root/radiance/ray/src/common/normcodec.c
Revision: 2.9
Committed: Thu Sep 22 21:47:13 2022 UTC (20 months, 1 week ago) by greg
CVS Tags: rad5R4, HEAD
fix: added stdlib.h to eliminate warning about atoi()
2 static const char RCSid[] = "$Id: normcodec.c,v 2.8 2022/09/22 21:45:28 greg Exp $";
5 * Routines to encode/decode 32-bit normals
6 */
7
8 #include "copyright.h"
9
10 #include <stdlib.h>
11 #include "rtio.h"
12 #include "rtmath.h"
13 #include "normcodec.h"
14
15
16 /* Set codec defaults */
17 void
18 set_nc_defaults(NORMCODEC *ncp)
19 {
20 memset(ncp, 0, sizeof(NORMCODEC));
21 ncp->finp = stdin;
22 ncp->inpname = "<stdin>";
23 ncp->format = 'a';
24 ncp->res.rt = PIXSTANDARD;
25 if (!progname) progname = "norm_codec";
26 }
27
28
29 /* process header line */
30 static int
31 headline(char *s, void *p)
32 {
33 NORMCODEC *ncp = (NORMCODEC *)p;
34 int rv;
35
36 if (formatval(ncp->inpfmt, s)) /* don't pass format */
37 return 0;
38
39 if ((rv = isbigendian(s)) >= 0) {
40 ncp->swapped = (nativebigendian() != rv);
41 return 0;
42 }
43 if (!strncmp(s, "NCOMP=", 6)) {
44 if (atoi(s+6) != 3) {
45 if (ncp->hdrflags & HF_STDERR) {
46 fputs(ncp->inpname, stderr);
47 fputs(": NCOMP must equal 3\n", stderr);
48 }
49 return -1;
50 }
51 return 0;
52 }
53 if (!strncmp(s, "NROWS=", 6)) {
54 ncp->res.yr = atoi(s+6);
55 return 0;
56 }
57 if (!strncmp(s, "NCOLS=", 6)) {
58 ncp->res.xr = atoi(s+6);
59 return 0;
60 }
61 if (ncp->hdrflags & HF_HEADOUT)
62 fputs(s, stdout); /* copy to standard output */
63 return 1;
64 }
65
66
67 /* Load/copy header */
68 int
69 process_nc_header(NORMCODEC *ncp, int ac, char *av[])
70 {
71 if (ncp->hdrflags & HF_HEADIN &&
72 getheader(ncp->finp, headline, ncp) < 0) {
73 if (ncp->hdrflags & HF_STDERR) {
74 fputs(ncp->inpname, stderr);
75 fputs(": bad header\n", stderr);
76 }
77 return 0;
78 }
79 /* get resolution string? */
80 if (ncp->hdrflags & HF_RESIN &&
81 (ncp->res.xr <= 0) | (ncp->res.yr <= 0) &&
82 !fgetsresolu(&ncp->res, ncp->finp)) {
83 if (ncp->hdrflags & HF_STDERR) {
84 fputs(ncp->inpname, stderr);
85 fputs(": bad resolution string\n", stderr);
86 }
87 return 0;
88 }
89 if (ncp->hdrflags & HF_HEADOUT) { /* finish header */
90 if (!(ncp->hdrflags & HF_HEADIN))
91 newheader("RADIANCE", stdout);
92 if (ac > 0)
93 printargs(ac, av, stdout);
94 if (ncp->hdrflags & HF_ENCODE) {
95 fputformat(NORMAL32FMT, stdout);
96 } else {
97 fputs("NCOMP=3\n", stdout);
98 if ((ncp->hdrflags & (HF_RESIN|HF_RESOUT)) == HF_RESIN)
99 printf("NCOLS=%d\nNROWS=%d\n",
100 scanlen(&ncp->res),
101 numscans(&ncp->res));
102 switch (ncp->format) {
103 case 'a':
104 fputformat("ascii", stdout);
105 break;
106 case 'f':
107 fputendian(stdout);
108 fputformat("float", stdout);
109 break;
110 case 'd':
111 fputendian(stdout);
112 fputformat("double", stdout);
113 break;
114 }
115 }
116 fputc('\n', stdout);
117 }
118 if (ncp->hdrflags & HF_RESOUT) /* put resolution string? */
119 fputsresolu(&ncp->res, stdout);
120
121 ncp->dstart = ftell(ncp->finp);
122 return 1;
123 }
124
125
126 /* Check that we have what we need to decode normals */
127 int
128 check_decode_normals(NORMCODEC *ncp)
129 {
130 if (ncp->hdrflags & HF_ENCODE) {
131 if (ncp->hdrflags & HF_STDERR) {
132 fputs(progname, stderr);
133 fputs(": wrong header mode for decode\n", stderr);
134 }
135 return 0;
136 }
137 if (ncp->inpfmt[0] && strcmp(ncp->inpfmt, NORMAL32FMT)) {
138 if (ncp->hdrflags & HF_STDERR) {
139 fputs(ncp->inpname, stderr);
140 fputs(": unexpected input format: ", stderr);
141 fputs(ncp->inpfmt, stderr);
142 fputc('\n', stderr);
143 }
144 return 0;
145 }
146 return 1;
147 }
148
149
150 /* Decode next normal from input */
151 int
152 decode_normal_next(FVECT nrm, NORMCODEC *ncp)
153 {
154 static int32 lastc;
155 static FVECT lastv;
156 int32 c = getint(4, ncp->finp);
157
158 if (c == EOF && feof(ncp->finp))
159 return -1;
160
161 if (c == lastc) { /* optimization */
162 VCOPY(nrm, lastv);
163 } else {
164 decodedir(nrm, c);
165 if (c) {
166 lastc = c;
167 VCOPY(lastv, nrm);
168 }
169 }
170 return (c != 0);
171 }
172
173
174 /* Seek to the indicated pixel position */
175 int
176 seek_nc_pix(NORMCODEC *ncp, int x, int y)
177 {
178 if ((ncp->res.xr <= 0) | (ncp->res.yr <= 0)) {
179 if (ncp->hdrflags & HF_STDERR) {
180 fputs(progname, stderr);
181 fputs(": need map resolution to seek\n", stderr);
182 }
183 return -1;
184 }
185 if ((x < 0) | (y < 0) ||
186 (x >= scanlen(&ncp->res)) | (y >= numscans(&ncp->res))) {
187 if (ncp->hdrflags & HF_STDERR) {
188 fputs(ncp->inpname, stderr);
189 fputs(": warning - pixel index off map\n", stderr);
190 }
191 return 0;
192 }
193 if (fseek(ncp->finp, ncp->dstart + 4*((long)y*scanlen(&ncp->res) + x),
194 SEEK_SET) == EOF) {
195 if (ncp->hdrflags & HF_STDERR) {
196 fputs(ncp->inpname, stderr);
197 fputs(": seek error\n", stderr);
198 }
199 return -1;
200 }
201 return 1;
202 }
203
204
205 /* Read and decode normal for the given pixel */
206 int
207 decode_normal_pix(FVECT nrm, NORMCODEC *ncp, int x, int y)
208 {
209 int rval = seek_nc_pix(ncp, x, y);
210
211 if (rval < 0)
212 return -1;
213
214 if (!rval) {
215 nrm[0] = nrm[1] = nrm[2] = .0;
216 return 0;
217 }
218 return decode_normal_next(nrm, ncp);
219 }
