--- ray/src/common/normcodec.h 2019/07/26 16:18:06 2.1 +++ ray/src/common/normcodec.h 2022/08/24 19:55:58 2.5 @@ -1,8 +1,8 @@ -/* RCSid $Id: normcodec.h,v 2.1 2019/07/26 16:18:06 greg Exp $ */ +/* RCSid $Id: normcodec.h,v 2.5 2022/08/24 19:55:58 greg Exp $ */ /* * Definitions and declarations for 32-bit vector normal encode/decode * - * Include after stdio.h and fvect.h + * Include after rtio.h and fvect.h * Includes resolu.h */ @@ -17,21 +17,22 @@ extern "C" { #define NORMAL32FMT "32-bit_encoded_normal" -#define HF_HEADIN 0x1 -#define HF_HEADOUT 0x2 -#define HF_RESIN 0x4 -#define HF_RESOUT 0x8 -#define HF_ALL 0xf -#define HF_ENCODE 0x10 +#define HF_HEADIN 0x1 /* expect input header */ +#define HF_HEADOUT 0x2 /* write header to stdout */ +#define HF_RESIN 0x4 /* expect resolution string */ +#define HF_RESOUT 0x8 /* write resolution to stdout */ +#define HF_STDERR 0x10 /* report errors to stderr */ +#define HF_ALL 0x1f /* all flags above */ +#define HF_ENCODE 0x20 /* we are encoding */ /* Structure for encoding/decoding normals */ typedef struct { FILE *finp; /* input stream */ const char *inpname; /* input name */ - int format; /* decoded format */ + short format; /* decoded format */ + short swapped; /* byte-swapped input */ long dstart; /* start of data */ - long curpos; /* current input position */ - int hdrflags; /* header i/o flags */ + short hdrflags; /* header i/o flags */ char inpfmt[MAXFMTLEN]; /* format from header */ RESOLU res; /* input resolution */ } NORMCODEC;
