Added prototypes and includes from patch by Randolph Fritz. Added more required includes and reduced other compile warnings.
Abstracted process and path handling for Windows. Renamed FLOAT to RREAL because of conflict on Windows. Added conditional compiles for some signal handlers.
*** empty log message ***
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
fixed MAXOBJBLK when BIGMEM undefined
fixed problem with new object block sizing
changed object block size and increased object limit to 32 million
increased object table size for -DBIGMEM to allow 4 million objects
added new set routines
removed lastrno from object structure
added FLOAT definition for vectors and matrices
added conditional sizing of structures from BIGMEM
reduced MAXSTR to something more reasonable
added consistency checks to detect stale octrees
