--- ray/src/common/object.h 1998/08/25 10:16:08 2.5 +++ ray/src/common/object.h 2003/02/25 02:47:21 2.9 @@ -1,13 +1,14 @@ -/* Copyright (c) 1986 Regents of the University of California */ - -/* SCCSid "$SunId$ LBL" */ - +/* RCSid $Id: object.h,v 2.9 2003/02/25 02:47:21 greg Exp $ */ /* * object.h - header file for routines using objects and object sets. - * - * 7/28/85 */ +#include "copyright.h" + +#ifndef OCTREE +#define OCTREE int +#endif + /* * Object definitions require general specifications * which may include a number of different argument types. @@ -54,15 +55,16 @@ typedef struct { #ifdef BIGMEM #define MAXOBJBLK 65535 /* maximum number of object blocks */ #else -#define MAXOBJBLK 31 /* maximum number of object blocks */ +#define MAXOBJBLK 63 /* maximum number of object blocks */ #endif #endif extern OBJREC *objblock[MAXOBJBLK]; /* the object blocks */ extern OBJECT nobjects; /* # of objects */ -#define OBJBLKSIZ 01000 /* object block size */ -#define objptr(obj) (objblock[(obj)>>9]+((obj)&0777)) +#define OBJBLKSHFT 9 +#define OBJBLKSIZ (1<>OBJBLKSHFT]+((obj)&(OBJBLKSIZ-1))) #define OVOID (-1) /* void object */ #define VOIDID "void" /* void identifier */ @@ -74,6 +76,74 @@ extern OBJECT nobjects; /* # of objects */ #define MAXSET 127 /* maximum object set size */ -OBJECT *setsave(); +#define setfree(os) free((void *)(os)) -#define setfree(os) free((char *)(os)) +extern void (*addobjnotify[])(); /* people to notify of new objects */ + +#ifdef NOPROTO + +extern int objndx(); +extern int lastmod(); +extern int modifier(); +extern int object(); +extern void insertobject(); +extern void clearobjndx(); +extern void insertelem(); +extern void deletelem(); +extern int inset(); +extern int setequal(); +extern void setcopy(); +extern OBJECT * setsave(); +extern void setunion(); +extern void setintersect(); +extern OCTREE fullnode(); +extern void objset(); +extern int dosets(); +extern void donesets(); +extern int otype(); +extern void objerror(); +extern int readfargs(); +extern void freefargs(); +extern void readobj(); +extern void getobject(); +extern int newobject(); +extern void freeobjects(); +extern int free_os(); + +#else + /* defined in modobject.c */ +extern int objndx(OBJREC *op); +extern int lastmod(OBJECT obj, char *mname); +extern int modifier(char *name); +extern int object(char *oname); +extern void insertobject(OBJECT obj); +extern void clearobjndx(void); + /* defined in objset.c */ +extern void insertelem(OBJECT *os, OBJECT obj); +extern void deletelem(OBJECT *os, OBJECT obj); +extern int inset(OBJECT *os, OBJECT obj); +extern int setequal(OBJECT *os1, OBJECT *os2); +extern void setcopy(OBJECT *os1, OBJECT *os2); +extern OBJECT * setsave(OBJECT *os); +extern void setunion(OBJECT *osr, OBJECT *os1, OBJECT *os2); +extern void setintersect(OBJECT *osr, OBJECT *os1, OBJECT *os2); +extern OCTREE fullnode(OBJECT *oset); +extern void objset(OBJECT *oset, OCTREE ot); +extern int dosets(int (*f)()); +extern void donesets(void); + + /* defined in otypes.c */ +extern int otype(char *ofname); +extern void objerror(OBJREC *o, int etyp, char *msg); + /* defined in readfargs.c */ +extern int readfargs(FUNARGS *fa, FILE *fp); +extern void freefargs(FUNARGS *fa); + /* defined in readobj.c */ +extern void readobj(char *inpspec); +extern void getobject(char *name, FILE *fp); +extern int newobject(); +extern void freeobjects(int firstobj, int nobjs); + /* defined in free_os.c */ +extern int free_os(OBJREC *op); + +#endif
