--- ray/src/common/normcodec.h 2019/07/26 17:04:12 2.2 +++ ray/src/common/normcodec.h 2019/08/14 21:00:14 2.3 @@ -1,4 +1,4 @@ -/* RCSid $Id: normcodec.h,v 2.2 2019/07/26 17:04:12 greg Exp $ */ +/* RCSid $Id: normcodec.h,v 2.3 2019/08/14 21:00:14 greg Exp $ */ /* * Definitions and declarations for 32-bit vector normal encode/decode * @@ -29,7 +29,8 @@ extern "C" { typedef struct { FILE *finp; /* input stream */ const char *inpname; /* input name */ - int format; /* decoded format */ + short format; /* decoded format */ + short swapped; /* byte-swapped input */ long dstart; /* start of data */ long curpos; /* current input position */ int hdrflags; /* header i/o flags */
