root/radiance/ray/src/common/normcodec.c
Thu Sep 22 21:47:13 2022 UTC (20 months, 2 weeks ago) by greg
CVS Tags: HEAD, rad5R4
fix: added stdlib.h to eliminate warning about atoi()
Thu Sep 22 21:45:28 2022 UTC (20 months, 2 weeks ago) by greg
Changes since 2.7: +22 -2 lines
feat(rcode_depth,rcode_norm): Allow NROWS,NCOLS in header rather than res string
Wed Aug 24 19:55:58 2022 UTC (21 months, 2 weeks ago) by greg
Changes since 2.6: +4 -11 lines
perf: Eliminated unnecessary curpos optimization to simplify code
Thu Mar 3 16:09:31 2022 UTC (2 years, 3 months ago) by greg
Changes since 2.5: +17 -11 lines
feat(rcode_depth,rcode_norm): Output NROWS & NCOLS with -Ho
Thu Nov 7 23:20:28 2019 UTC (4 years, 7 months ago) by greg
Changes since 2.4: +4 -5 lines
Mon Aug 26 23:33:24 2019 UTC (4 years, 9 months ago) by greg
Changes since 2.3: +12 -3 lines
Optimization for repeated normal directions
Wed Aug 14 21:00:14 2019 UTC (4 years, 9 months ago) by greg
Changes since 2.2: +9 -1 lines
Added byte order to gendaymtx, rsplit, dctimestep, rcode_depth, and rcode_normal
Fri Jul 26 17:04:12 2019 UTC (4 years, 10 months ago) by greg
Changes since 2.1: +33 -19 lines
Added control for stderr output
Fri Jul 26 16:18:06 2019 UTC (4 years, 10 months ago) by greg
Diff to selected 2.4
