root/radiance/ray/src/common/muc_randvar.c
Revision: 2.1
Committed: Thu Jul 14 17:32:12 2016 UTC (8 years, 11 months ago) by greg
CVS Tags: rad5R4, rad5R2, rad5R3, rad5R1, HEAD
Changes to evalglare by Jan Wienold
4 #include <stdio.h>
5 #include <stdlib.h>
6
7 #include "fvect.h"
8 #include "muc_randvar.h"
9
10 int muc_rvar_init(struct muc_rvar* rv)
11 {
12 rv->n = 0;
13 rv->w = 0.0;
14 if (!(rv->samples = g3fl_create(1)))
15 return 0;
16 rv->sum = NULL;
17 rv->sum_sqr = NULL;
18 rv->min = NULL;
19 rv->max = NULL;
20 rv->save_samp = 1;
21 return muc_rvar_set_dim(rv,1);
22 }
23
24 struct muc_rvar* muc_rvar_create()
25 {
26 struct muc_rvar* res;
27
28 if (!(res = (struct muc_rvar*) malloc(sizeof(struct muc_rvar))))
29 return NULL;
30 if (!(muc_rvar_init(res))) {
31 free(res);
32 return NULL;
33 }
34 return res;
35 }
36
37 void muc_rvar_free(struct muc_rvar* rv)
38 {
39 free(rv->sum);
40 free(rv->sum_sqr);
41 free(rv->min);
42 free(rv->max);
43 g3fl_free(rv->samples);
44 free(rv);
45 }
46
47 int muc_rvar_set_dim(struct muc_rvar* rv,int dim)
48 {
49 if (rv->n != 0) {
50 fprintf(stderr,"muc_rvar_set_dim: variable not cleared\n");
51 return 0;
52 }
53 if (!(rv->sum = realloc(rv->sum,dim*sizeof(double))))
54 return 0;
55 if (!(rv->sum_sqr = realloc(rv->sum_sqr,dim*sizeof(double))))
56 return 0;
57 if (!(rv->min = realloc(rv->min,dim*sizeof(double))))
58 return 0;
59 if (!(rv->max = realloc(rv->max,dim*sizeof(double))))
60 return 0;
61 rv->samples->comp_size = dim;
62 muc_rvar_clear(rv);
63 return 1;
64 }
65
66 void muc_rvar_clear(struct muc_rvar* rv)
67 {
68 int i;
69
70 rv->samples->size=0;
71 rv->w = 0.0;
72 rv->n = 0;
73 for(i=0;i<muc_rvar_get_dim(rv);i++) {
74 rv->sum[i] = 0.0;
75 rv->sum_sqr[i] = 0.0;
76 rv->min[i] = FHUGE;
77 rv->max[i] = -FHUGE;
78 }
79 }
80
81 void muc_rvar_no_samples(struct muc_rvar* rv)
82 {
83 rv->samples->size = 0;
84 rv->save_samp = 0;
85 }
86
87 int muc_rvar_store_sample(struct muc_rvar* rv, int on)
88 {
89 if (rv->n != 0) {
90 fprintf(stderr,"muc_rvar_store_sample: clear samples first\n");
91 return 0;
92 }
93 rv->save_samp = on;
94 return 1;
95 }
96
97 int muc_rvar_add_sample(struct muc_rvar* rv,double* s)
98 {
99 return muc_rvar_add_weighted_sample(rv,1.0,s);
100 }
101
102 int muc_rvar_add_weighted_sample(struct muc_rvar* rv,double w,double* s)
103 {
104 int i;
105 double val;
106
107 if (rv->save_samp)
108 if (!(g3fl_append(rv->samples,s)))
109 return 0;
110 for(i=0;i<muc_rvar_get_dim(rv);i++) {
111 val = s[i]*w;
112 rv->sum[i] += val;
113 rv->sum_sqr[i] += s[i]*s[i]*w;
114 if (rv->min[i] > val)
115 rv->min[i] = val;
116 if (rv->max[i] < val)
117 rv->max[i] = val;
118 }
119 rv->w += w;
120 rv->n++;
121 return 1;
122 }
123
124 int muc_rvar_get_vx(struct muc_rvar* rv,double* vx)
125 {
126 int i;
127 double ex,ex2;
128
129 if (rv->w == 0.0) {
130 return 0;
131 }
132 for(i=0;i<muc_rvar_get_dim(rv);i++) {
133 ex = rv->sum[i]/rv->w;
134 ex2 = rv->sum_sqr[i]/rv->w;
135 vx[i] = ex2 - ex*ex;
136 }
137 return 1;
138 }
139
140 int muc_rvar_get_ex(struct muc_rvar* rv,double* ex)
141 {
142 int i;
143
144 if (rv->w == 0.0) {
145 return 0;
146 }
147 for(i=0;i<muc_rvar_get_dim(rv);i++) {
148 ex[i] = rv->sum[i]/rv->w;
149 }
150 return 1;
151 }
152 int muc_rvar_get_sum(struct muc_rvar* rv,double* sum2)
153 {
154 int i;
155
156 for(i=0;i<muc_rvar_get_dim(rv);i++) {
157 sum2[i] = rv->sum[i];
158 }
159 return 1;
160 }
161
162 int muc_rvar_get_median(struct muc_rvar* rv, double* median)
163 {
164 double val;
165 int i;
166
167 if (!(rv->save_samp)) {
168 fprintf(stderr,"muc_rvar_get_median: samples are not stored\n");
169 return 0;
170 }
171 for(i=0;i<muc_rvar_get_dim(rv);i++) {
172 g3fl_sort(rv->samples, i);
173 val = g3fl_get(rv->samples, rv->n/2)[i];
174
175 if (rv->n % 2 == 0) {
176 val += g3fl_get(rv->samples,rv->n/2 - 1)[i];
177 val /= 2.0;
178 }
179 median[i] = val;
180 }
181 return 1;
182 }
183 int muc_rvar_get_percentile(struct muc_rvar* rv, double* median, double percentile)
184 {
185 double val;
186 int i;
187
188 if (!(rv->save_samp)) {
189 fprintf(stderr,"muc_rvar_get_median: samples are not stored\n");
190 return 0;
191 }
192 for(i=0;i<muc_rvar_get_dim(rv);i++) {
193 g3fl_sort(rv->samples, i);
194 val = g3fl_get(rv->samples, rv->n*percentile)[i];
195
196 if (rv->n % 1/percentile == 0) {
197 val += g3fl_get(rv->samples,rv->n*percentile - 1)[i];
198 val /= 2.0;
199 }
200 median[i] = val;
201 }
202 return 1;
203 }
204
205 int muc_rvar_get_bounding_box(struct muc_rvar* rv, double* bounds)
206 {
207 int i;
208
209 if (rv->n == 0)
210 return 0;
211 for(i=0;i<muc_rvar_get_dim(rv);i++) {
212 bounds[2*i] = rv->min[i];
213 bounds[2*i + 1] = rv->max[i];
214 }
215 return 1;
216 }
217
