--- ray/src/common/object.h 2003/03/10 17:13:29 2.10 +++ ray/src/common/object.h 2003/05/15 05:13:35 2.12 @@ -1,4 +1,4 @@ -/* RCSid $Id: object.h,v 2.10 2003/03/10 17:13:29 greg Exp $ */ +/* RCSid $Id: object.h,v 2.12 2003/05/15 05:13:35 greg Exp $ */ /* * object.h - header file for routines using objects and object sets. */ @@ -36,10 +36,10 @@ typedef struct { */ #ifndef OBJECT -#ifdef BIGMEM -#define OBJECT int4 /* index to object array */ -#else +#ifdef SMLMEM #define OBJECT int2 /* index to object array */ +#else +#define OBJECT int4 /* index to object array */ #endif #endif @@ -52,10 +52,10 @@ typedef struct { } OBJREC; #ifndef MAXOBJBLK -#ifdef BIGMEM -#define MAXOBJBLK 65535 /* maximum number of object blocks */ -#else +#ifdef SMLMEM #define MAXOBJBLK 63 /* maximum number of object blocks */ +#else +#define MAXOBJBLK 65535 /* maximum number of object blocks */ #endif #endif @@ -74,7 +74,7 @@ extern OBJECT nobjects; /* # of objects */ * the objects in ascending order. */ -#define MAXSET 127 /* maximum object set size */ +#define MAXSET 511 /* maximum object set size */ #define setfree(os) free((void *)(os))
