root/Development/ray/src/common/modobject.c
Revision 2.26 - (view) (download) (annotate) - [selected]
Sun Jun 22 17:21:37 2025 UTC (4 months, 2 weeks ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.25: +11 -8 lines
Diff to previous 2.25
perf: Minor code tweaks to speed initial search, check case OVOID==0
Sat Jun 21 17:42:17 2025 UTC (4 months, 2 weeks ago) by greg
Changes since 2.24: +21 -9 lines
Diff to previous 2.24 , to selected 2.26
perf: Optimized objndx() call with hashed cache table
Sat Jun 21 00:15:30 2025 UTC (4 months, 2 weeks ago) by greg
Changes since 2.23: +6 -7 lines
Diff to previous 2.23 , to selected 2.26
fix: paranoia in case sizeof(long) < sizeof(size_t)
Sun Dec 8 20:48:15 2024 UTC (10 months, 3 weeks ago) by greg
Diff to previous 2.22 , to selected 2.26
fix: Windows doesn't seem to have ssize_t
Fri Dec 6 20:54:23 2024 UTC (10 months, 4 weeks ago) by greg
Changes since 2.21: +9 -9 lines
Diff to previous 2.21 , to selected 2.26
fix: Another potential fix if OBJECT ever larger than int
Fri Dec 6 20:30:15 2024 UTC (10 months, 4 weeks ago) by greg
Changes since 2.20: +4 -4 lines
Diff to previous 2.20 , to selected 2.26
fix: Fixed potential bug in 64-bit machines with 32-bit integers
Mon Feb 1 17:36:45 2021 UTC (4 years, 9 months ago) by greg
Changes since 2.19: +5 -4 lines
Diff to previous 2.19 , to selected 2.26
fix: prophylactic against 64-bit architectures with 32-bit int's
Sat Oct 17 17:48:46 2020 UTC (5 years ago) by greg
Changes since 2.18: +12 -5 lines
Diff to previous 2.18 , to selected 2.26
fix: added caution around NULL modifier names
Sat Oct 17 16:39:23 2020 UTC (5 years ago) by greg
Changes since 2.17: +23 -11 lines
Diff to previous 2.17 , to selected 2.26
fix: freeing *some* objects now preserves valid modifier lookups
Mon Dec 9 18:17:13 2013 UTC (11 years, 10 months ago) by greg
Diff to previous 2.16 , to selected 2.26
Minor optimization to reference check in eqobjects()
Mon Dec 9 17:57:44 2013 UTC (11 years, 10 months ago) by greg
Changes since 2.15: +23 -2 lines
Diff to previous 2.15 , to selected 2.26
Added check for references to different, identically-named modifiers
Sun Dec 8 19:25:36 2013 UTC (11 years, 11 months ago) by greg
Changes since 2.14: +28 -28 lines
Diff to previous 2.14 , to selected 2.26
Made eqobjects() a little more general and exposed eqreal() to library
Sun Dec 8 18:59:53 2013 UTC (11 years, 11 months ago) by greg
Changes since 2.13: +57 -1 lines
Diff to previous 2.13 , to selected 2.26
Sat Mar 9 18:53:05 2013 UTC (12 years, 8 months ago) by greg
Changes since 2.12: +35 -27 lines
Diff to previous 2.12 , to selected 2.26
Slight efficiency improvement and ansification
Wed Jul 14 02:37:23 2004 UTC (21 years, 3 months ago) by greg
Diff to previous 2.11 , to selected 2.26
Bug fix for alias modifiers -- not exactly right for non-unique modifiers
Tue Sep 30 00:13:58 2003 UTC (22 years, 1 month ago) by greg
Diff to previous 2.10 , to selected 2.26
Thu Jul 17 09:21:29 2003 UTC (22 years, 3 months ago) by schorsch
Diff to previous 2.9 , to selected 2.26
Mon Mar 10 17:13:29 2003 UTC (22 years, 8 months ago) by greg
Diff to previous 2.8 , to selected 2.26
Tue Feb 25 02:47:21 2003 UTC (22 years, 8 months ago) by greg
Diff to previous 2.7 , to selected 2.26
Sat Feb 22 02:07:22 2003 UTC (22 years, 8 months ago) by greg
Changes since 2.6: +78 -7 lines
Diff to previous 2.6 , to selected 2.26
Thu Nov 5 16:51:26 1998 UTC (27 years ago) by gwlarson
Diff to previous 2.5 , to selected 2.26
fixed problem with new object block sizing
Tue Aug 11 09:54:34 1998 UTC (27 years, 3 months ago) by gwlarson
Diff to previous 2.4 , to selected 2.26
fixed bug in objndx()
Sun Dec 15 15:45:17 1996 UTC (28 years, 10 months ago) by greg
Diff to previous 2.3 , to selected 2.26
made lastmod() more efficient for singly-defined modifier
Mon Feb 12 17:14:59 1996 UTC (29 years, 9 months ago) by greg
Changes since 2.2: +45 -11 lines
Diff to previous 2.2 , to selected 2.26
added objndx() and lastmod() functions for looking up modifiers
Sat Nov 21 21:35:38 1992 UTC (32 years, 11 months ago) by greg
Changes since 2.1: +1 -13 lines
Diff to previous 2.1 , to selected 2.26
added global free routines
Tue Nov 12 16:56:08 1991 UTC (34 years ago) by greg
Diff to previous 1.3 , to selected 2.26
Mon Oct 28 09:47:24 1991 UTC (34 years ago) by greg
Diff to previous 1.2 , to selected 2.26
Mon Jul 29 15:47:46 1991 UTC (34 years, 3 months ago) by greg
Diff to previous 1.1 , to selected 2.26
added back in otypes.h include to modobject.c
Wed Jul 24 12:04:52 1991 UTC (34 years, 3 months ago) by greg
Diff to selected 2.26
