1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: normcodec.c,v 2.8 2022/09/22 21:45:28 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Routines to encode/decode 32-bit normals |
6 |
7 |
8 |
#include "copyright.h" |
9 |
10 |
#include <stdlib.h> |
11 |
#include "rtio.h" |
12 |
#include "rtmath.h" |
13 |
#include "normcodec.h" |
14 |
15 |
16 |
/* Set codec defaults */ |
17 |
void |
18 |
set_nc_defaults(NORMCODEC *ncp) |
19 |
20 |
memset(ncp, 0, sizeof(NORMCODEC)); |
21 |
ncp->finp = stdin; |
22 |
ncp->inpname = "<stdin>"; |
23 |
ncp->format = 'a'; |
24 |
ncp->res.rt = PIXSTANDARD; |
25 |
if (!progname) progname = "norm_codec"; |
26 |
27 |
28 |
29 |
/* process header line */ |
30 |
static int |
31 |
headline(char *s, void *p) |
32 |
33 |
NORMCODEC *ncp = (NORMCODEC *)p; |
34 |
int rv; |
35 |
36 |
if (formatval(ncp->inpfmt, s)) /* don't pass format */ |
37 |
return 0; |
38 |
39 |
if ((rv = isbigendian(s)) >= 0) { |
40 |
ncp->swapped = (nativebigendian() != rv); |
41 |
return 0; |
42 |
43 |
if (!strncmp(s, "NCOMP=", 6)) { |
44 |
if (atoi(s+6) != 3) { |
45 |
if (ncp->hdrflags & HF_STDERR) { |
46 |
fputs(ncp->inpname, stderr); |
47 |
fputs(": NCOMP must equal 3\n", stderr); |
48 |
49 |
return -1; |
50 |
51 |
return 0; |
52 |
53 |
if (!strncmp(s, "NROWS=", 6)) { |
54 |
ncp->res.yr = atoi(s+6); |
55 |
return 0; |
56 |
57 |
if (!strncmp(s, "NCOLS=", 6)) { |
58 |
ncp->res.xr = atoi(s+6); |
59 |
return 0; |
60 |
61 |
if (ncp->hdrflags & HF_HEADOUT) |
62 |
fputs(s, stdout); /* copy to standard output */ |
63 |
return 1; |
64 |
65 |
66 |
67 |
/* Load/copy header */ |
68 |
int |
69 |
process_nc_header(NORMCODEC *ncp, int ac, char *av[]) |
70 |
71 |
if (ncp->hdrflags & HF_HEADIN && |
72 |
getheader(ncp->finp, headline, ncp) < 0) { |
73 |
74 |
75 |
fputs(": bad header\n", stderr); |
76 |
77 |
return 0; |
78 |
79 |
/* get resolution string? */ |
80 |
if (ncp->hdrflags & HF_RESIN && |
81 |
(ncp->res.xr <= 0) | (ncp->res.yr <= 0) && |
82 |
!fgetsresolu(&ncp->res, ncp->finp)) { |
83 |
84 |
85 |
fputs(": bad resolution string\n", stderr); |
86 |
87 |
return 0; |
88 |
89 |
if (ncp->hdrflags & HF_HEADOUT) { /* finish header */ |
90 |
if (!(ncp->hdrflags & HF_HEADIN)) |
91 |
newheader("RADIANCE", stdout); |
92 |
if (ac > 0) |
93 |
printargs(ac, av, stdout); |
94 |
if (ncp->hdrflags & HF_ENCODE) { |
95 |
fputformat(NORMAL32FMT, stdout); |
96 |
} else { |
97 |
fputs("NCOMP=3\n", stdout); |
98 |
if ((ncp->hdrflags & (HF_RESIN|HF_RESOUT)) == HF_RESIN) |
99 |
printf("NCOLS=%d\nNROWS=%d\n", |
100 |
scanlen(&ncp->res), |
101 |
numscans(&ncp->res)); |
102 |
switch (ncp->format) { |
103 |
case 'a': |
104 |
fputformat("ascii", stdout); |
105 |
break; |
106 |
case 'f': |
107 |
fputendian(stdout); |
108 |
fputformat("float", stdout); |
109 |
break; |
110 |
case 'd': |
111 |
112 |
fputformat("double", stdout); |
113 |
break; |
114 |
115 |
116 |
fputc('\n', stdout); |
117 |
118 |
if (ncp->hdrflags & HF_RESOUT) /* put resolution string? */ |
119 |
fputsresolu(&ncp->res, stdout); |
120 |
121 |
ncp->dstart = ftell(ncp->finp); |
122 |
return 1; |
123 |
124 |
125 |
126 |
/* Check that we have what we need to decode normals */ |
127 |
int |
128 |
check_decode_normals(NORMCODEC *ncp) |
129 |
130 |
131 |
132 |
fputs(progname, stderr); |
133 |
fputs(": wrong header mode for decode\n", stderr); |
134 |
135 |
return 0; |
136 |
137 |
if (ncp->inpfmt[0] && strcmp(ncp->inpfmt, NORMAL32FMT)) { |
138 |
139 |
140 |
fputs(": unexpected input format: ", stderr); |
141 |
fputs(ncp->inpfmt, stderr); |
142 |
fputc('\n', stderr); |
143 |
144 |
return 0; |
145 |
146 |
return 1; |
147 |
148 |
149 |
150 |
/* Decode next normal from input */ |
151 |
int |
152 |
decode_normal_next(FVECT nrm, NORMCODEC *ncp) |
153 |
154 |
static int32 lastc; |
155 |
static FVECT lastv; |
156 |
int32 c = getint(4, ncp->finp); |
157 |
158 |
if (c == EOF && feof(ncp->finp)) |
159 |
return -1; |
160 |
161 |
if (c == lastc) { /* optimization */ |
162 |
VCOPY(nrm, lastv); |
163 |
} else { |
164 |
decodedir(nrm, c); |
165 |
if (c) { |
166 |
lastc = c; |
167 |
VCOPY(lastv, nrm); |
168 |
169 |
170 |
return (c != 0); |
171 |
172 |
173 |
174 |
/* Seek to the indicated pixel position */ |
175 |
int |
176 |
seek_nc_pix(NORMCODEC *ncp, int x, int y) |
177 |
178 |
if ((ncp->res.xr <= 0) | (ncp->res.yr <= 0)) { |
179 |
180 |
181 |
fputs(": need map resolution to seek\n", stderr); |
182 |
183 |
return -1; |
184 |
185 |
if ((x < 0) | (y < 0) || |
186 |
(x >= scanlen(&ncp->res)) | (y >= numscans(&ncp->res))) { |
187 |
188 |
189 |
fputs(": warning - pixel index off map\n", stderr); |
190 |
191 |
return 0; |
192 |
193 |
if (fseek(ncp->finp, ncp->dstart + 4*((long)y*scanlen(&ncp->res) + x), |
194 |
SEEK_SET) == EOF) { |
195 |
196 |
197 |
fputs(": seek error\n", stderr); |
198 |
199 |
return -1; |
200 |
201 |
return 1; |
202 |
203 |
204 |
205 |
/* Read and decode normal for the given pixel */ |
206 |
int |
207 |
decode_normal_pix(FVECT nrm, NORMCODEC *ncp, int x, int y) |
208 |
209 |
int rval = seek_nc_pix(ncp, x, y); |
210 |
211 |
if (rval < 0) |
212 |
return -1; |
213 |
214 |
if (!rval) { |
215 |
nrm[0] = nrm[1] = nrm[2] = .0; |
216 |
return 0; |
217 |
218 |
return decode_normal_next(nrm, ncp); |
219 |
