Dec 3 11:13:12 1997 UTC (26 years, 6 months ago) by gregl
Diff to previous 2.3 , to selected 2.19
increased object table size for -DBIGMEM to allow 4 million objects
Fri Mar 7 15:45:31 1997 UTC (27 years, 3 months ago) by greg
Changes since 2.2: +4 -0 lines
Diff to previous 2.2 , to selected 2.19
added new set routines
Mon Jan 25 12:41:25 1993 UTC (31 years, 4 months ago) by greg
Diff to previous 2.1 , to selected 2.19
removed lastrno from object structure
Tue Nov 12 16:55:32 1991 UTC (32 years, 7 months ago) by greg
Diff to previous 1.5 , to selected 2.19
Wed Oct 23 12:19:28 1991 UTC (32 years, 8 months ago) by greg
Diff to previous 1.4 , to selected 2.19
added FLOAT definition for vectors and matrices
Wed Oct 23 11:52:57 1991 UTC (32 years, 8 months ago) by greg
Changes since 1.3: +13 -1 lines
Diff to previous 1.3 , to selected 2.19
added conditional sizing of structures from BIGMEM
Wed Jul 24 14:15:51 1991 UTC (32 years, 11 months ago) by greg
Diff to previous 1.2 , to selected 2.19
reduced MAXSTR to something more reasonable
Thu Sep 6 23:32:38 1990 UTC (33 years, 9 months ago) by greg
Diff to previous 1.1 , to selected 2.19
added consistency checks to detect stale octrees
Thu Feb 2 10:34:17 1989 UTC (35 years, 4 months ago) by greg
Diff to selected 2.19
