--- ray/src/common/normcodec.c 2019/11/07 23:20:28 2.5 +++ ray/src/common/normcodec.c 2022/03/03 16:09:31 2.6 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: normcodec.c,v 2.5 2019/11/07 23:20:28 greg Exp $"; +static const char RCSid[] = "$Id: normcodec.c,v 2.6 2022/03/03 16:09:31 greg Exp $"; #endif /* * Routines to encode/decode 32-bit normals @@ -57,6 +57,14 @@ process_nc_header(NORMCODEC *ncp, int ac, char *av[]) } return 0; } + /* get resolution string? */ + if (ncp->hdrflags & HF_RESIN && !fgetsresolu(&ncp->res, ncp->finp)) { + if (ncp->hdrflags & HF_STDERR) { + fputs(ncp->inpname, stderr); + fputs(": bad resolution string\n", stderr); + } + return 0; + } if (ncp->hdrflags & HF_HEADOUT) { /* finish header */ if (!(ncp->hdrflags & HF_HEADIN)) newheader("RADIANCE", stdout); @@ -64,7 +72,12 @@ process_nc_header(NORMCODEC *ncp, int ac, char *av[]) printargs(ac, av, stdout); if (ncp->hdrflags & HF_ENCODE) { fputformat(NORMAL32FMT, stdout); - } else + } else { + fputs("NCOMP=3\n", stdout); + if ((ncp->hdrflags & (HF_RESIN|HF_RESOUT)) == HF_RESIN) + printf("NCOLS=%d\nNROWS=%d\n", + scanlen(&ncp->res), + numscans(&ncp->res)); switch (ncp->format) { case 'a': fputformat("ascii", stdout); @@ -78,17 +91,10 @@ process_nc_header(NORMCODEC *ncp, int ac, char *av[]) fputformat("double", stdout); break; } + } fputc('\n', stdout); } - /* get/put resolution string */ - if (ncp->hdrflags & HF_RESIN && !fgetsresolu(&ncp->res, ncp->finp)) { - if (ncp->hdrflags & HF_STDERR) { - fputs(ncp->inpname, stderr); - fputs(": bad resolution string\n", stderr); - } - return 0; - } - if (ncp->hdrflags & HF_RESOUT) + if (ncp->hdrflags & HF_RESOUT) /* put resolution string? */ fputsresolu(&ncp->res, stdout); ncp->dstart = ncp->curpos = ftell(ncp->finp);
