--- ray/src/common/object.h 2003/02/25 02:47:21 2.9 +++ ray/src/common/object.h 2003/03/12 04:59:04 2.11 @@ -1,4 +1,4 @@ -/* RCSid $Id: object.h,v 2.9 2003/02/25 02:47:21 greg Exp $ */ +/* RCSid $Id: object.h,v 2.11 2003/03/12 04:59:04 greg Exp $ */ /* * object.h - header file for routines using objects and object sets. */ @@ -74,7 +74,7 @@ extern OBJECT nobjects; /* # of objects */ * the objects in ascending order. */ -#define MAXSET 127 /* maximum object set size */ +#define MAXSET 511 /* maximum object set size */ #define setfree(os) free((void *)(os)) @@ -82,10 +82,10 @@ extern void (*addobjnotify[])(); /* people to #ifdef NOPROTO -extern int objndx(); -extern int lastmod(); -extern int modifier(); -extern int object(); +extern OBJECT objndx(); +extern OBJECT lastmod(); +extern OBJECT modifier(); +extern OBJECT object(); extern void insertobject(); extern void clearobjndx(); extern void insertelem(); @@ -106,16 +106,16 @@ extern int readfargs(); extern void freefargs(); extern void readobj(); extern void getobject(); -extern int newobject(); +extern OBJECT newobject(); extern void freeobjects(); extern int free_os(); #else /* defined in modobject.c */ -extern int objndx(OBJREC *op); -extern int lastmod(OBJECT obj, char *mname); -extern int modifier(char *name); -extern int object(char *oname); +extern OBJECT objndx(OBJREC *op); +extern OBJECT lastmod(OBJECT obj, char *mname); +extern OBJECT modifier(char *name); +extern OBJECT object(char *oname); extern void insertobject(OBJECT obj); extern void clearobjndx(void); /* defined in objset.c */ @@ -141,9 +141,9 @@ extern void freefargs(FUNARGS *fa); /* defined in readobj.c */ extern void readobj(char *inpspec); extern void getobject(char *name, FILE *fp); -extern int newobject(); +extern OBJECT newobject(); extern void freeobjects(int firstobj, int nobjs); /* defined in free_os.c */ extern int free_os(OBJREC *op); -#endif +#endif /* NOPROTO */
