--- ray/src/common/normcodec.c 2019/07/26 17:04:12 2.2 +++ ray/src/common/normcodec.c 2019/08/14 21:00:14 2.3 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: normcodec.c,v 2.2 2019/07/26 17:04:12 greg Exp $"; +static const char RCSid[] = "$Id: normcodec.c,v 2.3 2019/08/14 21:00:14 greg Exp $"; #endif /* * Routines to encode/decode 32-bit normals @@ -20,6 +20,7 @@ set_nc_defaults(NORMCODEC *ncp) ncp->finp = stdin; ncp->inpname = ""; ncp->format = 'a'; + ncp->swapped = 0; ncp->res.rt = PIXSTANDARD; if (!progname) progname = "norm_codec"; } @@ -30,10 +31,15 @@ static int headline(char *s, void *p) { NORMCODEC *ncp = (NORMCODEC *)p; + int rv; if (formatval(ncp->inpfmt, s)) /* don't pass format */ return 0; + if ((rv = isbigendian(s)) >= 0) { + ncp->swapped = (nativebigendian() != rv); + return 0; + } if (ncp->hdrflags & HF_HEADOUT) fputs(s, stdout); /* copy to standard output */ return 1; @@ -65,9 +71,11 @@ process_nc_header(NORMCODEC *ncp, int ac, char *av[]) fputformat("ascii", stdout); break; case 'f': + fputendian(stdout); fputformat("float", stdout); break; case 'd': + fputendian(stdout); fputformat("double", stdout); break; }
