--- ray/src/common/modobject.c 2003/03/10 17:13:29 2.9 +++ ray/src/common/modobject.c 2013/12/08 19:25:36 2.15 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: modobject.c,v 2.9 2003/03/10 17:13:29 greg Exp $"; +static const char RCSid[] = "$Id: modobject.c,v 2.15 2013/12/08 19:25:36 greg Exp $"; #endif /* * Routines for tracking object modifiers @@ -21,18 +21,19 @@ static struct ohtab { OBJECT *htab; /* table, if allocated */ } modtab = {100, NULL}, objtab = {1000, NULL}; /* modifiers and objects */ -static int otndx(); +static int otndx(char *, struct ohtab *); OBJECT -objndx(op) /* get object number from pointer */ -register OBJREC *op; +objndx( /* get object number from pointer */ + OBJREC *op +) { - register int i, j; + int i, j; for (i = nobjects>>OBJBLKSHFT; i >= 0; i--) { j = op - objblock[i]; - if (j >= 0 && j < OBJBLKSIZ) + if ((j >= 0) & (j < OBJBLKSIZ)) return((i< 0; ) { /* need to search */ op = objptr(i); - if (ismodifier(op->otype) && !strcmp(op->oname, mname)) + if (ismodifier(op->otype) && op->oname[0] == mname[0] && + !strcmp(op->oname, mname)) return(i); } return(OVOID); @@ -60,10 +63,11 @@ char *mname; OBJECT -modifier(mname) /* get a modifier number from its name */ -char *mname; +modifier( /* get a modifier number from its name */ + char *mname +) { - register int ndx; + int ndx; ndx = otndx(mname, &modtab); return(modtab.htab[ndx]); @@ -72,10 +76,11 @@ char *mname; #ifdef GETOBJ OBJECT -object(oname) /* get an object number from its name */ -char *oname; +object( /* get an object number from its name */ + char *oname +) { - register int ndx; + int ndx; ndx = otndx(oname, &objtab); return(objtab.htab[ndx]); @@ -83,14 +88,71 @@ char *oname; #endif +int +eqreal( /* are two real values close enough to equal? */ + double d1, + double d2 +) +{ + if (d2 != 0.0) + d1 = d1/d2 - 1.0; + return((-FTINY <= d1) & (d1 <= FTINY)); +} + + +int +eqobjects( /* check if two objects are equal */ + OBJECT obj1, + OBJECT obj2 +) +{ + OBJREC *op1, *op2; + int i; + + while (obj1 != obj2) { + if (obj1 == OVOID) + return(0); + if (obj2 == OVOID) + return(0); + op1 = objptr(obj1); + op2 = objptr(obj2); + if (op1->otype != op2->otype) + return(0); + if (op1->oargs.nsargs != op2->oargs.nsargs) + return(0); + if (op1->oargs.nfargs != op2->oargs.nfargs) + return(0); +#ifdef IARGS + if (op1->oargs.niargs != op2->oargs.niargs) + return(0); + for (i = op1->oargs.niargs; i-- > 0; ) + if (op1->oargs.iarg[i] != op2->oargs.iarg[i]) + return(0); +#endif + for (i = op1->oargs.nfargs; i-- > 0; ) + if (!eqreal(op1->oargs.farg[i], op2->oargs.farg[i])) + return(0); + for (i = op1->oargs.nsargs; i-- > 0; ) + if (strcmp(op1->oargs.sarg[i], op2->oargs.sarg[i])) + return(0); + obj1 = op1->omod; + obj2 = op2->omod; + } + return(1); +} + + void -insertobject(obj) /* insert new object into our list */ -register OBJECT obj; +insertobject( /* insert new object into our list */ + OBJECT obj +) { - register int i; + int i; if (ismodifier(objptr(obj)->otype)) { i = otndx(objptr(obj)->oname, &modtab); + if (eqobjects(obj, modtab.htab[i])) + return; modtab.htab[i] = obj; } #ifdef GETOBJ @@ -105,7 +167,7 @@ register OBJECT obj; void -clearobjndx() /* clear object hash tables */ +clearobjndx(void) /* clear object hash tables */ { if (modtab.htab != NULL) { free((void *)modtab.htab); @@ -121,13 +183,14 @@ clearobjndx() /* clear object hash tables */ static int -nexthsiz(oldsiz) /* return next hash table size */ -int oldsiz; +nexthsiz( /* return next hash table size */ + int oldsiz +) { static int hsiztab[] = { 251, 509, 1021, 2039, 4093, 8191, 16381, 0 }; - register int *hsp; + int *hsp; for (hsp = hsiztab; *hsp; hsp++) if (*hsp > oldsiz) @@ -137,13 +200,14 @@ int oldsiz; static int -otndx(name, tab) /* get object table index for name */ -char *name; -register struct ohtab *tab; +otndx( /* get object table index for name */ + char *name, + struct ohtab *tab +) { OBJECT *oldhtab; int hval, i; - register int ndx; + int ndx; if (tab->htab == NULL) { /* new table */ tab->hsiz = nexthsiz(tab->hsiz); @@ -158,7 +222,7 @@ register struct ohtab *tab; hval = shash(name); tryagain: for (i = 0; i < tab->hsiz; i++) { - ndx = (hval + i*i) % tab->hsiz; + ndx = (hval + (unsigned long)i*i) % tab->hsiz; if (tab->htab[ndx] == OVOID || !strcmp(objptr(tab->htab[ndx])->oname, name)) return(ndx);
