--- ray/src/common/normcodec.h 2019/11/07 23:20:28 2.4 +++ ray/src/common/normcodec.h 2022/08/24 19:55:58 2.5 @@ -1,4 +1,4 @@ -/* RCSid $Id: normcodec.h,v 2.4 2019/11/07 23:20:28 greg Exp $ */ +/* RCSid $Id: normcodec.h,v 2.5 2022/08/24 19:55:58 greg Exp $ */ /* * Definitions and declarations for 32-bit vector normal encode/decode * @@ -32,7 +32,6 @@ typedef struct { short format; /* decoded format */ short swapped; /* byte-swapped input */ long dstart; /* start of data */ - long curpos; /* current input position */ short hdrflags; /* header i/o flags */ char inpfmt[MAXFMTLEN]; /* format from header */ RESOLU res; /* input resolution */
