--- ray/src/common/modobject.c 1992/11/21 21:35:38 2.2 +++ ray/src/common/modobject.c 1998/08/11 09:54:34 2.5 @@ -25,20 +25,42 @@ static struct ohtab { static int otndx(); -#ifdef GETOBJ int -object(oname) /* get an object number from its name */ -char *oname; +objndx(op) /* get object number from pointer */ +register OBJREC *op; { - register int ndx; + register int i, j; - ndx = otndx(oname, &objtab); - return(objtab.htab[ndx]); + for (i = nobjects>>6; i >= 0; i--) { + j = op - objblock[i]; + if (j >= 0 && j < 0100) + return((i<<6) + j); + } + return(OVOID); } -#endif int +lastmod(obj, mname) /* find modifier definition before obj */ +OBJECT obj; +char *mname; +{ + register OBJREC *op; + register int i; + + i = modifier(mname); /* try hash table first */ + if (i < obj) + return(i); + for (i = obj; i-- > 0; ) { /* need to search */ + op = objptr(i); + if (ismodifier(op->otype) && !strcmp(op->oname, mname)) + return(i); + } + return(OVOID); +} + + +int modifier(mname) /* get a modifier number from its name */ char *mname; { @@ -49,19 +71,34 @@ char *mname; } +#ifdef GETOBJ +int +object(oname) /* get an object number from its name */ +char *oname; +{ + register int ndx; + + ndx = otndx(oname, &objtab); + return(objtab.htab[ndx]); +} +#endif + + insertobject(obj) /* insert new object into our list */ register OBJECT obj; { register int i; -#ifdef GETOBJ - i = otndx(objptr(obj)->oname, &objtab); - objtab.htab[i] = obj; -#endif if (ismodifier(objptr(obj)->otype)) { i = otndx(objptr(obj)->oname, &modtab); modtab.htab[i] = obj; } +#ifdef GETOBJ + else { + i = otndx(objptr(obj)->oname, &objtab); + objtab.htab[i] = obj; + } +#endif for (i = 0; addobjnotify[i] != NULL; i++) (*addobjnotify[i])(obj); }
