1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: modobject.c,v 2.14 2013/12/08 18:59:53 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Routines for tracking object modifiers |
6 |
7 |
* External symbols declared in object.h |
8 |
9 |
10 |
#include "copyright.h" |
11 |
12 |
#include "standard.h" |
13 |
14 |
#include "object.h" |
15 |
16 |
#include "otypes.h" |
17 |
18 |
19 |
static struct ohtab { |
20 |
int hsiz; /* current table size */ |
21 |
OBJECT *htab; /* table, if allocated */ |
22 |
} modtab = {100, NULL}, objtab = {1000, NULL}; /* modifiers and objects */ |
23 |
24 |
static int otndx(char *, struct ohtab *); |
25 |
26 |
27 |
OBJECT |
28 |
objndx( /* get object number from pointer */ |
29 |
OBJREC *op |
30 |
31 |
32 |
int i, j; |
33 |
34 |
for (i = nobjects>>OBJBLKSHFT; i >= 0; i--) { |
35 |
j = op - objblock[i]; |
36 |
if ((j >= 0) & (j < OBJBLKSIZ)) |
37 |
return((i<<OBJBLKSHFT) + j); |
38 |
39 |
return(OVOID); |
40 |
41 |
42 |
43 |
OBJECT |
44 |
lastmod( /* find modifier definition before obj */ |
45 |
OBJECT obj, |
46 |
char *mname |
47 |
48 |
49 |
OBJREC *op; |
50 |
int i; |
51 |
52 |
i = modifier(mname); /* try hash table first */ |
53 |
if ((obj == OVOID) | (i < obj)) |
54 |
return(i); |
55 |
for (i = obj; i-- > 0; ) { /* need to search */ |
56 |
op = objptr(i); |
57 |
if (ismodifier(op->otype) && op->oname[0] == mname[0] && |
58 |
!strcmp(op->oname, mname)) |
59 |
return(i); |
60 |
61 |
return(OVOID); |
62 |
63 |
64 |
65 |
OBJECT |
66 |
modifier( /* get a modifier number from its name */ |
67 |
char *mname |
68 |
69 |
70 |
int ndx; |
71 |
72 |
ndx = otndx(mname, &modtab); |
73 |
return(modtab.htab[ndx]); |
74 |
75 |
76 |
77 |
#ifdef GETOBJ |
78 |
OBJECT |
79 |
object( /* get an object number from its name */ |
80 |
char *oname |
81 |
82 |
83 |
int ndx; |
84 |
85 |
ndx = otndx(oname, &objtab); |
86 |
return(objtab.htab[ndx]); |
87 |
88 |
#endif |
89 |
90 |
91 |
int |
92 |
eqreal( /* are two real values close enough to equal? */ |
93 |
double d1, |
94 |
double d2 |
95 |
96 |
97 |
if (d2 != 0.0) |
98 |
d1 = d1/d2 - 1.0; |
99 |
return((-FTINY <= d1) & (d1 <= FTINY)); |
100 |
101 |
102 |
103 |
int |
104 |
eqobjects( /* check if two objects are equal */ |
105 |
OBJECT obj1, |
106 |
OBJECT obj2 |
107 |
108 |
109 |
OBJREC *op1, *op2; |
110 |
int i; |
111 |
112 |
while (obj1 != obj2) { |
113 |
if (obj1 == OVOID) |
114 |
return(0); |
115 |
if (obj2 == OVOID) |
116 |
return(0); |
117 |
op1 = objptr(obj1); |
118 |
op2 = objptr(obj2); |
119 |
if (op1->otype != op2->otype) |
120 |
return(0); |
121 |
if (op1->oargs.nsargs != op2->oargs.nsargs) |
122 |
return(0); |
123 |
if (op1->oargs.nfargs != op2->oargs.nfargs) |
124 |
return(0); |
125 |
#ifdef IARGS |
126 |
if (op1->oargs.niargs != op2->oargs.niargs) |
127 |
return(0); |
128 |
for (i = op1->oargs.niargs; i-- > 0; ) |
129 |
if (op1->oargs.iarg[i] != op2->oargs.iarg[i]) |
