root/radiance/ray/src/common/normcodec.c
Revision: 2.5
Committed: Thu Nov 7 23:20:28 2019 UTC (4 years, 6 months ago) by greg
Changes since 2.4: +4 -5 lines
2 static const char RCSid[] = "$Id: normcodec.c,v 2.4 2019/08/26 23:33:24 greg Exp $";
5 * Routines to encode/decode 32-bit normals
6 */
7
8 #include "copyright.h"
9
10 #include "rtio.h"
11 #include "rtmath.h"
12 #include "normcodec.h"
13
14
15 /* Set codec defaults */
16 void
17 set_nc_defaults(NORMCODEC *ncp)
18 {
19 memset(ncp, 0, sizeof(NORMCODEC));
20 ncp->finp = stdin;
21 ncp->inpname = "<stdin>";
22 ncp->format = 'a';
23 ncp->res.rt = PIXSTANDARD;
24 if (!progname) progname = "norm_codec";
25 }
26
27
28 /* process header line */
29 static int
30 headline(char *s, void *p)
31 {
32 NORMCODEC *ncp = (NORMCODEC *)p;
33 int rv;
34
35 if (formatval(ncp->inpfmt, s)) /* don't pass format */
36 return 0;
37
38 if ((rv = isbigendian(s)) >= 0) {
39 ncp->swapped = (nativebigendian() != rv);
40 return 0;
41 }
42 if (ncp->hdrflags & HF_HEADOUT)
43 fputs(s, stdout); /* copy to standard output */
44 return 1;
45 }
46
47
48 /* Load/copy header */
49 int
50 process_nc_header(NORMCODEC *ncp, int ac, char *av[])
51 {
52 if (ncp->hdrflags & HF_HEADIN &&
53 getheader(ncp->finp, headline, ncp) < 0) {
54 if (ncp->hdrflags & HF_STDERR) {
55 fputs(ncp->inpname, stderr);
56 fputs(": bad header\n", stderr);
57 }
58 return 0;
59 }
60 if (ncp->hdrflags & HF_HEADOUT) { /* finish header */
61 if (!(ncp->hdrflags & HF_HEADIN))
62 newheader("RADIANCE", stdout);
63 if (ac > 0)
64 printargs(ac, av, stdout);
65 if (ncp->hdrflags & HF_ENCODE) {
66 fputformat(NORMAL32FMT, stdout);
67 } else
68 switch (ncp->format) {
69 case 'a':
70 fputformat("ascii", stdout);
71 break;
72 case 'f':
73 fputendian(stdout);
74 fputformat("float", stdout);
75 break;
76 case 'd':
77 fputendian(stdout);
78 fputformat("double", stdout);
79 break;
80 }
81 fputc('\n', stdout);
82 }
83 /* get/put resolution string */
84 if (ncp->hdrflags & HF_RESIN && !fgetsresolu(&ncp->res, ncp->finp)) {
85 if (ncp->hdrflags & HF_STDERR) {
86 fputs(ncp->inpname, stderr);
87 fputs(": bad resolution string\n", stderr);
88 }
89 return 0;
90 }
91 if (ncp->hdrflags & HF_RESOUT)
92 fputsresolu(&ncp->res, stdout);
93
94 ncp->dstart = ncp->curpos = ftell(ncp->finp);
95 return 1;
96 }
97
98
99 /* Check that we have what we need to decode normals */
100 int
101 check_decode_normals(NORMCODEC *ncp)
102 {
103 if (ncp->hdrflags & HF_ENCODE) {
104 if (ncp->hdrflags & HF_STDERR) {
105 fputs(progname, stderr);
106 fputs(": wrong header mode for decode\n", stderr);
107 }
108 return 0;
109 }
110 if (ncp->inpfmt[0] && strcmp(ncp->inpfmt, NORMAL32FMT)) {
111 if (ncp->hdrflags & HF_STDERR) {
112 fputs(ncp->inpname, stderr);
113 fputs(": unexpected input format: ", stderr);
114 fputs(ncp->inpfmt, stderr);
115 fputc('\n', stderr);
116 }
117 return 0;
118 }
119 return 1;
120 }
121
122
123 /* Decode next normal from input */
124 int
125 decode_normal_next(FVECT nrm, NORMCODEC *ncp)
126 {
127 static int32 lastc;
128 static FVECT lastv;
129 int32 c = getint(4, ncp->finp);
130
131 if (c == EOF && feof(ncp->finp))
132 return -1;
133
134 ncp->curpos += 4;
135
136 if (c == lastc) { /* optimization */
137 VCOPY(nrm, lastv);
138 } else {
139 decodedir(nrm, c);
140 if (c) {
141 lastc = c;
142 VCOPY(lastv, nrm);
143 }
144 }
145 return (c != 0);
146 }
147
148
149 /* Seek to the indicated pixel position */
150 int
151 seek_nc_pix(NORMCODEC *ncp, int x, int y)
152 {
153 long seekpos;
154
155 if ((ncp->res.xr <= 0) | (ncp->res.yr <= 0)) {
156 if (ncp->hdrflags & HF_STDERR) {
157 fputs(progname, stderr);
158 fputs(": need map resolution to seek\n", stderr);
159 }
160 return -1;
161 }
162 if ((x < 0) | (y < 0) ||
163 (x >= scanlen(&ncp->res)) | (y >= numscans(&ncp->res))) {
164 if (ncp->hdrflags & HF_STDERR) {
165 fputs(ncp->inpname, stderr);
166 fputs(": warning - pixel index off map\n", stderr);
167 }
168 return 0;
169 }
170 seekpos = ncp->dstart + 4*((long)y*scanlen(&ncp->res) + x);
171
172 if (seekpos != ncp->curpos &&
173 fseek(ncp->finp, seekpos, SEEK_SET) == EOF) {
174 if (ncp->hdrflags & HF_STDERR) {
175 fputs(ncp->inpname, stderr);
176 fputs(": seek error\n", stderr);
177 }
178 return -1;
179 }
180 ncp->curpos = seekpos;
181 return 1;
182 }
183
184
185 /* Read and decode normal for the given pixel */
186 int
187 decode_normal_pix(FVECT nrm, NORMCODEC *ncp, int x, int y)
188 {
189 int rval = seek_nc_pix(ncp, x, y);
190
191 if (rval < 0)
192 return -1;
193
194 if (!rval) {
195 nrm[0] = nrm[1] = nrm[2] = .0;
196 return 0;
197 }
198 return decode_normal_next(nrm, ncp);
199 }
