root/Development/ray/src/common/muc_randvar.h
Revision: 2.1
Committed: Thu Jul 14 17:32:12 2016 UTC (9 years, 5 months ago) by greg
CVS Tags: rad6R0, rad5R4, rad5R3, rad5R2, rad5R1, HEAD
Changes to evalglare by Jan Wienold
# User Rev Content
1 greg 2.1 /* RCSid $Id$ */
2     /*
3     ** Author: Christian Reetz ([email protected])
4     */
5     #ifndef __MUC_RANDVAR_H
6     #define __MUC_RANDVAR_H
7
8     /** \file muc_randvar.h
9     * \author Ch. Reetz ([email protected])
10     * \brief representation of a random variables of arbitrary dimension
11     */
12
13
14     #ifdef __cplusplus
15     extern "C" {
16     #endif
17
18     #include "g3flist.h"
19
20     /** random variable structure*/
21     struct muc_rvar {
22     int n; /* number of samples */
23     double w; /* sum of weights*/
24     double* sum; /* sample values sum*/
25     double* sum_sqr; /* squared sample values sum*/
26     double* min; /* minimum component value*/
27     double* max; /* maximum component value*/
28     g3FList* samples; /* measured samples (if saved)*/
29     int save_samp; /* if true (default) save samples*/
30     };
31
32     /* returns dimension of random variable*/
33     #define muc_rvar_get_dim(rv) (g3fl_get_comp_size(rv->samples))
34     /* returns the number of samples*/
35     #define muc_rvar_get_sample_size(rv) (rv->n)
36
37     /* returns a reference to a sample list element*/
38     /* Take care to have save_samp flag set*/
39     #define muc_rvar_get_sample(rv,id) (g3fl_get(rv->samples, id))
40
41
42     int muc_rvar_init(struct muc_rvar* rv);
43     struct muc_rvar* muc_rvar_create();
44     void muc_rvar_free(struct muc_rvar* rv);
45
46     /* set dimension of random variable (default 1). */
47     /* random variable needs to be empty (\see muc_rvar_clear)*/
48     int muc_rvar_set_dim(struct muc_rvar* rv,int dim);
49
50     /* set storing samples on (default) or off*/
51     /* random varianle must be cleared to succeed*/
52     int muc_rvar_store_sample(struct muc_rvar* rv, int on);
53
54     /* clear random variables samples. Don't change dimension.*/
55     void muc_rvar_clear(struct muc_rvar* rv);
56
57     /* Don't store measured sample values, just summed values.*/
58     /* (Deletes samples if there are already stored some)*/
59     void muc_rvar_no_samples(struct muc_rvar* rv);
60
61     /* adds measured sample to sums (and stores them if \ref save_samp is true)*/
62     /* The weight of the sample is assumed to be 1.0*/
63     int muc_rvar_add_sample(struct muc_rvar* rv,double* sample);
64
65     /* adds \param w weighted sample to sums */
66     /* (and stores them if \ref save_samp is true)*/
67     int muc_rvar_add_weighted_sample(struct muc_rvar* rv,double w,double* samp);
68
69     /* returns current expected value in \param ex*/
70     int muc_rvar_get_ex(struct muc_rvar* rv,double* ex);
71
72     /* returns current variance in \param vx*/
73     int muc_rvar_get_vx(struct muc_rvar* rv,double* vx);
74
75     /* returns current bounds*/
76     /* \param bounds: array with len 2*component_size */
77     /* \return {min1, max1, min2, max2....}*/
78     int muc_rvar_get_bounding_box(struct muc_rvar* rv, double* bounds);
79
80     /* return sample median (using averaging for even sample numbers)*/
81     /* \return false if samples are not stored*/
82     int muc_rvar_get_median(struct muc_rvar* rv, double* median);
83
84     int muc_rvar_get_percentile(struct muc_rvar* rv, double* median, double percentile);
85
86     #ifdef __cplusplus
87     }
88     #endif
89     #endif