130 |
return(0); |
131 |
#endif |
132 |
for (i = op1->oargs.nfargs; i-- > 0; ) |
133 |
if (!eqreal(op1->oargs.farg[i], op2->oargs.farg[i])) |
134 |
return(0); |
135 |
for (i = op1->oargs.nsargs; i-- > 0; ) |
136 |
if (strcmp(op1->oargs.sarg[i], op2->oargs.sarg[i])) |
137 |
return(0); |
138 |
obj1 = op1->omod; |
139 |
obj2 = op2->omod; |
140 |
141 |
return(1); |
142 |
143 |
144 |
145 |
void |
146 |
insertobject( /* insert new object into our list */ |
147 |
OBJECT obj |
148 |
149 |
150 |
int i; |
151 |
152 |
if (ismodifier(objptr(obj)->otype)) { |
153 |
i = otndx(objptr(obj)->oname, &modtab); |
154 |
if (eqobjects(obj, modtab.htab[i])) |
155 |
return; |
156 |
modtab.htab[i] = obj; |
157 |
158 |
#ifdef GETOBJ |
159 |
else { |
160 |
i = otndx(objptr(obj)->oname, &objtab); |
161 |
objtab.htab[i] = obj; |
162 |
163 |
#endif |
164 |
for (i = 0; addobjnotify[i] != NULL; i++) |
165 |
(*addobjnotify[i])(obj); |
166 |
167 |
168 |
169 |
void |
170 |
clearobjndx(void) /* clear object hash tables */ |
171 |
172 |
if (modtab.htab != NULL) { |
173 |
free((void *)modtab.htab); |
174 |
modtab.htab = NULL; |
175 |
modtab.hsiz = 100; |
176 |
177 |
if (objtab.htab != NULL) { |
178 |
free((void *)objtab.htab); |
179 |
objtab.htab = NULL; |
180 |
objtab.hsiz = 100; |
181 |
182 |
183 |
184 |
185 |
static int |
186 |
nexthsiz( /* return next hash table size */ |
187 |
int oldsiz |
188 |
189 |
190 |
static int hsiztab[] = { |
191 |
251, 509, 1021, 2039, 4093, 8191, 16381, 0 |
192 |
193 |
int *hsp; |
194 |
195 |
for (hsp = hsiztab; *hsp; hsp++) |
196 |
if (*hsp > oldsiz) |
197 |
return(*hsp); |
198 |
return(oldsiz*2 + 1); /* not always prime */ |
199 |
200 |
201 |
202 |
static int |
203 |
otndx( /* get object table index for name */ |
204 |
char *name, |
205 |
struct ohtab *tab |
206 |
207 |
208 |
OBJECT *oldhtab; |
209 |
int hval, i; |
210 |
int ndx; |
211 |
212 |
if (tab->htab == NULL) { /* new table */ |
213 |
tab->hsiz = nexthsiz(tab->hsiz); |
214 |
tab->htab = (OBJECT *)malloc(tab->hsiz*sizeof(OBJECT)); |
215 |
if (tab->htab == NULL) |
216 |
error(SYSTEM, "out of memory in otndx"); |
217 |
ndx = tab->hsiz; |
218 |
while (ndx--) /* empty it */ |
219 |
tab->htab[ndx] = OVOID; |
220 |
221 |
/* look up object */ |
222 |
hval = shash(name); |
223 |
tryagain: |
224 |
for (i = 0; i < tab->hsiz; i++) { |
225 |
ndx = (hval + (unsigned long)i*i) % tab->hsiz; |
226 |
if (tab->htab[ndx] == OVOID || |
227 |
!strcmp(objptr(tab->htab[ndx])->oname, name)) |
228 |
return(ndx); |
229 |
230 |
/* table is full, reallocate */ |
231 |
oldhtab = tab->htab; |
232 |
ndx = tab->hsiz; |
233 |
tab->htab = NULL; |
234 |
while (ndx--) |
235 |
if (oldhtab[ndx] != OVOID) { |
236 |
i = otndx(objptr(oldhtab[ndx])->oname, tab); |
237 |
tab->htab[i] = oldhtab[ndx]; |
238 |
239 |
free((void *)oldhtab); |
240 |
goto tryagain; /* should happen only once! */ |
241 |
