--- ray/src/common/object.h 1989/02/02 10:34:17 1.1 +++ ray/src/common/object.h 2003/06/06 16:38:47 2.13 @@ -1,13 +1,19 @@ -/* Copyright (c) 1986 Regents of the University of California */ - -/* SCCSid "$SunId$ LBL" */ - +/* RCSid $Id: object.h,v 2.13 2003/06/06 16:38:47 schorsch Exp $ */ /* * object.h - header file for routines using objects and object sets. - * - * 7/28/85 */ +#ifndef _RAD_OBJECT_H_ +#define _RAD_OBJECT_H_ +#ifdef __cplusplus +extern "C" { +#endif +#include "copyright.h" + +#ifndef OCTREE +#define OCTREE int +#endif + /* * Object definitions require general specifications * which may include a number of different argument types. @@ -19,14 +25,14 @@ typedef struct { short nsargs; /* # of string arguments */ short nfargs; /* # of real arguments */ char **sarg; /* string arguments */ - double *farg; /* real arguments */ + FLOAT *farg; /* real arguments */ #ifdef IARGS short niargs; /* # of integer arguments */ long *iarg; /* integer arguments */ #endif } FUNARGS; -#define MAXSTR 512 /* maximum string length */ +#define MAXSTR 128 /* maximum string length */ /* * An object is defined as an index into an array of @@ -34,7 +40,13 @@ typedef struct { * and the modifier index. */ -typedef short OBJECT; /* index into object array */ +#ifndef OBJECT +#ifdef SMLMEM +#define OBJECT int2 /* index to object array */ +#else +#define OBJECT int4 /* index to object array */ +#endif +#endif typedef struct { OBJECT omod; /* modifier number */ @@ -42,15 +54,22 @@ typedef struct { char *oname; /* object name */ FUNARGS oargs; /* object specification */ char *os; /* object structure */ - long lastrno; /* last ray this was used with */ } OBJREC; -#define MAXOBJBLK 511 /* maximum number of object blocks */ +#ifndef MAXOBJBLK +#ifdef SMLMEM +#define MAXOBJBLK 63 /* maximum number of object blocks */ +#else +#define MAXOBJBLK 65535 /* maximum number of object blocks */ +#endif +#endif extern OBJREC *objblock[MAXOBJBLK]; /* the object blocks */ -extern int nobjects; /* # of objects */ +extern OBJECT nobjects; /* # of objects */ -#define objptr(obj) (objblock[(obj)>>6]+((obj)&077)) +#define OBJBLKSHFT 9 +#define OBJBLKSIZ (1<>OBJBLKSHFT]+((obj)&(OBJBLKSIZ-1))) #define OVOID (-1) /* void object */ #define VOIDID "void" /* void identifier */ @@ -60,4 +79,50 @@ extern int nobjects; /* # of objects */ * the objects in ascending order. */ -#define MAXSET 127 /* maximum object set size */ +#define MAXSET 511 /* maximum object set size */ + +#define setfree(os) free((void *)(os)) + +extern void (*addobjnotify[])(); /* people to notify of new objects */ + + /* defined in modobject.c */ +extern OBJECT objndx(OBJREC *op); +extern OBJECT lastmod(OBJECT obj, char *mname); +extern OBJECT modifier(char *name); +extern OBJECT object(char *oname); +extern void insertobject(OBJECT obj); +extern void clearobjndx(void); + /* defined in objset.c */ +extern void insertelem(OBJECT *os, OBJECT obj); +extern void deletelem(OBJECT *os, OBJECT obj); +extern int inset(OBJECT *os, OBJECT obj); +extern int setequal(OBJECT *os1, OBJECT *os2); +extern void setcopy(OBJECT *os1, OBJECT *os2); +extern OBJECT * setsave(OBJECT *os); +extern void setunion(OBJECT *osr, OBJECT *os1, OBJECT *os2); +extern void setintersect(OBJECT *osr, OBJECT *os1, OBJECT *os2); +extern OCTREE fullnode(OBJECT *oset); +extern void objset(OBJECT *oset, OCTREE ot); +extern int dosets(int (*f)()); +extern void donesets(void); + + /* defined in otypes.c */ +extern int otype(char *ofname); +extern void objerror(OBJREC *o, int etyp, char *msg); + /* defined in readfargs.c */ +extern int readfargs(FUNARGS *fa, FILE *fp); +extern void freefargs(FUNARGS *fa); + /* defined in readobj.c */ +extern void readobj(char *inpspec); +extern void getobject(char *name, FILE *fp); +extern OBJECT newobject(); +extern void freeobjects(int firstobj, int nobjs); + /* defined in free_os.c */ +extern int free_os(OBJREC *op); + + +#ifdef __cplusplus +} +#endif +#endif /* _RAD_OBJECT_H_ */ +
