--- ray/src/common/modobject.c 1998/08/11 09:54:34 2.5 +++ ray/src/common/modobject.c 2024/12/06 20:54:23 2.22 @@ -1,13 +1,14 @@ -/* Copyright (c) 1992 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: modobject.c,v 2.22 2024/12/06 20:54:23 greg Exp $"; #endif - /* * Routines for tracking object modifiers + * + * External symbols declared in object.h */ +#include "copyright.h" + #include "standard.h" #include "object.h" @@ -15,56 +16,59 @@ static char SCCSid[] = "$SunId$ LBL"; #include "otypes.h" -extern int (*addobjnotify[])(); /* people to notify of new objects */ - static struct ohtab { - int hsiz; /* current table size */ - OBJECT *htab; /* table, if allocated */ + int hsiz; /* current table size */ + OBJECT *htab; /* table, if allocated */ } modtab = {100, NULL}, objtab = {1000, NULL}; /* modifiers and objects */ -static int otndx(); +static int otndx(char *, struct ohtab *); -int -objndx(op) /* get object number from pointer */ -register OBJREC *op; +OBJECT +objndx( /* get object number from pointer */ + OBJREC *op +) { - register int i, j; + int i; + ssize_t j; - for (i = nobjects>>6; i >= 0; i--) { + for (i = (nobjects-1)>>OBJBLKSHFT; i >= 0; i--) { j = op - objblock[i]; - if (j >= 0 && j < 0100) - return((i<<6) + j); + if ((0 <= j) & (j < OBJBLKSIZ)) + return(((OBJECT)i< 0; ) { /* need to search */ op = objptr(i); - if (ismodifier(op->otype) && !strcmp(op->oname, mname)) + if ((ismodifier(op->otype) != 0) & (op->oname[0] == mname[0]) + && !strcmp(op->oname, mname)) return(i); } return(OVOID); } -int -modifier(mname) /* get a modifier number from its name */ -char *mname; +OBJECT +modifier( /* get a modifier number from its name */ + char *mname +) { - register int ndx; + int ndx; ndx = otndx(mname, &modtab); return(modtab.htab[ndx]); @@ -72,11 +76,12 @@ char *mname; #ifdef GETOBJ -int -object(oname) /* get an object number from its name */ -char *oname; +OBJECT +object( /* get an object number from its name */ + char *oname +) { - register int ndx; + int ndx; ndx = otndx(oname, &objtab); return(objtab.htab[ndx]); @@ -84,13 +89,93 @@ char *oname; #endif -insertobject(obj) /* insert new object into our list */ -register OBJECT obj; +int +eqreal( /* are two real values close enough to equal? */ + double d1, + double d2 +) { - register int i; + if (d2 != 0.0) + d1 = d1/d2 - 1.0; + return((-FTINY <= d1) & (d1 <= FTINY)); +} + +int +eqobjects( /* check if two objects are equal */ + OBJECT obj1, + OBJECT obj2 +) +{ + OBJREC *op1, *op2; + int i, n; + + while (obj1 != obj2) { + if (obj1 == OVOID) + return(0); + if (obj2 == OVOID) + return(0); + op1 = objptr(obj1); + op2 = objptr(obj2); + if (op1->otype != op2->otype) + return(0); + if (op1->oargs.nsargs != op2->oargs.nsargs) + return(0); + if (op1->oargs.nfargs != op2->oargs.nfargs) + return(0); +#ifdef IARGS + if (op1->oargs.niargs != op2->oargs.niargs) + return(0); + for (i = op1->oargs.niargs; i-- > 0; ) + if (op1->oargs.iarg[i] != op2->oargs.iarg[i]) + return(0); +#endif + for (i = op1->oargs.nfargs; i-- > 0; ) + if (!eqreal(op1->oargs.farg[i], op2->oargs.farg[i])) + return(0); + n = 0; + switch (op1->otype) { /* special cases (KEEP CONSISTENT!) */ + case MOD_ALIAS: + case MAT_ILLUM: + case MAT_MIRROR: + n = (op1->oargs.nsargs > 0); + break; + case MIX_FUNC: + case MIX_DATA: + case MIX_TEXT: + case MIX_PICT: + n = 2*(op1->oargs.nsargs >= 2); + break; + case MAT_CLIP: + n = op1->oargs.nsargs; + break; + } + /* check other string arguments */ + for (i = op1->oargs.nsargs; i-- > n; ) + if (strcmp(op1->oargs.sarg[i], op2->oargs.sarg[i])) + return(0); + while (n-- > 0) /* check modifier references */ + if (!eqobjects( lastmod(obj1, op1->oargs.sarg[n]), + lastmod(obj2, op2->oargs.sarg[n]) )) + return(0); + obj1 = op1->omod; + obj2 = op2->omod; + } + return(1); +} + + +void +insertobject( /* insert new object into our list */ + OBJECT obj +) +{ + int i; + if (ismodifier(objptr(obj)->otype)) { i = otndx(objptr(obj)->oname, &modtab); + if (eqobjects(obj, modtab.htab[i])) + return; /* don't index if same as earlier def. */ modtab.htab[i] = obj; } #ifdef GETOBJ @@ -104,14 +189,44 @@ register OBJECT obj; } +void +truncobjndx(void) /* remove bogus table entries past end */ +{ + int ndx; + + if (nobjects <= 0) { + if (modtab.htab != NULL) { + free(modtab.htab); + modtab.htab = NULL; + modtab.hsiz = 100; + } + if (objtab.htab != NULL) { + free(objtab.htab); + objtab.htab = NULL; + objtab.hsiz = 100; + } + return; + } + for (ndx = modtab.hsiz*(modtab.htab != NULL); ndx--; ) + if (modtab.htab[ndx] >= nobjects) + modtab.htab[ndx] = OVOID; + + for (ndx = objtab.hsiz*(objtab.htab != NULL); ndx--; ) + if (objtab.htab[ndx] >= nobjects) + objtab.htab[ndx] = OVOID; +} + + static int -nexthsiz(oldsiz) /* return next hash table size */ -int oldsiz; +nexthsiz( /* return next hash table size */ + int oldsiz +) { static int hsiztab[] = { - 251, 509, 1021, 2039, 4093, 8191, 16381, 0 + 251, 509, 1021, 2039, 4093, 8191, 16381, + 32749, 65521, 131071, 262139, 0 }; - register int *hsp; + int *hsp; for (hsp = hsiztab; *hsp; hsp++) if (*hsp > oldsiz) @@ -121,13 +236,15 @@ int oldsiz; static int -otndx(name, tab) /* get object table index for name */ -char *name; -register struct ohtab *tab; +otndx( /* get object table index for name */ + char *name, + struct ohtab *tab +) { + char *onm; OBJECT *oldhtab; int hval, i; - register int ndx; + int ndx; if (tab->htab == NULL) { /* new table */ tab->hsiz = nexthsiz(tab->hsiz); @@ -142,10 +259,12 @@ register struct ohtab *tab; hval = shash(name); tryagain: for (i = 0; i < tab->hsiz; i++) { - ndx = (hval + i*i) % tab->hsiz; - if (tab->htab[ndx] == OVOID || - !strcmp(objptr(tab->htab[ndx])->oname, name)) + ndx = (hval + (unsigned long)i*i) % tab->hsiz; + if (tab->htab[ndx] == OVOID) return(ndx); + onm = objptr(tab->htab[ndx])->oname; + if (onm != NULL && !strcmp(onm, name)) + return(ndx); } /* table is full, reallocate */ oldhtab = tab->htab; @@ -153,9 +272,12 @@ tryagain: tab->htab = NULL; while (ndx--) if (oldhtab[ndx] != OVOID) { - i = otndx(objptr(oldhtab[ndx])->oname, tab); + onm = objptr(oldhtab[ndx])->oname; + if (onm == NULL) + continue; + i = otndx(onm, tab); tab->htab[i] = oldhtab[ndx]; } - free((char *)oldhtab); + free(oldhtab); goto tryagain; /* should happen only once! */ }
